Nikolaiski Neutral Newbie March 3, 2009 Share March 3, 2009 The TPC system facilitates tire replacement for GM customers on GM vehicles, meeting the same critical performance specifications of GM vehicle original equipment tires. Tire Size and Construction Tire Type: Identifies vehicle type. P denotes passenger vehicle*; LT denotes Light Truck. Tire Width: Measured in millimetres. E.g. 215 Aspect Ratio: The ratio of the height of the tire's cross-section to its width. E.g. 65 Construction: R denotes radial, whereas B indicates a bias construction. Wheel Diameter: The greatest distance across the wheel from tread to tread, measured in inches. E.g. 15 * May also include pickup trucks and SUVs. Load Index and Load Capacity Load Index: The maximum load in pounds (lb.) that the tire can support when properly inflated based on the Load Index Chart. E.g. 89 Load Index Pounds Kilograms 75 853 387 76 882 400 77 908 412 78 937 425 79 963 437 80 992 450 81 1019 462 82 1047 475 83 1074 487 84 1102 500 85 1135 515 86 1168 530 87 1201 545 88 1235 560 89 1279 580 90 1323 600 91 1356 615 92 1389 630 93 1433 650 94 1477 670 95 1521 690 96 1565 710 97 1609 730 98 1653 750 99 1709 775 100 1764 800 101 1819 825 102 1874 850 103 1929 875 104 1984 900 105 2039 925 Load Capacity: The maximum load in actual pounds (lb.) and kilograms (kg) that the tire can support. E.g. 1300 lbs. or 580 kg Speed Rating Speed Rating: Indicates the maximum service speed for the tire based in the speed-rating chart. E.g. " H " indicates a maximum tolerable speed of 210 km/h (130 mph). Rating Symbol Maximum Speed (km/h) Q 160 S 180 T 190 U 200 H 210 V 240 * ZR W 270 Y 300 Over 300 Uniform Tire Quality Grade (UTQG) Labelling UTQG stands for Uniform Tire Quality Grading. Developed by the US Department of Transportation (DOT), all tires sold in Canada feature this identification number moulded into the sidewall of the tire. Treadwear Treadwear Grade: A comparative rating (E.g. 220) based on the wear rate of the tire when tested under controlled conditions by the manufacturer on a specified government test track. E.g. a tire with a 200 treadwear rating would wear twice as long as a tire with a 100 rating. More than 100: Better 100: Baseline Less than 100: Poorer Tread wear grades are only valid when comparing tires from the same manufacturer! Traction and Temperature Traction Grades: : Identify the tire's ability to stop on wet pavement measured under controlled conditions by the manufacturer on specified government test surfaces of asphalt and concrete. The test is based upon "straight ahead" braking tests. E.g. Traction A AA: Very Best A: Best B: Intermediate C: Acceptable Temperature Grades: Denote the tire's resistance to the generation of heat when tested under controlled conditions by the manufacturer on a specified indoor laboratory test wheel. Excessive temperatures can lead to tire failure. E.g. Temperature A A: Best B: Intermediate C: Acceptable Tire Identification Number All tires sold in Canada feature a Tire Identification Number, which provides retailers with information about when and where the tire was produced. Example: B3 : Indicates the manufacturer and plant code CD : Tire size code E52X : Optional 2602 : Week and year of manufacture (in this example the 26th week of 2002) The maple leaf symbol indicates this is a Canadian made tire and certifies that it meets all of Transport Canada's requirements. All Season and Winter Tire Markings M+S (Mud + Snow): Indicates this is an all-season tire. Every all-season tire must carry this symbol. For more on all-season tires, click here . Four Seasons Ico Indicates this is an all-season tire. Sometimes used in conjunction with or instead of the M+S symbol. For more on all-season tires, click here . Winter Symbol: Indicates that this tire has been specifically designed for severe winter conditions. For more on winter tires, click here . When you buy new tires, fill in and return your tire registration form. In the event of a recall, the manufacturer will contact you. In many cases, you can register online. ↡ Advertisement Link to post Share on other sites More sharing options...
Conned Clutched March 4, 2009 Share March 4, 2009 well done! This should make STICKY! Link to post Share on other sites More sharing options...
Sbc55 Neutral Newbie March 7, 2009 Share March 7, 2009 Thanks for the info. Link to post Share on other sites More sharing options...
Lo70ly81 Neutral Newbie December 11, 2009 Share December 11, 2009 sorry as I am new and I cannot post new topic. I have a question. I want to transfer the car but the buyer do not want to re-loan, they will take over the giro and thought of doing private agreement. How do I legalized it? Link to post Share on other sites More sharing options...
DMC Neutral Newbie December 11, 2009 Share December 11, 2009 sorry as I am new and I cannot post new topic. I have a question. I want to transfer the car but the buyer do not want to re-loan, they will take over the giro and thought of doing private agreement. How do I legalized it? never do that. For whatever happens, you are still the owner. So you may still face all the shits even though you have black and white. For eg, Bank go after the owner only (that's you). It will be your own problem to go after the so-called buyer that take over your car. You engage lawyer against that fella will also take time. Worst still, if he MIA, good luck to you.. just my 2cents. Link to post Share on other sites More sharing options...
RidZ Neutral Newbie December 22, 2009 Share December 22, 2009 not worth takin the rixk braderrr Link to post Share on other sites More sharing options...
Asdfghjkl Neutral Newbie December 25, 2009 Share December 25, 2009 I was told that we should avoid tyres with manufacturer date of more than 2 years old. Is this true ? Link to post Share on other sites More sharing options...
Sky61 1st Gear December 25, 2009 Share December 25, 2009 old tyres will be harden over time,even if the thread is still unused. when the compound is harden,the grip capabilities are compromised..go for fresh tyres Link to post Share on other sites More sharing options...
Ghostami 2nd Gear December 25, 2009 Share December 25, 2009 I was told that we should avoid tyres with manufacturer date of more than 2 years old. Is this true ? I wouldn't get tyres that are older than a year. Most tyre shop would not take in any stock of >1 year as well. Link to post Share on other sites More sharing options...
John1123 Neutral Newbie December 30, 2009 Share December 30, 2009 Hello Nikolaiski, You have made it very clear. I recently bought a car (Maruti Swift). I was looking for some stuff like this. Thanks. Link to post Share on other sites More sharing options...
Chiangauto Clutched December 31, 2009 Share December 31, 2009 Thanks for your info.really useful. Link to post Share on other sites More sharing options...
Fishnchip Neutral Newbie December 31, 2009 Share December 31, 2009 Thanks , now i know liao !!! ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre puncture
Tyre puncture
Tourador Tyres
Tourador Tyres
Replacing a 2yrs old tyre?
