Turbonetics 2nd Gear January 12, 2009 Share January 12, 2009 Hi,i just bought a short shifter and will be DIYing it myself. we know that short shifter helps reduce the throw of the gear distance between each gear. my new shifter is actually about 2 cm longer than my stock one but the throw distance is about 20% shorter. but then,i have the urge to cut it shorter by about 3-3.5cm which is shorter than my stock ones. therefore before i make my final decision,i would like to hear your views. thanks for reading. ↡ Advertisement Link to post Share on other sites More sharing options...
Qr25vet Clutched January 12, 2009 Share January 12, 2009 you cut short...then how u gonna screw in the knob? i thought short shifters can also allow you to adjust the throw? its not abt how short the gearstick is also ma...is the length of travel... anyways y yr CVR only boost 1 bar? Life for turbo starts @ 2 bar and above Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 13, 2009 Author Share January 13, 2009 On 1/12/2009 at 4:47 PM, Qr25vet said: you cut short...then how u gonna screw in the knob? i thought short shifters can also allow you to adjust the throw? its not abt how short the gearstick is also ma...is the length of travel... anyways y yr CVR only boost 1 bar? Life for turbo starts @ 2 bar and above other than using screw,there are other methods to fix the gearknob also. i thought the shorter the stick,the short the length of travel?or is it same? Link to post Share on other sites More sharing options...
Maroon5 5th Gear January 13, 2009 Share January 13, 2009 On 1/12/2009 at 3:33 PM, Turbonetics said: Hi,i just bought a short shifter and will be DIYing it myself. we know that short shifter helps reduce the throw of the gear distance between each gear. my new shifter is actually about 2 cm longer than my stock one but the throw distance is about 20% shorter. but then,i have the urge to cut it shorter by about 3-3.5cm which is shorter than my stock ones. therefore before i make my final decision,i would like to hear your views. thanks for reading. same for mine...my short shifter throw shorter but height similar to stock....have tried to cut too but cant find wkshops to do it...made worse by the fact that mine is the damn heavy solid iron....i decided to jus leave it.. Link to post Share on other sites More sharing options...
Kenmical Clutched January 16, 2009 Share January 16, 2009 On 1/12/2009 at 3:33 PM, Turbonetics said: Hi,i just bought a short shifter and will be DIYing it myself. we know that short shifter helps reduce the throw of the gear distance between each gear. my new shifter is actually about 2 cm longer than my stock one but the throw distance is about 20% shorter. but then,i have the urge to cut it shorter by about 3-3.5cm which is shorter than my stock ones. therefore before i make my final decision,i would like to hear your views. thanks for reading. Bro...as i said before it is good to have longer gear stick. I still stick to this theory. Don't cut it...I use to have a short one but regreted cos the reach is terrible and tend to misshift. Link to post Share on other sites More sharing options...
Kenmical Clutched January 16, 2009 Share January 16, 2009 On 1/12/2009 at 4:47 PM, Qr25vet said: you cut short...then how u gonna screw in the knob? i thought short shifters can also allow you to adjust the throw? its not abt how short the gearstick is also ma...is the length of travel... anyways y yr CVR only boost 1 bar? Life for turbo starts @ 2 bar and above I agree with u totally. 2 bars provided it is a Evo or Rex...CVR onli so better dun be so greedy. Btw i onli 1.17 bar nia...hehehe Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 17, 2009 Author Share January 17, 2009 (edited) On 1/16/2009 at 1:29 PM, Kenmical said: Bro...as i said before it is good to have longer gear stick. I still stick to this theory. Don't cut it...I use to have a short one but regreted cos the reach is terrible and tend to misshift. my previous ride has got a shorter shifter,so iam actually more used to short ones. anyway,i won't be cutting it already. just give a try on a longer shifter,maybe i will have a change of mind.haha. iam now still figuring out how to remove my stock shifter. very tricky job. Edited January 17, 2009 by Turbonetics Link to post Share on other sites More sharing options...
Kenmical Clutched January 18, 2009 Share January 18, 2009 Now that your pivot point of the shifter is shorter by 20%...u will also reduce some time when reaching for the stick cos it is longer and nearer to steering. ↡ Advertisement Link to post Share on other sites More sharing options...
Vietnam - HCMC short visit
6 Mods That Are A Waste Of Money For A Daily Driver
Consolidation of useless modification (Performance parts)
Wheelchair needed for Short term
Paddle shifters - fixed to wheel or column?
If you buy a COE Car and have $3K to spare. . .
Malaysia allows rear windows tinting as dark as they want!
Do You Mod Your car?
