Pentrain Clutched January 2, 2009 Share January 2, 2009 hi all.. need some help here..i have been noticing that my rear left passenger mat gets damp after i drive thru rain..and the damp is in between the carpet and the mat..hence it cannot be rain or water that soak thru from the top of the carpet... any idea if the water can enter from underneath the car?? my car is still under warranty..was thinking of sending back to AD to check..haiz.. hope u guys understand my problem ↡ Advertisement Link to post Share on other sites More sharing options...
Yeshe Turbocharged January 2, 2009 Share January 2, 2009 hi all.. need some help here..i have been noticing that my rear left passenger mat gets damp after i drive thru rain..and the damp is in between the carpet and the mat..hence it cannot be rain or water that soak thru from the top of the carpet... any idea if the water can enter from underneath the car?? my car is still under warranty..was thinking of sending back to AD to check..haiz.. hope u guys understand my problem should be from beneath the car, go send it for a check. which make/model btw? Link to post Share on other sites More sharing options...
Mkl22 Supersonic January 2, 2009 Share January 2, 2009 water has to come in from the door seals or the door card. no way will it come from underneath. its just gravity. get someone to hose the car and spot the leak Link to post Share on other sites More sharing options...
Twofouronenite 1st Gear January 2, 2009 Share January 2, 2009 hi all.. need some help here..i have been noticing that my rear left passenger mat gets damp after i drive thru rain..and the damp is in between the carpet and the mat..hence it cannot be rain or water that soak thru from the top of the carpet... any idea if the water can enter from underneath the car?? my car is still under warranty..was thinking of sending back to AD to check..haiz.. hope u guys understand my problem Put tissue paper between door frame and close door. Spray with water using water hose. Wipe dry and open door to check. See if tissue paper wet. Link to post Share on other sites More sharing options...
Watwheels Supersonic January 2, 2009 Share January 2, 2009 (edited) I ever read from megane forum that their cars got this problem. Believe it or not the problem lies with the windscreen which is not properly sealed. Yours is rear passenger so it could be door seal. Did you check your window for that side is fully closed? Edited January 2, 2009 by Watwheels Link to post Share on other sites More sharing options...
Xefera 6th Gear January 2, 2009 Share January 2, 2009 (edited) *deleted* Edited January 2, 2009 by Xefera Link to post Share on other sites More sharing options...
Pentrain Clutched January 2, 2009 Author Share January 2, 2009 hi..mine is a hyundai getz 1.4A.. erm..actually i tried splashing water at my rear left passenger door..but the water is not able to get on to the mat..only the door panel..or i shld splash more...haha.. i splash with 2 pails directly at the door.. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear January 2, 2009 Share January 2, 2009 hi all.. need some help here..i have been noticing that my rear left passenger mat gets damp after i drive thru rain..and the damp is in between the carpet and the mat..hence it cannot be rain or water that soak thru from the top of the carpet... any idea if the water can enter from underneath the car?? my car is still under warranty..was thinking of sending back to AD to check..haiz.. hope u guys understand my problem What brand and model? My old Vios got this problem. The taillight is the problem. Link to post Share on other sites More sharing options...
Pentrain Clutched January 2, 2009 Author Share January 2, 2009 hmm i went back to AD to fix my reverse sensor once..and not sure if that may cause anything to be not fitted properly when they are fixing the reverse sensor... and also there was once when the AD cleared my air con but using those spray that they leave behind the rear passenger left seat..i dunno wad is that called..but since then on..it has been getting wet..not sure if this is the cause but it shld not be.. Link to post Share on other sites More sharing options...
Pentrain Clutched January 2, 2009 Author Share January 2, 2009 What brand and model? My old Vios got this problem. The taillight is the problem. hi bro..hyundai getz Link to post Share on other sites More sharing options...
Xefera 6th Gear January 2, 2009 Share January 2, 2009 hmm i went back to AD to fix my reverse sensor once..and not sure if that may cause anything to be not fitted properly when they are fixing the reverse sensor... and also there was once when the AD cleared my air con but using those spray that they leave behind the rear passenger left seat..i dunno wad is that called..but since then on..it has been getting wet..not sure if this is the cause but it shld not be.. i would suggest pursuing with the AD since they have operated on that spot before. Link to post Share on other sites More sharing options...
Pentrain Clutched January 2, 2009 Author Share January 2, 2009 (edited) I ever read from megane forum that their cars got this problem. Believe it or not the problem lies with the windscreen which is not properly sealed. Yours is rear passenger so it could be door seal. Did you check your window for that side is fully closed? yes bro..window fully closed..got window visor somemore..haha..haiz..think send it down to AD one of these days.. Edited January 2, 2009 by Pentrain Link to post Share on other sites More sharing options...
Pentrain Clutched January 2, 2009 Author Share January 2, 2009 What brand and model? My old Vios got this problem. The taillight is the problem. bro did u get it fixed and how..wads wrong with the tailight that cos the prob? Link to post Share on other sites More sharing options...
Desimone Neutral Newbie January 22, 2009 Share January 22, 2009 Send to ur ride to agent to check. I used to have this on my new car and was told that the so called "glue" seal on the chassic joint part not well glued, thus result in water slipping in. Mine is rear right passenger door. floor map wet too. 2 days down. Link to post Share on other sites More sharing options...
Alechi 2nd Gear January 22, 2009 Share January 22, 2009 agree .. all water that seeped in through doors will end up between mat and floor Link to post Share on other sites More sharing options...
Qaz20 3rd Gear January 27, 2009 Share January 27, 2009 Hi, every compartments of the car interior like front/rear and left/right will have a drain hole underneath the carpet. The drain hole will be cover by a rubber seal which is removable. remove the carpet and you will get to see it. maybe it's not paced/plugged in properly. Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 27, 2009 Share January 27, 2009 Try to remove your left rear floor mats to expose the metal floorboard. Make sure it is completely dry. Then sprey water from underneath or drive in the rain. See if u can spot any part starting to get wet. It is unlikely a new car can have this leak. Most likely its your rubber door seal damaged, misaligined or loose. Try to spot the location & seal it with silicon sealant. I had a leak in the boot of my 18 year old Corona after being hit from behing & the ws repaired the dent but did not check for water leakage. I DIY the leak with silicon & it lasted a couple of years until I sold the car. Link to post Share on other sites More sharing options...
Comnao 1st Gear January 27, 2009 Share January 27, 2009 car got kenna langgah before ? if no, then it is most probably the rubber seals have drop out of place. jus replace a new one and you will be fine else .... start saving cash to change car ↡ Advertisement Link to post Share on other sites More sharing options...
Rear seat passenger : Do they belt up?
COVID-19: Retrenchments
Is it illegal to fetch passengers at the back of a Suzuki Every?
Renal failure on the rise
Doctor gets 10 years jail for Sexual Assault
NUS Grad becomes rubbish collector after retrenchment
