Drive_carcar Clutched March 27, 2009 Share March 27, 2009 I just sent my car for it's 10K servicing a few days ago. Today I just notice that when ever I applied my brakes, there's a very high pitched screeching sound that seem to come from my rear right brakes. This happens when I'm only gently applying the brakes. Is this goning to be a costly problem? I'm thinking maybe my brake pads are worned down (how come so fast? It's still a relatively new car How much might it cost to replace the brake pads if they are worn down? ↡ Advertisement Link to post Share on other sites More sharing options...
Ev0lutionz Clutched March 27, 2009 Share March 27, 2009 Rotors may need to be changed? Or need skimming. Link to post Share on other sites More sharing options...
Drive_carcar Clutched March 27, 2009 Author Share March 27, 2009 Rotors may need to be changed? Or need skimming. Hmmm... what's skimming? Is it grinding my brake disc? If have to change rotors means very costly right? Link to post Share on other sites More sharing options...
Comnao 1st Gear March 27, 2009 Share March 27, 2009 how new is yr car ? if used for more than 30K km ... maybe bcos yr brake pads are worn out Link to post Share on other sites More sharing options...
Friendstar Supercharged March 27, 2009 Share March 27, 2009 i thought confirm under warranty? urs is a very new car leh plus its a honda. Link to post Share on other sites More sharing options...
Ev0lutionz Clutched March 27, 2009 Share March 27, 2009 Hmmm... what's skimming? Is it grinding my brake disc? If have to change rotors means very costly right? Hmm, might not be rotor problem. Cause skimming is usually done when the rotor is warped. If its warped, normally will feel some vibration. Best is head down to a workshop where they will test for you. You using stock pads given to you on the 1st day? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 27, 2009 Share March 27, 2009 I don't think your brake pad or brake disc are worn out. Only 10K, how can that be possible? Suggest you bring to a workshop and take out the rear right brake assembly to check. Maybe just dirty? Link to post Share on other sites More sharing options...
Friendstar Supercharged March 27, 2009 Share March 27, 2009 this kind of sound typically happens on rear drum brakes Link to post Share on other sites More sharing options...
Ev0lutionz Clutched March 27, 2009 Share March 27, 2009 (edited) this kind of sound typically happens on rear drum brakes Civic using drum brakes? Think its all disc. Edited March 27, 2009 by Ev0lutionz Link to post Share on other sites More sharing options...
Application9999 Clutched March 27, 2009 Share March 27, 2009 i had same issue on my hippo...took out the pad and found hair line crack on it...due to the crack..the braking force is uneven and cause the noise.....changed and now quiet as the mouse.... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear March 28, 2009 Share March 28, 2009 Bro, since your ride is so new, jus send it back to the agent for a check Your brake pad shouldn't have worn out so soon as it is only 10K Maybe the pad is dirty or whatsoever which cause the screeching sound whenever you depress the brake pedal Link to post Share on other sites More sharing options...
Lab4games 1st Gear March 29, 2009 Share March 29, 2009 Rotors may need to be changed? Or need skimming. skimming may not always work. i skimmed my rotors and after 2 days the screeching came back. i think pads dirty but don't care much liao wait until next time change pads then see how. Link to post Share on other sites More sharing options...
Babyt 4th Gear August 23, 2011 Share August 23, 2011 my new honda accord also start to have screeching sound when braking gently too. only at 5000km nia. Link to post Share on other sites More sharing options...
Amuroboy 1st Gear August 23, 2011 Share August 23, 2011 Someone pls ban the bot! Link to post Share on other sites More sharing options...
Kueijie Clutched August 23, 2011 Share August 23, 2011 Someone pls ban the bot! mass yellow card him? think that would solve the problem... but i dunno how to, cos i'm new Link to post Share on other sites More sharing options...
Greenfunk Neutral Newbie August 23, 2011 Share August 23, 2011 does honda have a screeching brakes problem? i've got a '09 civic it's got about 20k and it's beeen making this screeching sound for over a year. have been to the dealer and they said," it's like that... It's not as if you car doesnt stop." Not lying, that's what the service guy said. Link to post Share on other sites More sharing options...
Satria_neo Clutched August 24, 2011 Share August 24, 2011 Its pretty normal as brake pads get uneven wear. When you gently press on the brake, the entire brake pad do not usually come into contact with the rotor. Only one part of it will. Hence this will cause the brake pad to vibrate and cause that screeching noise. Brake pads are only secured to the caliper by clips so it will move around a little. ITs not welded or bolted on. Link to post Share on other sites More sharing options...
Satria_neo Clutched August 24, 2011 Share August 24, 2011 mass yellow card him? think that would solve the problem... but i dunno how to, cos i'm new I think only mods can do that. But it won't exactly help cause these people can create one account after another. ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Whining sound : Lift off accelerator
Understanding Anti-lock Braking System (ABS)
Right side speakers no sound
Metal grinding sound on civic
Light clattering clicking sound when accelerating
