Quantum 5th Gear December 31, 2008 Author Share December 31, 2008 Sunny 1.6M 100km/h @2500 rpm also Honda city 1.5M 100km/h @30000 rpm ↡ Advertisement Link to post Share on other sites More sharing options...
Twofouronenite 1st Gear December 31, 2008 Share December 31, 2008 For FD civic, at cruising, the auto is actually more fuel efficient than the manual. You can check out the press release when it first came out. Maybe u should read from the link from KM webpage: http://www.honda.com.sg/cars/torque.pdf Link to post Share on other sites More sharing options...
Kelpie 2nd Gear December 31, 2008 Share December 31, 2008 Sunny 1.6M 100km/h @2500 rpm also Honda city 1.5M 100km/h @30000 rpm It is hig rev but without compromising fuel economy significantly. Since when did you hear Sunny is renown for its fuel economy at low rpm for 100Km/h? Regards, Link to post Share on other sites More sharing options...
Seevic Neutral Newbie December 31, 2008 Share December 31, 2008 Aiya, manual transmission at the end of the day still more FC efficient. Normal to have higher RPM for manual too. Check this: http://www.articlesbase.com/cars-articles/...red-610972.html http://www.consumerreports.org/cro/cars/ne...-vs-auto-ov.htm Golden rule: Ideal rpm for lowest FC is the lowest rpm. Link to post Share on other sites More sharing options...
Twofouronenite 1st Gear December 31, 2008 Share December 31, 2008 Golden rule: Ideal rpm for lowest FC is the lowest rpm. I think the rule should be Efficiency in Combustion. How well do u burn the fuel and air mixture, not number of RPM. Link to post Share on other sites More sharing options...
Seevic Neutral Newbie December 31, 2008 Share December 31, 2008 Golden rule: Ideal rpm for lowest FC is the lowest rpm. Btw, juz a "general" golden rule la. Of course not taking the above word for word. Since taking into consideration for different makes of vehicles, i believe there is a cut-off point in spd/rpm("sweet speed") that will yield the best FC & not necc at lowest spd or rpm. IMHO.... Link to post Share on other sites More sharing options...
Kelpie 2nd Gear December 31, 2008 Share December 31, 2008 I think the rule should be Efficiency in Combustion. How well do u burn the fuel and air mixture, not number of RPM. This is a more reasonable explanation. Engine does count. Regards, Link to post Share on other sites More sharing options...
Twofouronenite 1st Gear December 31, 2008 Share December 31, 2008 Btw, juz a "general" golden rule la. Of course not taking the above word for word. Since taking into consideration for different makes of vehicles, i believe there is a cut-off point in spd/rpm("sweet speed") that will yield the best FC & not necc at lowest spd or rpm. IMHO.... Don't get me wrong either, Of course if everything is the same(transmission, tyre, weight, density of air etc) then full agree, the golden rule is correct. Lowest RPM is better one! No doubt. That why, I under this link: http://www.honda.com.sg/cars/torque.pdf , the 1.8M is 6.6L/100Km compare to 1.8A at 6.7L/100Km. But have to note it is not just talking about crusing but mix mode which I assume will be city and hiway driving. Link to post Share on other sites More sharing options...
Quantum 5th Gear December 31, 2008 Author Share December 31, 2008 Don't get me wrong either, Of course if everything is the same(transmission, tyre, weight, density of air etc) then full agree, the golden rule is correct. Lowest RPM is better one! No doubt. That why, I under this link: http://www.honda.com.sg/cars/torque.pdf , the 1.8M is 6.6L/100Km compare to 1.8A at 6.7L/100Km. But have to note it is not just talking about crusing but mix mode which I assume will be city and hiway driving. 1.8A top speed is 197km/h, but what is the 1.8M top speed? Link to post Share on other sites More sharing options...
Twofouronenite 1st Gear December 31, 2008 Share December 31, 2008 1.8A top speed is 197km/h, but what is the 1.8M top speed? I'm not sure on this but I don't think there is a different. Even if there is, it is not going to be much. Link to post Share on other sites More sharing options...
Nt30 Neutral Newbie January 1, 2009 Share January 1, 2009 so low mah? do you use stock tyres, how come mine is 2500rpm on 5th gear? I am on 215/45/17 AD07, I think manual gear is higher RPM, the EK 4 manual is 3000rpm@90km/h on 5th gear with stock! Link to post Share on other sites More sharing options...
Passion 5th Gear January 1, 2009 Share January 1, 2009 yo bro, your explaination is wrong lah :( ... doesn't mean got power lost then RPM lower....arghh..it is due to the gear ratio. You can read up wikipedia to understand how gears work.....the power lost does not translate anything to the RPM. Power lost will be felt. (slower acceleration ) ..... Eh brother,i never say i'm correct leh.I say if not wrong.So i might be wrong leh.Of cuz i know it's gear ratio,but when going at final gear,it has lock-in clutch,thus the rpm would be lower,as it is lock to the engine speed instead of free rev,if that's what ppl call it. Link to post Share on other sites More sharing options...
Drive_carcar Clutched January 4, 2009 Share January 4, 2009 ask civic drivers, do you notice that thanks a lot Mine is about 2500 rpm leh... Link to post Share on other sites More sharing options...
Drive_carcar Clutched January 4, 2009 Share January 4, 2009 I still believe a manual will post better fc as compared to an auto at the end of the day. My MT chao chao is 13km/l... so even 2500 rpm at 100km/h, can't complain too much.. Link to post Share on other sites More sharing options...
Oscar__76 Neutral Newbie January 13, 2009 Share January 13, 2009 mine is FD4M..3000rpm at 100km/h.. i find it strange having a high RPM at 3k where my speed is only 100km/h Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 13, 2009 Share January 13, 2009 ask civic drivers, do you notice that thanks a lot i believe different FD models(1.6,1.8,2.0 and Type R) have different gear ratios. and also manual and auto trans usually are different too. Link to post Share on other sites More sharing options...
Frozebite Neutral Newbie January 13, 2009 Share January 13, 2009 For auto 110km/h should be less than 2k rpm Link to post Share on other sites More sharing options...
Marcng Neutral Newbie January 14, 2009 Share January 14, 2009 is ard 2.5k rpm ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Toyota GR Corolla
2025 Mitsuoka M55
2025 Mitsuoka M55
