Sturtles 6th Gear March 2, 2009 Share March 2, 2009 Hi Guys, my primary 6 cousin showed me a math question of his over the weekend, and because I'd flunk it everytime, I wasn't able to help him It goes like this. A grass field can feed 200 sheeps for 100 days. 150 sheeps for 150 days. Assuming the grass grows at a constant amount daily, how many days can it feed 100 sheeps. ↡ Advertisement Link to post Share on other sites More sharing options...
Newbie_driver Neutral Newbie March 2, 2009 Share March 2, 2009 Hi Guys, my primary 6 cousin showed me a math question of his over the weekend, and because I'd flunk it everytime, I wasn't able to help him It goes like this. A grass field can feed 200 sheeps for 100 days. 150 sheeps for 150 days. Assuming the grass grows at a constant amount daily, how many days can it feed 100 sheeps. is it 200 days assuming that the no. of days increased proportionally to the amount of reduction of sheeps. Link to post Share on other sites More sharing options...
Triple2onroad Neutral Newbie March 2, 2009 Share March 2, 2009 Hi Guys, my primary 6 cousin showed me a math question of his over the weekend, and because I'd flunk it everytime, I wasn't able to help him It goes like this. A grass field can feed 200 sheeps for 100 days. 150 sheeps for 150 days. Assuming the grass grows at a constant amount daily, how many days can it feed 100 sheeps. Can feed for 300 days. Initial grass field can feed 15000 sheep-days Growth rate is 50 per day Link to post Share on other sites More sharing options...
Sturtles 6th Gear March 2, 2009 Author Share March 2, 2009 That's what I thought, but the answer is 300. The key point is that the grass grows Link to post Share on other sites More sharing options...
Sturtles 6th Gear March 2, 2009 Author Share March 2, 2009 Can feed for 300 days. Initial grass field can feed 15000 sheep-days Growth rate is 50 per day Wow. how did you get the growth rate and sheep days? Link to post Share on other sites More sharing options...
Newbie_driver Neutral Newbie March 2, 2009 Share March 2, 2009 Can feed for 300 days. Initial grass field can feed 15000 sheep-days Growth rate is 50 per day hmm... can explain it mathematically.... sound so chim... Link to post Share on other sites More sharing options...
Triple2onroad Neutral Newbie March 2, 2009 Share March 2, 2009 Wow. how did you get the growth rate and sheep days? Using constant gradient equation: Initial + (-number of sheeps + Growth rate) * number of days = 0 Plug in the two given conditions and you will get them. Link to post Share on other sites More sharing options...
Kusje Supersonic March 2, 2009 Share March 2, 2009 Do a simultaneous equation. Link to post Share on other sites More sharing options...
Grx80 Neutral Newbie March 2, 2009 Share March 2, 2009 Let X=initial amount of grass, Y=daily grass growth rate. X + 100Y = 200 * 100 -> Equation 1 X + 150Y = 150 * 150 -> Equation 2 Solving above equations give X = 15000, Y = 50 If there's 100 sheeps which can be fed in Z days, => X + Y*Z = 100 * Z (X = 15000, Y = 50) => Z=300 days Link to post Share on other sites More sharing options...
Fkadir Neutral Newbie March 2, 2009 Share March 2, 2009 This is a primary 6 question? WOW! I think I used to do this kinda math in Sec 4. Goes to show how old I am! Link to post Share on other sites More sharing options...
Newbie_driver Neutral Newbie March 2, 2009 Share March 2, 2009 Let X=initial amount of grass, Y=daily grass growth rate. X + 100Y = 200 * 100 -> Equation 1 X + 150Y = 150 * 150 -> Equation 2 Solving above equations give X = 15000, Y = 50 If there's 100 sheeps which can be fed in Z days, => X + Y*Z = 100 * Z (X = 15000, Y = 50) => Z=300 days guess nowadays the standard has improved and my math skill has ..... Link to post Share on other sites More sharing options...
