ER-3682 Twincharged November 2, 2019 Share November 2, 2019 Oh....It is Drum Brake...hmmm,maybe Monday i get another Brake Specialist Number,,,for You... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 2, 2019 Share November 2, 2019 On 11/2/2019 at 3:43 PM, Pr1nse said: Yeah guess its the same problem as mine , but from some skimming workshops i checked , they only do for rotors n not for drums. ER- 3682- gave a contact. Maybe gota check it out on monday. Expand Never heard of skimming of drum though. Most probably it’s the brake shoes I guess, too much brake dust. 1 Link to post Share on other sites More sharing options...
Pr1nse 1st Gear November 3, 2019 Share November 3, 2019 yes true, Brake shoes do leave some mlld negligible squeak , when its dusty inside but this screach is exceptionally high. Let me walk u thru the the steps I got into. 1) My first encounter , thinking of solving the problem I changed my brake shoes when in fact the ext'g was good for another 40% usage , as told by my mechanic. But my cry baby came knocking again , after 3 weeks , n to my surprise it sounded like my old shoes . 2) 2nd , when to a workshop referred to by my friend. He opened up and cleaned the drum , and did some sanding of the inner lip and the shoes. He said shd work alright and as a precautionary measure he gave me a so called excuse, that if the noise reoccur my drum would have lost its form or alignment, even after telling him I have not knocked hard on anything to have caused it. Told him to skim the drum , but said he would if I insist and advised me against it for the time being. So coming back to my story. Not long after, and yes cry baby , was starting back its tantrums. 3) Enquired some shops told me they only have skimming services for disc and not for drum.After some research , came to know that workshop avoid skimming for drums as its time consuming and tedious compare to disc. 4) Last attempt is mycarforum Gurus before I start driving without brakes:) Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 3, 2019 Share November 3, 2019 On 11/3/2019 at 9:35 AM, Pr1nse said: yes true, Brake shoes do leave some mlld negligible squeak , when its dusty inside but this screach is exceptionally high. Let me walk u thru the the steps I got into. 1) My first encounter , thinking of solving the problem I changed my brake shoes when in fact the ext'g was good for another 40% usage , as told by my mechanic. But my cry baby came knocking again , after 3 weeks , n to my surprise it sounded like my old shoes . 2) 2nd , when to a workshop referred to by my friend. He opened up and cleaned the drum , and did some sanding of the inner lip and the shoes. He said shd work alright and as a precautionary measure he gave me a so called excuse, that if the noise reoccur my drum would have lost its form or alignment, even after telling him I have not knocked hard on anything to have caused it. Told him to skim the drum , but said he would if I insist and advised me against it for the time being. So coming back to my story. Not long after, and yes cry baby , was starting back its tantrums. 3) Enquired some shops told me they only have skimming services for disc and not for drum.After some research , came to know that workshop avoid skimming for drums as its time consuming and tedious compare to disc. 4) Last attempt is mycarforum Gurus before I start driving without brakes:) Expand In this Case,just buy new Drums.it is not Expensive if you buy OEM....May i know what make is your Car.? 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 3, 2019 Share November 3, 2019 On 11/3/2019 at 9:35 AM, Pr1nse said: yes true, Brake shoes do leave some mlld negligible squeak , when its dusty inside but this screach is exceptionally high. Let me walk u thru the the steps I got into. 1) My first encounter , thinking of solving the problem I changed my brake shoes when in fact the ext'g was good for another 40% usage , as told by my mechanic. But my cry baby came knocking again , after 3 weeks , n to my surprise it sounded like my old shoes . 2) 2nd , when to a workshop referred to by my friend. He opened up and cleaned the drum , and did some sanding of the inner lip and the shoes. He said shd work alright and as a precautionary measure he gave me a so called excuse, that if the noise reoccur my drum would have lost its form or alignment, even after telling him I have not knocked hard on anything to have caused it. Told him to skim the drum , but said he would if I insist and advised me against it for the time being. So coming back to my story. Not long after, and yes cry baby , was starting back its tantrums. 3) Enquired some shops told me they only have skimming services for disc and not for drum.After some research , came to know that workshop avoid skimming for drums as its time consuming and tedious compare to disc. 4) Last attempt is mycarforum Gurus before I start driving without brakes:) Expand Original brake shoes? If not, use original and change the drum. Should be cheap and last another 10years 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 3, 2019 Share November 3, 2019 On 11/3/2019 at 10:30 AM, Mkl22 said: Original brake shoes? If not, use original and change the drum. Should be cheap and last another 10years Expand He mentioned his car left 2 years plus. i also faced the same issue. Bought original Suzuki brake shoes from Popular Motor and installed it. Cleared the brake dust too but also got the noise. The last step is really changing the drum liao. Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 3, 2019 Share November 3, 2019 2 Years can easily use 25,000Km..worth it if change Brake Drums & new Brake Shoes. 1 Link to post Share on other sites More sharing options...
