Davekiat Clutched August 13, 2010 Share August 13, 2010 I sent my used car for evaluation before I bought my second hand vios. I found that the report was not detailed enough although they have chassis alignment tests conducted, engine, gearbox checks but I do not know how extensive these tests were. They did put a remark mentioning "Minor repair job on the rear of the car". After getting my car, I sent it to my mechanic for checks and found it was actually a rear bumper repair job. STA will try to report it in a nice way rather than the specifics. ↡ Advertisement Link to post Share on other sites More sharing options...
Busybody 1st Gear August 13, 2010 Share August 13, 2010 i also having this problem Got a used car in mind, but do not know where to bring for evaluation. Anyone got advise for me ? Test Drive the car, if it feels right, ask the dealer to send it in for you. You would most likely have agreed upon a price and the Dealer will ask you for a downpayment Put in down in the agreement that If <=Grade C, dealer pays for the eval fee., refunds you the downpayment in full and you walk away paying nothing. If Grade A or B, you pay for the eval fee, and will have to accept the car. Link to post Share on other sites More sharing options...
Busybody 1st Gear August 13, 2010 Share August 13, 2010 Thanks for the info, Btw is it grade B means that vehicle have been involved accident before ? Any idea? No, i believe older cars will automatically get grade B due to wear and tear of parts. Link to post Share on other sites More sharing options...
Auntyoink Neutral Newbie August 16, 2010 Share August 16, 2010 Hi all, i am a first-time car buyer so pardon me if the question sounds silly. Which inspection centre is better in yr experience? STA or Vicom? And do u know if the folks there can help check if the car is a "flood" vehicle? Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 16, 2010 Share August 16, 2010 You will be surprise that there are simple and very important tests that used car evaluation centres , I understand are just doing visual or don't conduct test at all a) Engine compression and mandifold vaccum test b) Cooling system pressure & coolant test c) Brake fluid moisture test d) Battery high discharge test e) Alternator output amp volt load test f)Power steering hydraulic power output test Correct me I maybe out of date Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear August 16, 2010 Share August 16, 2010 You will be surprise that there are simple and very important tests that used car evaluation centres , I understand are just doing visual or don't conduct test at all a) Engine compression and mandifold vaccum test b) Cooling system pressure & coolant test c) Brake fluid moisture test d) Battery high discharge test e) Alternator output amp volt load test f)Power steering hydraulic power output test Correct me I maybe out of date I believe those are for academics who never know what it is about. Articles written after 'test-drive' no mention of braking distances? No mention of lateral acceleration? No mention of cruising speed? No mentione of noise level within car cabin? Link to post Share on other sites More sharing options...
Voodooman Supersonic August 16, 2010 Share August 16, 2010 http://www.aas.com.sg/data/Services/VAS/Car.pdf I only trust AA since I swore off new car. It is however difficult to convince dealers to allow an AA inspection. Dealers will usually ask you to use STA or Viacom instead, just insist on it and be prepared to walk away. Link to post Share on other sites More sharing options...
Auntyoink Neutral Newbie August 16, 2010 Share August 16, 2010 I tried to search on AA's website but didn't see any car evaluation. Must u be a member to get the car evaluated? Link to post Share on other sites More sharing options...
Voodooman Supersonic August 17, 2010 Share August 17, 2010 I tried to search on AA's website but didn't see any car evaluation. Must u be a member to get the car evaluated? Here you go... http://www.aas.com.sg/index.php?show=conte...w=8&val=210 No, you do not need to be a member to have access to the service but you pay slightly more. Link to post Share on other sites More sharing options...
Picanto 3rd Gear August 17, 2010 Share August 17, 2010 You will be surprise that there are simple and very important tests that used car evaluation centres , I understand are just doing visual or don't conduct test at all a) Engine compression and mandifold vaccum test b) Cooling system pressure & coolant test c) Brake fluid moisture test d) Battery high discharge test e) Alternator output amp volt load test f)Power steering hydraulic power output test Correct me I maybe out of date then which are the centres that skip these tests? Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 17, 2010 Share August 17, 2010 Not even one centre do such tests Link to post Share on other sites More sharing options...
Picanto 3rd Gear August 17, 2010 Share August 17, 2010 Not even one centre do such tests perhaps its not cost economical for the centres Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 17, 2010 Share August 17, 2010 No idea as I am not sure how they run the centres Link to post Share on other sites More sharing options...
Mm63 1st Gear August 17, 2010 Share August 17, 2010 Take all evaluation reports with a pinch of salt. Nowadays, workshops can repair seriously damaged cars to such a extent that the evaluation centres cannot really detect. I wanted to buy a car and it was rated B by a evaluation centre that shall remain unnamed. Later I found out from reliable sources that the car was a serious accident before where even the airbags were deployed. I re-checked the car myself and saw the tell-tale signs personally e.g dashboard and steering wheel looks new compared to the rest of the interior etc etc. Managed to back out of the deal and forfeited 10% of my deposit. It was a close call but learnt quite a bit from the experience. Car dealers like to go their preferred evaluation centre because they bring so many cars there to check and may have formed "personal" relationships with the staff there. Serious damage may then be reported as "minor repair work at the front"........ I have heard that from a car dealer that car dealers really hate sending their cars to AA for evaluation because the mechanics there are very strict and fussy and will be blunt and upfront about what they see. I have never sent any cars to AA for evaluation so don't just take my word for it Link to post Share on other sites More sharing options...
Mkl22 Supersonic August 17, 2010 Share August 17, 2010 Take all evaluation reports with a pinch of salt. Nowadays, workshops can repair seriously damaged cars to such a extent that the evaluation centres cannot really detect. I wanted to buy a car and it was rated B by a evaluation centre that shall remain unnamed. Later I found out from reliable sources that the car was a serious accident before where even the airbags were deployed. I re-checked the car myself and saw the tell-tale signs personally e.g dashboard and steering wheel looks new compared to the rest of the interior etc etc. Managed to back out of the deal and forfeited 10% of my deposit. It was a close call but learnt quite a bit from the experience. Car dealers like to go their preferred evaluation centre because they bring so many cars there to check and may have formed "personal" relationships with the staff there. Serious damage may then be reported as "minor repair work at the front"........ I have heard that from a car dealer that car dealers really hate sending their cars to AA for evaluation because the mechanics there are very strict and fussy and will be blunt and upfront about what they see. I have never sent any cars to AA for evaluation so don't just take my word for it yup agree with you. All the evaluation are b-------t. and lots of under table money. never trust them. heck even the yearly inspections got heavily modified cars passing, what more such evaluation which are no subjected to any laws. Link to post Share on other sites More sharing options...
Shadla Neutral Newbie August 17, 2010 Share August 17, 2010 a relible workshop Link to post Share on other sites More sharing options...
Picanto 3rd Gear August 17, 2010 Share August 17, 2010 yup agree with you. All the evaluation are b-------t. and lots of under table money. never trust them. heck even the yearly inspections got heavily modified cars passing, what more such evaluation which are no subjected to any laws. its time the govt do some audits of these centres ↡ Advertisement Link to post Share on other sites More sharing options...
Used Car, what STA Inspection grade then can buy?
Used car dealers tampering odometer readings
Get a new car plate number for used car
Recommend lawyer to take dealer to court for mileage / odometer tampering?
Selling Car through CARRO
Top 5 questions to ask every used car dealer
Home-stay for holiday instead of Hotel? (AIRBNB)