Josho 1st Gear March 2, 2009 Share March 2, 2009 OMGGGGGGGGGG Primary 6 using equation? OMGGGGGGGGGG That's a no no for me.. im a D7 Math student... can never pass... Link to post Share on other sites More sharing options...
David Clutched March 2, 2009 Share March 2, 2009 No wonders the primary students are interesting. Link to post Share on other sites More sharing options...
Parkingidiot 1st Gear March 2, 2009 Share March 2, 2009 Let X=initial amount of grass, Y=daily grass growth rate. X + 100Y = 200 * 100 -> Equation 1 X + 150Y = 150 * 150 -> Equation 2 Solving above equations give X = 15000, Y = 50 If there's 100 sheeps which can be fed in Z days, => X + Y*Z = 100 * Z (X = 15000, Y = 50) => Z=300 days This is a good solution. But this is using algebra, rite? If I remember correctly, in Pri school they do not want us to use algebra to solve the problems. Is there another way to solve this kind of problem without using algebra? ie. i remember my kid used to do sums drawing little bars and things to represent the sheep and the number of days to feed. Something similar in concept to the simultaneous equations above, but yet manage to solve without bring X, Y and Z to represent the unknown numbers as in algebra. Link to post Share on other sites More sharing options...
Tjkbeluga 5th Gear March 2, 2009 Share March 2, 2009 This is a good solution. But this is using algebra, rite? If I remember correctly, in Pri school they do not want us to use algebra to solve the problems. Is there another way to solve this kind of problem without using algebra? ie. i remember my kid used to do sums drawing little bars and things to represent the sheep and the number of days to feed. Something similar in concept to the simultaneous equations above, but yet manage to solve without bring X, Y and Z to represent the unknown numbers as in algebra. OKlah, if you insist, initial growth rate plus daily grass growth rate multiply by hundred is equal to two hundred multiply by one hundred initial growth rate plus daily grass growth rate multiply by hundred fifty is equal to hundred fifty multiply by hundred fifty Link to post Share on other sites More sharing options...
Route88 2nd Gear March 2, 2009 Share March 2, 2009 Let X=initial amount of grass, Y=daily grass growth rate. X + 100Y = 200 * 100 -> Equation 1 X + 150Y = 150 * 150 -> Equation 2 Solving above equations give X = 15000, Y = 50 If there's 100 sheeps which can be fed in Z days, => X + Y*Z = 100 * Z (X = 15000, Y = 50) => Z=300 days P6 uses tis equation? Link to post Share on other sites More sharing options...
Grx80 Neutral Newbie March 2, 2009 Share March 2, 2009 alamak..... you all ai pee ai qi you ai dua liap nee... Link to post Share on other sites More sharing options...
Leepee 1st Gear March 2, 2009 Share March 2, 2009 (edited) The X original amount of grass....How come did not factor in the Y growth rate as well? All living grass will grow at Y rate right? But the equation did not factor in the existing grass growth rate!!! It seems that the assumption was made that existing grass will not grow anymore? (Which I think is totally wrong as it goes against nature!) Meaning as the grass grows longer, the sheeps will still eat it as a unit and not as a proportion to its hunger level! (In simple terms, a long grass or short grass will still be considered as a single unit of grass to satisfy hunger!) I think using grass is a POOR formulation of this questions as the growth rate is a complex thing to fanthom. I think I still like the old skool questions, example 5 painters need 10 days to paint a house, how many day 2 painter use to paint the same house type of question! Damm....I am in NUS and yet I still cannot derive the formula to calculate this 'easy' math!!! Edited March 2, 2009 by Leepee ↡ Advertisement Link to post Share on other sites More sharing options...
Straits Times - Devastated after being rejected by three schools for DSA: How to help your child cope
More Copycat: India school logo same as S’pore Sports School logo, principal says nothing to discuss
Neighbourhood or Elite Primary School
Own up, do you surf pornhub? 🤔
Stay of execution for Drug trafficker due to Covid!
Math Question
Math Question
HUMAN RIGHTS is bulls**t in the war against drugs.
Reco for home tutors (Pri sch)
