Onslaught Neutral Newbie January 9, 2009 Share January 9, 2009 any bros heard of royal purple engine oil? how's the performance? thks! ↡ Advertisement Link to post Share on other sites More sharing options...
Civic6656 1st Gear January 9, 2009 Share January 9, 2009 On 1/9/2009 at 3:15 AM, Onslaught said: any bros heard of royal purple engine oil? how's the performance? thks! Was told that this oil can last for 7kkm only. Dunno true or not. Link to post Share on other sites More sharing options...
Onslaught Neutral Newbie January 9, 2009 Author Share January 9, 2009 On 1/9/2009 at 4:28 AM, Civic6656 said: Was told that this oil can last for 7kkm only. Dunno true or not. my friend recommended to me...i'm sending my RS FIT 4 5k servicing @ comfort delgro Link to post Share on other sites More sharing options...
Civic6656 1st Gear January 9, 2009 Share January 9, 2009 On 1/9/2009 at 4:45 AM, Onslaught said: my friend recommended to me...i'm sending my RS FIT 4 5k servicing @ comfort delgro SHC forum many using RP oil. I prefer OWS. Link to post Share on other sites More sharing options...
Chevycavy 1st Gear January 9, 2009 Share January 9, 2009 On 1/9/2009 at 4:28 AM, Civic6656 said: Was told that this oil can last for 7kkm only. Dunno true or not. I believe so. I tried to extend my usual OCI from 5k to 7.5k but the engine starts to feel rough ard 6-7k. Link to post Share on other sites More sharing options...
Onslaught Neutral Newbie January 9, 2009 Author Share January 9, 2009 that means this oil can't last to 10k, rite? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear January 9, 2009 Share January 9, 2009 its only a group iii, sure will rough after 5-6k Link to post Share on other sites More sharing options...
Robo 2nd Gear January 9, 2009 Share January 9, 2009 heard its not as good as RL. now on amsoil, power loss rl but smoothness is there. Link to post Share on other sites More sharing options...
Application9999 Clutched January 9, 2009 Share January 9, 2009 On 1/9/2009 at 6:03 AM, Furrynadz said: its only a group iii, sure will rough after 5-6k Add some royal jelly inside...or KY jelly...for lub Link to post Share on other sites More sharing options...
Blackyv Turbocharged January 9, 2009 Share January 9, 2009 On 1/9/2009 at 5:56 AM, Onslaught said: that means this oil can't last to 10k, rite? there's no one fix rule or guideline saying it cant last 10K or can ...simply put, depends on your driving style and engine made..... .. but general rule is if u red line frequently, it may not last 10K but if u drive normally, i dont see why not it last 10K or more... i use Rp before my current M1 and still have 4 bottles of rp at home.... not considering what happen to the oil properties after 10k since i do not have any equipment to test on how bad or how good the oil degraded, all i can say is comparing to M1, my engine noise is coarse and lesser "power" comparing with current M1 (extended) ... if u ask me, will i use it again, i would say i might not after use up my current stock but if price is cheap, i will... Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear January 9, 2009 Share January 9, 2009 Its a normal oil....if you not too demanding...its ok. Cheap. But I dun like it....I bought 12Q last time...cos group buy....after the first 3k km...I sold all off them....the engine was damn rough....and it doesn't like to be rev high... But I believe its the cheapest synthetic oil avaliable in the market now. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear January 9, 2009 Share January 9, 2009 On 1/9/2009 at 6:16 AM, Blackyv said: there's no one fix rule or guideline saying it cant last 10K or can ...simply put, depends on your driving style and engine made..... .. but general rule is if u red line frequently, it may not last 10K but if u drive normally, i dont see why not it last 10K or more... i use Rp before my current M1 and still have 4 bottles of rp at home.... not considering what happen to the oil properties after 10k since i do not have any equipment to test on how bad or how good the oil degraded, all i can say is comparing to M1, my engine noise is coarse and lesser "power" comparing with current M1 (extended) ... if u ask me, will i use it again, i would say i might not after use up my current stock but if price is cheap, i will... mine last for 1k...drained and change brand! Link to post Share on other sites More sharing options...
Robo 2nd Gear January 9, 2009 Share January 9, 2009 On 1/9/2009 at 6:28 AM, Ghostrider said: Its a normal oil....if you not too demanding...its ok. Cheap. But I dun like it....I bought 12Q last time...cos group buy....after the first 3k km...I sold all off them....the engine was damn rough....and it doesn't like to be rev high... But I believe its the cheapest synthetic oil avaliable in the market now. den u should try RL. super rev happy! good! Link to post Share on other sites More sharing options...
Onslaught Neutral Newbie January 9, 2009 Author Share January 9, 2009 seems like more cons than pros...might give it a miss. bcoz i'll driving all the way from s'pore to kedah for CNY, so itz better to have a better engine oil. scarly drive half away engine up lorry may can consider idemitsu...specially for honda ivtec engine Link to post Share on other sites More sharing options...
Onslaught Neutral Newbie January 9, 2009 Author Share January 9, 2009 On 1/9/2009 at 6:30 AM, Robo said: den u should try RL. super rev happy! good! bro how much does it cost for 4L Link to post Share on other sites More sharing options...
Onslaught Neutral Newbie January 9, 2009 Author Share January 9, 2009 On 1/9/2009 at 6:30 AM, Roadhogger said: mine last for 1k...drained and change brand! wow...so jialuk meh? Link to post Share on other sites More sharing options...
Robo 2nd Gear January 9, 2009 Share January 9, 2009 (edited) per quartz for RL is around $17.50. trust me its worth the $$$! Edited January 9, 2009 by Robo Link to post Share on other sites More sharing options...
Onslaught Neutral Newbie January 9, 2009 Author Share January 9, 2009 On 1/9/2009 at 6:16 AM, Blackyv said: there's no one fix rule or guideline saying it cant last 10K or can ...simply put, depends on your driving style and engine made..... .. but general rule is if u red line frequently, it may not last 10K but if u drive normally, i dont see why not it last 10K or more... i use Rp before my current M1 and still have 4 bottles of rp at home.... not considering what happen to the oil properties after 10k since i do not have any equipment to test on how bad or how good the oil degraded, all i can say is comparing to M1, my engine noise is coarse and lesser "power" comparing with current M1 (extended) ... if u ask me, will i use it again, i would say i might not after use up my current stock but if price is cheap, i will... not that kind of rough driver...usually drive @ 70km/h @ normal street, highway 80~90km/h... any problems created by this oil? ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
