Sgnick 1st Gear February 14, 2009 Share February 14, 2009 (edited) I am currently using 205/45 R16 tyres Thinking of changing to 195/50 R16 tyres. Question is, do I need to change my rims? Or can rims support different width tyres, 195 and 205 also can use? Reason why i dont change to 205/50 instead is because if I use 205/50, the tyre will scrap something when I do a full steering turn I cannot be certain but I think my rim size is 16x7 Edited February 14, 2009 by Sgnick ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 14, 2009 Share February 14, 2009 wat is ur stock size in e 1st pl??? Link to post Share on other sites More sharing options...
Kusje Supersonic February 14, 2009 Share February 14, 2009 Hijacking this thread! I'm driving a Lancer EX (sports version) and its time to change my tires and I have no clue what to do. I don't know anything about tire width, size, etc. Can someone link me to a post or article about it? Link to post Share on other sites More sharing options...
Twofouronenite 1st Gear February 14, 2009 Share February 14, 2009 I am currently using 205/45 R16 tyres Thinking of changing to 195/50 R16 tyres. Question is, do I need to change my rims? Or can rims support different width tyres, 195 and 205 also can use? Reason why i dont change to 205/50 instead is because if I use 205/50, the tyre will scrap something when I do a full steering turn I cannot be certain but I think my rim size is 16x7 No need to change. But why down size? Link to post Share on other sites More sharing options...
Akula Turbocharged February 14, 2009 Share February 14, 2009 205/45R16, correct size to downgrade to is 185/50R16. so 195/50R16 size out already. Also 7 inch wide rims is TOO wide for 195mm tires. For 195mm tires should be 6 or 6.5inch. Link to post Share on other sites More sharing options...
Mits_jc 5th Gear February 14, 2009 Share February 14, 2009 Have a read: http://en.wikipedia.org/wiki/Tire_code Link to post Share on other sites More sharing options...
Sgnick 1st Gear February 14, 2009 Author Share February 14, 2009 wat is ur stock size in e 1st pl??? Stock is 175/70R14 14 Link to post Share on other sites More sharing options...
Sgnick 1st Gear February 14, 2009 Author Share February 14, 2009 No need to change. But why down size? I want higher profile tyre. Link to post Share on other sites More sharing options...
Sgnick 1st Gear February 14, 2009 Author Share February 14, 2009 205/45R16, correct size to downgrade to is 185/50R16. so 195/50R16 size out already. Also 7 inch wide rims is TOO wide for 195mm tires. For 195mm tires should be 6 or 6.5inch. I see, so I need to change rims too :( Link to post Share on other sites More sharing options...
Twofouronenite 1st Gear February 14, 2009 Share February 14, 2009 I want higher profile tyre. ?? Tot most would want lower. I think 45 ratio is good at least in term of looks. Too hard ride? Link to post Share on other sites More sharing options...
Sgnick 1st Gear February 14, 2009 Author Share February 14, 2009 Have a read: http://en.wikipedia.org/wiki/Tire_code Good link about tyres about is not relevant to my question which is about rim width relating to tyre width Thanks anyway Link to post Share on other sites More sharing options...
Sgnick 1st Gear February 14, 2009 Author Share February 14, 2009 ?? Tot most would want lower. I think 45 ratio is good at least in term of looks. Too hard ride? Looks unbalanced on my car. Yes, too hard also. Link to post Share on other sites More sharing options...
Hub_n_mona 1st Gear February 14, 2009 Share February 14, 2009 Hijacking this thread! I'm driving a Lancer EX (sports version) and its time to change my tires and I have no clue what to do. I don't know anything about tire width, size, etc. Can someone link me to a post or article about it? Try this: http://www.carbibles.com/ Link to post Share on other sites More sharing options...
Akula Turbocharged February 14, 2009 Share February 14, 2009 As a general guide, the width of the rim should be btn 75%-90% of the tire. Will have to take the width of rim, express in "JJ" (inches) convert to millimeters and divided by the width of tire. Link to post Share on other sites More sharing options...
Sgnick 1st Gear February 15, 2009 Author Share February 15, 2009 As a general guide, the width of the rim should be btn 75%-90% of the tire. Will have to take the width of rim, express in "JJ" (inches) convert to millimeters and divided by the width of tire. Thanks man, just the answer I am seeking Link to post Share on other sites More sharing options...
Kb27 Supersonic February 15, 2009 Share February 15, 2009 (edited) I am currently using 205/45 R16 tyres Thinking of changing to 195/50 R16 tyres. Question is, do I need to change my rims? Or can rims support different width tyres, 195 and 205 also can use? Reason why i dont change to 205/50 instead is because if I use 205/50, the tyre will scrap something when I do a full steering turn I cannot be certain but I think my rim size is 16x7 I've used 7" width rims (two different types) on 195 without problems. First, an Enkei 15x7" on a Hankook RS2, then Advanti 15x7" on a Falken ZE912. 7" width minimum is prolly 195. In fact, I was thinking of going down to 185. But I think it might not fit properly. Edited February 15, 2009 by Kb27 Link to post Share on other sites More sharing options...
Sgnick 1st Gear February 15, 2009 Author Share February 15, 2009 I've used 7" width rims (two different types) on 195 without problems. First, an Enkei 15x7" on a Hankook RS2, then Advanti 15x7" on a Falken ZE912. 7" width minimum is prolly 195. In fact, I was thinking of going down to 185. But I think it might not fit properly. Hmm, ok, thanks. Then i go ask the tyre shop people. Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 15, 2009 Share February 15, 2009 while e width of taya plays a impt part, its actually e series profile tat is more impt tat decides wat width of rim to be use. ↡ Advertisement Link to post Share on other sites More sharing options...
Continental closing Alor Setar plant
Minimum Post Limit Before New Thread Creation
Portable Tyre Pump
Portable Tyre Pump
Tyre puncture
Tyre puncture
