Windwaver Turbocharged April 11, 2009 Share April 11, 2009 Normally when we wax our car, some of the wax may end up on the plastic part of the car and it'll leave a white wax stain that you cannot clean away with water. I thought I saw a product that can get rid of the wax stuck on the plastic mount but I can't recall. The wax on the plastic mount will disappear after wiping with water but will come back after the watrer dries . Just want to know if anybody has any idea how to remove the wax? ↡ Advertisement Link to post Share on other sites More sharing options...
Imamiah Clutched April 11, 2009 Share April 11, 2009 I used to remove wax from my sideview mirror using hot water and cloth. u can try :) Link to post Share on other sites More sharing options...
Maddriver 4th Gear April 11, 2009 Share April 11, 2009 A wax erazer will do the job... Erase waxing mistakes instantly! Duragloss Wax Eraser is formulated to easily remove wax and polish residue from textured and smooth surfaces. Duragloss WE erases the white, chalky residue and leaves the textured surface like new. Duragloss Wax Eraser undoes one of the most common detailing problems: white chalky stains on black trim. Many waxes and most polishes do leave some kind of white residue that easily wipes off paint, but is virtually impossible to remove from plastic and rubber. There are a dozen home remedies out there but all you need is Duragloss Wax Eraser. Duragloss Wax Eraser dissolves errant wax and polish on smooth and textured surfaces. A gentle solvent eliminates the chalky stain without harming rubber or plastic. These surfaces will look like new. This is not a cover-up product! Duragloss Wax Eraser literally erases white wax stains and they won Link to post Share on other sites More sharing options...
Windwaver Turbocharged April 12, 2009 Author Share April 12, 2009 I used to remove wax from my sideview mirror using hot water and cloth. u can try :) Yeah, my side mirror kena wax , will try your method Link to post Share on other sites More sharing options...
Windwaver Turbocharged April 12, 2009 Author Share April 12, 2009 This Duragloss Wax Eraser looks good, will check it out too Link to post Share on other sites More sharing options...
Maddriver 4th Gear April 12, 2009 Share April 12, 2009 This Duragloss Wax Eraser looks good, will check it out too As long a wax eraser will do it... Link to post Share on other sites More sharing options...
Dunno Neutral Newbie April 12, 2009 Share April 12, 2009 Use lighter to burn it off Link to post Share on other sites More sharing options...
Windwaver Turbocharged April 13, 2009 Author Share April 13, 2009 Use lighter to burn it off I probably wouldn't try this Link to post Share on other sites More sharing options...
Circuit Clutched April 13, 2009 Share April 13, 2009 use leather cleaner. can remove stains on leather and plastic.. not those tissue wipes... i using armour leather cleaner... works... Link to post Share on other sites More sharing options...
Four4s 1st Gear April 13, 2009 Share April 13, 2009 (edited) A simple search on the internet: http://www.detailingworld.co.uk/forum/showthread.php?t=81192 I know "polish" is not the same as wax but some polishes do use wax as the lubricating agent... so it might work. Personally, i would definitely try window cleaner + soft toothbrush on the plastic trim first before spending on any products. Edited April 13, 2009 by Four4s Link to post Share on other sites More sharing options...
Dschia Neutral Newbie April 13, 2009 Share April 13, 2009 A simple search on the internet: http://www.detailingworld.co.uk/forum/showthread.php?t=81192 I know "polish" is not the same as wax but some polishes do use wax as the lubricating agent... so it might work. Personally, i would definitely try window cleaner + soft toothbrush on the plastic trim first before spending on any products. I use APC and AG Fast glass before, sometimes it works, sometimes don't.. May be it could be the wax stain on plastic too long and dry off leaving permanent damage. But usually for fresh stain should be no prb.. I also try to use super resin polish with a damp mutton cloth(cannot be dry) to clean before.. The cleaning properties also able to remove but don't let it dry too long(1-2min) before you wipe off or you will have new stain.. Link to post Share on other sites More sharing options...
Krismas Neutral Newbie April 14, 2009 Share April 14, 2009 errr....could you try using those rubber eraser (yes the stationary eraser). I was able to remove some residue on my rubber windscreen seal and some plastic trim with it. And if you don't mind tell me the outcome cuz I'm just wondering whether mine is just a fluke. Regards. Link to post Share on other sites More sharing options...
Invigorated Supercharged April 17, 2009 Share April 17, 2009 I've removed mine using a special foam-like sponge from japan, it's white and looks the same as our dish washing sponge but the texture is dense. It's the more ex type that retails for about $2 each. Link to post Share on other sites More sharing options...
Maddriver 4th Gear April 17, 2009 Share April 17, 2009 I've removed mine using a special foam-like sponge from japan, it's white and looks the same as our dish washing sponge but the texture is dense. It's the more ex type that retails for about $2 each. Yes..this is also works but do it carefully just in case it lighten up the trimming color texture.. Link to post Share on other sites More sharing options...
Snowbell Neutral Newbie April 17, 2009 Share April 17, 2009 where can i buy it?i don't see it. Link to post Share on other sites More sharing options...
Newage Neutral Newbie April 17, 2009 Share April 17, 2009 (edited) where can i buy it?i don't see it. daiso has it. Edited April 17, 2009 by Newage Link to post Share on other sites More sharing options...
Windwaver Turbocharged April 19, 2009 Author Share April 19, 2009 daiso has it. Will this dense foam leave scratches? Link to post Share on other sites More sharing options...
Newage Neutral Newbie April 19, 2009 Share April 19, 2009 Will this dense foam leave scratches? don't think so. u've to damp it before using. ↡ Advertisement Link to post Share on other sites More sharing options...
Iconic Tupperware warns it could go out of business
Interior wrapping
Interior wrapping
Plastic Trim Cleaner and Restorer
NTUC FairPrice’s ‘no plastic bag’ initiative to be extended to 25 stores islandwide for a year
Waste plastics for roads
Addy Lee Plastic Surgery Gone Wrong
Engine mounts the same for left- and right-hand drive?
Greta Thunberg would disapprove Singapore
