Bobnah Neutral Newbie March 11, 2009 Share March 11, 2009 Hi guys, Did anyone encounter this problem? Recently, during reversing, the shaft rotate make some obvious noise. Half turn also have this problem, shouldn't be tire rub against something. Moving forward no such problem. Can any expert tell me the problem? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Try_conti 2nd Gear March 11, 2009 Share March 11, 2009 get ur ride hoist up & check the CV boot ..... Link to post Share on other sites More sharing options...
Try_conti 2nd Gear March 11, 2009 Share March 11, 2009 if ur ride is under warranty, why not bring it back to the AD workshop for them to check ? Link to post Share on other sites More sharing options...
Bobnah Neutral Newbie March 12, 2009 Author Share March 12, 2009 What do you suspect? Link to post Share on other sites More sharing options...
Bobnah Neutral Newbie March 12, 2009 Author Share March 12, 2009 if ur ride is under warranty, why not bring it back to the AD workshop for them to check ? Warranty over. If nothing serious, i wait for routine servicing then ask the workshop guy to check. Link to post Share on other sites More sharing options...
Fisheye Neutral Newbie March 12, 2009 Share March 12, 2009 look at both your front wheel well. If there are obvious oil stains all along the wheel well, most probably you've got a torn CV rubber boot. This covers your driveshaft. If you need to change it, its about $150 at Elite AD would probably charge you additional $70 on top of the $150. This is preety common for VAG cars... Link to post Share on other sites More sharing options...
Bobnah Neutral Newbie March 13, 2009 Author Share March 13, 2009 Thanks. If this is the problem , need to attend immediately or can hold till next servicing? Link to post Share on other sites More sharing options...
Try_conti 2nd Gear March 13, 2009 Share March 13, 2009 if this is 'THE' problem, not advisable to hold. The cv boot is cheap compared to the cv joint if that goes ..... Link to post Share on other sites More sharing options...
Fisheye Neutral Newbie March 15, 2009 Share March 15, 2009 Yup, Agree with bro conti, change it soon. if not the whole driveshaft needs to be replaced. ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Car fails to reverse out of HDB car park lot after 12 tries
[Spyshots] 2023 4th Generation Skoda Superb
Honda civic FD4 gearbox issue
Skoda Octavia RS launched in Singapore at $199,900!
