Horsee Clutched June 6, 2009 Share June 6, 2009 Hi, Do you guys check yr coolant & radiator water & at what km interval. I just found out that my coolant tank is totally dry out, and there is still 5k to my next servicing. Thought this water top up can last easily for 10K interval. Unless there is an leak somewhere??? ↡ Advertisement Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 6, 2009 Share June 6, 2009 Hi, Do you guys check yr coolant & radiator water & at what km interval. I just found out that my coolant tank is totally dry out, and there is still 5k to my next servicing. Thought this water top up can last easily for 10K interval. Unless there is an leak somewhere??? When the water in the radiator heats up it expands. The extra water gets transferred to the expansion tank. When the water cools, it contracts and water from the expansion tank gets suck back into the radiator. So actually radiator water dont really need to top up that often. For mine, I do it once a year. So for your case there is definitely a leak. Better get a mech to check it out. Also, if you need to top up, only do it with water only and not the coolant. Improper proportion of coolant will cause the radiator to crack...and that is going to be expensive. Link to post Share on other sites More sharing options...
Kongkongwolf Clutched June 6, 2009 Share June 6, 2009 Hi, Do you guys check yr coolant & radiator water & at what km interval. I just found out that my coolant tank is totally dry out, and there is still 5k to my next servicing. Thought this water top up can last easily for 10K interval. Unless there is an leak somewhere??? Which part did u take a peek? The radiator or de the reservoir? If reservoir wah, ur coolant system leaking somewhere or cap not tighten? Link to post Share on other sites More sharing options...
Yuan 6th Gear June 6, 2009 Share June 6, 2009 Hi, Do you guys check yr coolant & radiator water & at what km interval. I just found out that my coolant tank is totally dry out, and there is still 5k to my next servicing. Thought this water top up can last easily for 10K interval. Unless there is an leak somewhere??? I usually check every fortnight or a month. Sometimes at the reservoir, need to top up with little bit of water. Link to post Share on other sites More sharing options...
Chickensoup 1st Gear June 6, 2009 Share June 6, 2009 Better check where is the leak. In modern cars today you rarely need topping up. Link to post Share on other sites More sharing options...
Lihong82 Neutral Newbie June 6, 2009 Share June 6, 2009 Hi, Do you guys check yr coolant & radiator water & at what km interval. I just found out that my coolant tank is totally dry out, and there is still 5k to my next servicing. Thought this water top up can last easily for 10K interval. Unless there is an leak somewhere??? Possible ... Leaking somewhere. I experienced topping up 2X 1L of mineral water into the radiator everyday .. 3rd day i go to STpowered repair at low cost ... better go to your workshop ASAP to check Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 6, 2009 Share June 6, 2009 You can either top up with coolant or distilled water but before doing you have to check the the radiator water/coolant ratio with anti-freeze PG or EG hydrometer. A 50/50 ratio will be moswt idea for our climate. Coolant whether it's PG or EG are rust inhibitants that means it will help to prevent rust formations and will not cause radiator leak or crack. On the contrary ,lack of coolant will result in rust formation and the radiator cooling tubes will leak or burst when the pressure in the cooling system built up to cap pressure or more Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 6, 2009 Share June 6, 2009 You should be using distilled water and not mineral or public pipe water. Pipe water has cholride which will cause corossion on the metal parts. Link to post Share on other sites More sharing options...
Yuan 6th Gear June 6, 2009 Share June 6, 2009 You should be using distilled water and not mineral or public pipe water. Pipe water has cholride which will cause corossion on the metal parts. Where can we get distilled water? Oops. I have been using tap water.....Will rust be formed inside my cooling system or engine? Link to post Share on other sites More sharing options...
Maverickchua Neutral Newbie June 6, 2009 Share June 6, 2009 beri expensive to top up with distill water. I dont think it is necessary. u go petrol kiosk or workshop, they just use tap water. There is definitely a leak. Probably is the hose. Check any sign of "green" residue Link to post Share on other sites More sharing options...
Horsee Clutched June 6, 2009 Author Share June 6, 2009 Thanks for all the reply.. Will sent to WS to check for leak.. Link to post Share on other sites More sharing options...
Kb27 Supersonic June 6, 2009 Share June 6, 2009 Recently, I found the coolant overflow tank completely dry on two occasions. I checked the radiator cap and it appeared that the rubber was a little flat. I changed the cap and so far, the empty tank has not come back. Link to post Share on other sites More sharing options...
Evilernie 4th Gear June 6, 2009 Share June 6, 2009 If not mistaken most mechanic will simple use tap water to top up with radiator. Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 7, 2009 Share June 7, 2009 They will also use them for your battery. Link to post Share on other sites More sharing options...
Lihong82 Neutral Newbie June 7, 2009 Share June 7, 2009 You can either top up with coolant or distilled water but before doing you have to check the the radiator water/coolant ratio with anti-freeze PG or EG hydrometer. A 50/50 ratio will be moswt idea for our climate. Coolant whether it's PG or EG are rust inhibitants that means it will help to prevent rust formations and will not cause radiator leak or crack. On the contrary ,lack of coolant will result in rust formation and the radiator cooling tubes will leak or burst when the pressure in the cooling system built up to cap pressure or more whaha ya true ... that time i just go to nearest petrol kiosk to buy any water thats available but only mineral water at the shelf ... but mineral water still better then tap water Link to post Share on other sites More sharing options...
Lihong82 Neutral Newbie June 7, 2009 Share June 7, 2009 Where can we get distilled water? Oops. I have been using tap water.....Will rust be formed inside my cooling system or engine? most of the petrol kiosk .... But all the wkshop using tap water till now ... its perfectly fine one .... cars using tap water 120,000km still havent change the radiator ah !!! Ultimately is your choice ... Do or pay within your means Link to post Share on other sites More sharing options...
Picanto 3rd Gear June 7, 2009 Share June 7, 2009 Thanks for all the reply.. Will sent to WS to check for leak.. shell is selling premixed coolant, pink color one. i am using it. whenever coolant is low, just top up with the pink coolant. dun need to get distilled water and worry about the correct mix etc........ Link to post Share on other sites More sharing options...
Freifeit Neutral Newbie June 7, 2009 Share June 7, 2009 u can get distilled water from hypermarts.. get those packed in 5.5L bottle. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
Radiator Cap
Radiator Cap