Pr1nse 1st Gear November 3, 2019 Share November 3, 2019 On 11/3/2019 at 10:06 AM, ER-3682 said: In this Case,just buy new Drums.it is not Expensive if you buy OEM....May i know what make is your Car.? Expand sure bro, its toyota wish .. from the way it looks, maybe I might end up changing it .. Link to post Share on other sites More sharing options...
Pr1nse 1st Gear November 3, 2019 Share November 3, 2019 On 11/3/2019 at 1:14 PM, ER-3682 said: 2 Years can easily use 25,000Km..worth it if change Brake Drums & new Brake Shoes. Expand hmm, well Im trying to wrap my head around it .. slowly but surely Link to post Share on other sites More sharing options...
Pr1nse 1st Gear November 3, 2019 Share November 3, 2019 (edited) On 11/3/2019 at 10:49 AM, Fcw75 said: i also faced the same issue. Bought original Suzuki brake shoes from Popular Motor and installed it. Cleared the brake dust too but also got the noise. The last step is really changing the drum liao. Expand Yeah, bro im beginning to wonder if the drum was affected because of the rims. Mine from stock upsized to 17". What abt yours ? is it stock? Edited November 3, 2019 by Pr1nse Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 3, 2019 Share November 3, 2019 On 11/3/2019 at 1:58 PM, Pr1nse said: Yeah, bro im beginning to wonder if the drum was affected because of the rims. Mine from stock upsized to 17". What abt yours ? is it stock? Expand Rims never changed before. Maybe just the drum wear and tear? Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 3, 2019 Share November 3, 2019 On 11/3/2019 at 1:58 PM, Pr1nse said: Yeah, bro im beginning to wonder if the drum was affected because of the rims. Mine from stock upsized to 17". What abt yours ? is it stock? Expand Rims won't affect the Brake Drums. Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 3, 2019 Share November 3, 2019 On 11/3/2019 at 1:31 PM, Pr1nse said: sure bro, its toyota wish .. from the way it looks, maybe I might end up changing it .. Expand Toyota Wish Spare Part so cheap,why bother to Machine/Skim...? 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 4, 2019 Share November 4, 2019 (edited) On 11/3/2019 at 10:48 PM, ER-3682 said: Toyota Wish Spare Part so cheap,why bother to Machine/Skim...? Expand Yeah. Might have to pay 80% of the price of the new one if you have to skim. That’s my experience with disc. especially so with workshops who have their own disc skimming. I can’t be bothered to skim with the ridiculous labour these days. Just replace. Edited November 4, 2019 by Mkl22 1 Link to post Share on other sites More sharing options...
Pr1nse 1st Gear November 4, 2019 Share November 4, 2019 On 11/3/2019 at 10:47 PM, ER-3682 said: Rims won't affect the Brake Drums. Expand oh okies, guess I was wrong then Link to post Share on other sites More sharing options...
Pr1nse 1st Gear November 4, 2019 Share November 4, 2019 On 11/3/2019 at 10:48 PM, ER-3682 said: Toyota Wish Spare Part so cheap,why bother to Machine/Skim...? Expand Relatively yes, just thought of having a cheaper alternative if possible. Wasnt free to check it out from the stockist , maybe by this week would sort it out. Link to post Share on other sites More sharing options...
Pr1nse 1st Gear November 4, 2019 Share November 4, 2019 On 11/4/2019 at 12:05 AM, Mkl22 said: Yeah. Might have to pay 80% of the price of the new one if you have to skim. That’s my experience with disc. especially so with workshops who have their own disc skimming. I can’t be bothered to skim with the ridiculous labour these days. Just replace. Expand from a reality standpoint , well it is true . After all the reluctance from the skimming workshop , guess its the only way to go. Link to post Share on other sites More sharing options...
Pr1nse 1st Gear November 4, 2019 Share November 4, 2019 On 11/3/2019 at 3:16 PM, Fcw75 said: Rims never changed before. Maybe just the drum wear and tear? Expand okies, guess we are on the same boat. Having said that , Well last least the boat doesn't have brake drums. 🙂 ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Sound Proofing the car
Whole car sound proof
Understanding Anti-lock Braking System (ABS)
Right side speakers no sound
Metal grinding sound on civic
