Hishercar Clutched February 5, 2009 Share February 5, 2009 It is also more fuel efficient to move the car forward when the engine is cold than to reverse. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> It has been said that a car parked head first in a lot between two vehicles, with its front wheels turned completely, is harder to steal. But in fact, a car with a steering and pedal lock is even harder to steal. ↡ Advertisement Link to post Share on other sites More sharing options...
Chickensoup 1st Gear February 5, 2009 Share February 5, 2009 Yes, if your car is FWD, forward movement is more efficient. Reverse means you car become RWD style. But only reverse out of parking lot the difference is too minimal to mention. If FC is what you at aiming at, insignificant. Link to post Share on other sites More sharing options...
Hishercar Clutched February 5, 2009 Author Share February 5, 2009 Spark plugs that are slow to dissipate heat are described as hot while those that are quick to do so are called cold plugs. A hot plug has a longer insulator nose, which exposes more surface area to the combustion gases. This is to ensure the temperature at the insulator nose stays sufficiently high to burn off carbon and oil deposits. A cold plug is the opposite. The shorter insulator nose minimises exposure to combustion gases for faster transfer of heat to the cylinder to minimise the chances of overheating and premature failure. Start with spark plugs recommended by the car manufacturer. After a few days, remove the plug and examine the insulator tip. If you see a grey, chalky deposit, the plug is suitable for the engine.If the tip is sooty, you will need a hotter plug. If it is white, switch to a colder plug. When switching from a hotter to colder plug or vice versa, move up or down the heat range scale gradually (one unit at a time) and check its suitability with the steps above. ↡ Advertisement Link to post Share on other sites More sharing options...
Attention all Duragloss #951 Aquawax user.
U can no longer user your parts for RiverView Auto
Your North-South highway survival guide(user-posted sharing)
SPC $2 voucher to give away / Amex card user only
GT Radial CHAMPIRO UHP1 - user come in
Inspiring Words of Wisdom
Rent a end user car
Rent a end user car
Any User Reviews on Groomers Lab?
