Ken_leong 2nd Gear April 26, 2009 Share April 26, 2009 Anyone knows? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
S4vtec 3rd Gear April 26, 2009 Share April 26, 2009 5 x 114.3 Link to post Share on other sites More sharing options...
TiC Neutral Newbie April 28, 2009 Share April 28, 2009 same as the old stream 114.3 x 5PCD Link to post Share on other sites More sharing options...
Osiris 1st Gear April 28, 2009 Share April 28, 2009 if u intend to change rims, for stream need to consider the offset which is +55. many change to +40ish rims and when full load kenna tyres on the wheel well unless u roll fender personally, gave up looking for correct offset rims. sticking to stock Link to post Share on other sites More sharing options...
Gizmo Clutched April 28, 2009 Share April 28, 2009 Offset of rims +55mm is much prefered. But the market of rims of this offset is rare. If available ,not be the design that suits you Link to post Share on other sites More sharing options...
Blueegg Clutched April 28, 2009 Share April 28, 2009 Yeah, have seen too many Streams with aftermarket rims protruding from the wheel well. Makes them look like 4x4s. LoL. Link to post Share on other sites More sharing options...
Jdm77 Neutral Newbie April 30, 2009 Share April 30, 2009 offset more than 45 is ok Link to post Share on other sites More sharing options...
Sbtyong 1st Gear May 4, 2009 Share May 4, 2009 Yeah, have seen too many Streams with aftermarket rims protruding from the wheel well. Makes them look like 4x4s. LoL. May I ask What is offset? What is +40? +45? +50? Does it mean that the smaller the number the more protruding the rim? Then what is the correct offset for flash look in stream? cheers Link to post Share on other sites More sharing options...
KennyJoseph Neutral Newbie December 18, 2009 Share December 18, 2009 Sbtyong, Know that this may come a little too late but if you are still wondering about offset; and for the benefit of pple who chance upon this forum wanting to know about offset, this website offers quite a comprehensive read-up on wheel offset- Wheel offset - Car Bibles Link to post Share on other sites More sharing options...
Shanhz 3rd Gear August 3, 2011 Share August 3, 2011 if u intend to change rims, for stream need to consider the offset which is +55. many change to +40ish rims and when full load kenna tyres on the wheel well unless u roll fender personally, gave up looking for correct offset rims. sticking to stock anyone know what is the stock RSZ rims offset? Link to post Share on other sites More sharing options...
Dldm Neutral Newbie August 4, 2011 Share August 4, 2011 Enkei got 1 model http://www.efxsoft.com/sgtyres/tr1.asp?vie...5&rimdia=02 Very rare for 55 on offset Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged August 5, 2011 Share August 5, 2011 My offset +38 also never rub fender Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 5, 2011 Share August 5, 2011 (edited) SOME SAID must be rare offset 55 and some said offset 35 also no rub so which is the recommended one? the brother said 35 no rub one can please share your full size what diameter like 15 inch to 19 inch? your tyre size? once the diameter changed the offset will vary too. Edited August 5, 2011 by Roberttan Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 5, 2011 Share August 5, 2011 when you lowered the car with coilover and on full load, confirm offset 35 will rub until dont want to rub. off set of 35 is way off. There is good reason when engineer placed a 55mm there in the 1st place. Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged August 5, 2011 Share August 5, 2011 SOME SAID must be rare offset 55 and some said offset 35 also no rub so which is the recommended one? the brother said 35 no rub one can please share your full size what diameter like 15 inch to 19 inch? your tyre size? once the diameter changed the offset will vary too. Use this as a gauge: http://rimsntires.com/specs.jsp Anyway, I am driving the old model so cannot say Link to post Share on other sites More sharing options...
Chillipadi 1st Gear October 14, 2011 Share October 14, 2011 (edited) Can I ask how wide can the tyres go for the original RSZ 17" rims? Size is 17 X 6JJ and stock tyres are 205/55R17. Can fit 215/45R17 tyres? Edited October 14, 2011 by Chillipadi Link to post Share on other sites More sharing options...
Beregond Supersonic October 14, 2011 Share October 14, 2011 Can I ask how wide can the tyres go for the original RSZ 17" rims? Size is 17 X 6JJ and stock tyres are 205/55R17. Can fit 215/45R17 tyres? if u wanna put 215 width tyre, use 215.50.17 better. 6' wide rim put 205 more accurate, but your orginal size, i think very rare. hard to find any tyre shop to keep stock, if u not urgent, why not ask your shop order the exact size for u ? Link to post Share on other sites More sharing options...
Chillipadi 1st Gear October 14, 2011 Share October 14, 2011 I'm not on a stream but getting RSZ rims. My stock is 205/55R16. So go up to 17" for my ride should be 215/45R17 if I didn't calculate wrongly. Coz just wondering if the 17 X 6JJ can fit the width of 215. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery for Honda Vezel
Takata airbag recall
