Furrynadz 5th Gear March 2, 2009 Share March 2, 2009 cheating by weighing the vehicles to get traction :p ↡ Advertisement Link to post Share on other sites More sharing options...
Kyojin 1st Gear March 2, 2009 Share March 2, 2009 (edited) definitely a R50. very fun to drive. 850Nm of torque from 2000rpm with killer brakes. don't mess... 0-100 is 6.9 seconds. but in day-to-day reality, you should be looking at the 0-80 which is 4.7 seconds - less than 1 second slower than the M3 or C63! Edited March 2, 2009 by Kyojin Link to post Share on other sites More sharing options...
Leepee 1st Gear March 3, 2009 Share March 3, 2009 In singapore context....good acceleration will only win you traffic light races. But on an empty KJE road....the real test of man and machine is where it matters! High speed driving is where the guts of the car owner is tested. Most cars on the road are considered good for 180km/hr....but is the driver gutsy enough to drive at that speed? I will drive a motorcycle if I want to experience 0-100km/hr under 5 seconds! Link to post Share on other sites More sharing options...
Astrid 4th Gear March 3, 2009 Share March 3, 2009 touareg not that expensive lah. A large-capacity diesel engined car in SG is not cheap. With taxes and all, it should cost you at least 4-5 times more than a petrol engine of the same size. But diesel is cheaper than petrol, by the gallon though. Link to post Share on other sites More sharing options...
Paddie 3rd Gear March 3, 2009 Share March 3, 2009 Actually I think quite a few proper 4x4s may be able to tug a 747. Just that noone bothered to film it and sell the car that way. Don't they have people in China and India pulling stuff like 747s and freight trains with their teeth and ears? Link to post Share on other sites More sharing options...
Terence_oh Neutral Newbie March 3, 2009 Share March 3, 2009 definitely a R50. very fun to drive. 850Nm of torque from 2000rpm with killer brakes. don't mess... 0-100 is 6.9 seconds. but in day-to-day reality, you should be looking at the 0-80 which is 4.7 seconds - less than 1 second slower than the M3 or C63! High torque on a big, heavy HIGH vehicle is great if you only need to travel at high speeds in a straight line. Go through a couple of tight turns and see what happens. Link to post Share on other sites More sharing options...
Ferraricalifornia 1st Gear March 3, 2009 Share March 3, 2009 the R50 tows the 747 so slowly, like it's not moving...the tractors in the airport tow faster...more efficient... VW touareg interior quite small and the quality use is quite cheap...hence the rather low sticker price...i think the R50 going at $298,000 last time i checked... Link to post Share on other sites More sharing options...
Drunkclubber Neutral Newbie March 3, 2009 Share March 3, 2009 High torque on a big, heavy HIGH vehicle is great if you only need to travel at high speeds in a straight line. Go through a couple of tight turns and see what happens. Bro different car for different road , why dun u get a million dollars ferrari and drive on desert . you Link to post Share on other sites More sharing options...
Mustank Hypersonic March 3, 2009 Share March 3, 2009 diesel 5l tourage's torque is simply how i wish i can get one of this and fit it inside mustank the only problem is that vw's engine is those euro 4 direct injection much much more efficient than my old euro3 indirect injection mercs engine problem is i cant use those oem pumps anymore i defintely cannot afford a tourage i think they should make the tourage bigger and more rugged like GM's yukon xl series Link to post Share on other sites More sharing options...
Kyojin 1st Gear March 3, 2009 Share March 3, 2009 High torque on a big, heavy HIGH vehicle is great if you only need to travel at high speeds in a straight line. Go through a couple of tight turns and see what happens. i think you've got it mixed up. for a big, heavy vehicle, what you need is high torque to pull you from standstill. it's what you need when you go through a couple of tight turns: slow in, fast out. horsepower is what you need to travel at high speeds. as a diesel vehicle, the R50 isn't great at higher speeds because it lacks the horsepower. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 3, 2009 Share March 3, 2009 R50, my dream car. The pulling power is awesome. Road tax plus special tax is a killer though. Match with Yamaha V-max to ride on wkends....damn! Link to post Share on other sites More sharing options...
Tohto Hypersonic March 3, 2009 Share March 3, 2009 Look at the torque spec. Volkswagen Touareg R50 5.0 (A) specifications Engine Engine capacity 4,921 cc Engine type V10 Compression ratio unknown Bore x Stroke (81.0 x 95.5) mm Power 350 bhp Torque 850 Nm Performance Acceleration 6.8s (0-100kmh) Top Speed 235kmh Fuel consumption 8.4 km\L Misc technical data Transmission 6-speed automatic Drive type 4WD Measurements Dimensions (L x W x H) (4754 x 1977 x 1778)mm Wheelbase 2,855mm Min turning radius 5,600mm Kerb weight 2,602kg Fuel tank capacity 100L Brakes Brakes (Front) Ventilated disc Brakes (Rear) Ventilated disc Suspension Suspension (Front) unknown Suspension (Rear) unknown Link to post Share on other sites More sharing options...
Z750 Neutral Newbie March 3, 2009 Share March 3, 2009 R50, my dream car. The pulling power is awesome. Road tax plus special tax is a killer though. Match with Yamaha V-max to ride on wkends....damn! should match with Triumph Rocket III Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 3, 2009 Share March 3, 2009 should match with Triumph Rocket III Triumph never appeal to me, reminds me of bra. V-max for me but unfortunately can't afford. Machine price is $40K! Ok, let's get back to Touareg topic. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic March 3, 2009 Share March 3, 2009 It's 850nm at 2000rpm. That's the scary part. Wow, fuel tank 100L. Petrol station sure like. Link to post Share on other sites More sharing options...
Dwoon 1st Gear March 3, 2009 Share March 3, 2009 (edited) Hitting 850Nm at 2K rpm is one thing..... but can that torque be maintained throughout its rev band or it just tapers away quickly after that??? If so, then can you imagine when cruising along at say 150km/h and say a sudden pickup is required for overtaking..... I wonder how would be the pull then? Without looking at the torque & power graph, its difficult to tell if its really that good in acceleration when at higher speeds. But for 0-100 in 6.8 secs, that's pretty fast..... not really very fast category. It's 850nm at 2000rpm. That's the scary part. Wow, fuel tank 100L. Petrol station sure like. Edited March 3, 2009 by Dwoon Link to post Share on other sites More sharing options...
Dwoon 1st Gear March 3, 2009 Share March 3, 2009 Errr.... 0-100 in 6.9 sec. but 0 -80 in 4.7 sec. So for the additional 20km/h takes 2 secs??? definitely a R50. very fun to drive. 850Nm of torque from 2000rpm with killer brakes. don't mess... 0-100 is 6.9 seconds. but in day-to-day reality, you should be looking at the 0-80 which is 4.7 seconds - less than 1 second slower than the M3 or C63! Link to post Share on other sites More sharing options...
Kyojin 1st Gear March 3, 2009 Share March 3, 2009 Errr.... 0-100 in 6.9 sec. but 0 -80 in 4.7 sec. So for the additional 20km/h takes 2 secs??? yes. it's a diesel engine. that's why i say you have to look at the 0-80. and in real life, that's the speed you'll hit on normal roads. ↡ Advertisement Link to post Share on other sites More sharing options...
Chechnya bans dance music that is too fast or slow
The Singapore divide accdg to this!
Speeding In Singapore [CNA Talking Point]
Engine water dry up fast?
Fast & Furious star Paul Walker dies in car crash/F&F7
VW reveals the new 2019 Touareg
Motor vehicles travel too Fast on SG Roads
Driving fast on the German Autobahn
