Information on Car Battery
Steven
Well for voltage shld be at least 12.5v and the CCA at least above 300 depending on the vehicle itself..For a NS60 battery u will have problem starting if its below 300.
Wonder if there is one that monitors voltage and CCA at realtime [:)]?
Regards,
actually i think battery very hard to tell how is the life left. i've had those water type of battery last me 3 years but some of the dry cells only last around 2 years. i always take care never crank with aircon or radio on and no heavy ICE system in my car.
My stock dry cell battery lasted 40K. It is difficult to tell hence the need for a digital monitor to at least give some tell-tale sign of battery depleting. I frequent MY so I don't want a case of battery failed and I can't restart my car in ulu places [laugh]. I also have a TPMS to tell me the tyre pressure and temperature at real-time. I feel safer with them when traveling on NSH too.
Regards,
The most reliable and time test method of testing lead acid flood battery is to check the battery diluted sulphric acid with a hydrometer. Many professional batterymen sometime still have to re-comfirm the battery health status with this simple hydrometer even after testing with a high class professional CCA or high discharge tester.
The most simple and most reliable method is to bring a long a fully charged spare battery in yr car.
Plus. 4 spare tyre or may be just tow a spare car along [swe [:p] atdrop]
Ok, me bad [smash]:ph34r:
Back to the question, any expert out there care to share the basic construction of the battery?
My dry cell battery's indicator shown healthy state but still failed. So visual check may not always be reliable too.
Regards,
my new amaron MF battery doesn't comes with that indicator window anymore .
A friend of mine used to bring along a spare battery in his SUV. I'm not sure whether he is still doing it till today. He also keeps a box of barang barang (tools), another box of detailing kits and a small pile in his car. Very well prepared [thumbsup]. Not my cup of tea though.
Regards,
Probably cut down on manufacturing cost plus they knew it will not be accurate anyway [laugh]. How much did you pay for your battery, what is the voltage?
Regards,
Given that the title of this thread is highly relevant to my question, pardon me if you can and hopefully you can give me an answer.
Given two identical powerplants of which one has been engineered to put out greater torque at crank, does it means that the battery has to do more work to produce the necessary cranking power to start the engine?
me driving an old 90+ civic..nowadays start car got some slowness n some times cannot start car immed if i stop after driving for quite a while..need wait awhile before can restart..signs of battery dying soon? think its dry type of batt..any idea how much will it costs to replace it?
I can get for you amaron or volta 45AH battery for $90/- C&C with 1 yr warranty....
