Lala81 Hypersonic December 2, 2019 Share December 2, 2019 2 hours ago, Victor68 said: Even if you have a 15 gal tank installed 1.8m above your head and the pressure into the tank is only that much, say 0.5 bar, it is not going to help too. Having a booster pump definitely will increase pressure. Of course the rest of the article on the shower head,, restrictor, etc are thing you should consider when you don't have pressure. Rain shower helps too when it flow downwards instead of having to spray out. I think the main issue is that even if u use a water pressure pump, but ultimately are using a flow restricted heating device (instant heater), it's like trying to step on the accelerator while holding down the brakes at the same time. Flow rate is highly dependent on pressure yes. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic December 2, 2019 Share December 2, 2019 22 hours ago, Ysc3 said: i am staying 40 yr old flat in tampines ... (no pipe in gas also) ... water pressure is 👎 ... even when i am at top floor, right under the water tanks. 😅 Try feedback to your TC. Sometimes it helps when they replace the control valve for your water mains. Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 2, 2019 Share December 2, 2019 10 minutes ago, 13177 said: From the article then i know that staying on the most top floor, water pressure will be low? So it is not a good thing to stay too high floor. Staying low floor seems better for water pressure. I stay on 6th floor. I have a grohe overhead shower, think it's about 240mm dimension. Link to post Share on other sites More sharing options...
Ysc3 Twincharged December 2, 2019 Share December 2, 2019 1 hour ago, 13177 said: Rain shower head cannot use on low water pressure de. Lol. Yup... I paid $170 to find out... Was hoping the pump heater would help... But it was just like walking under the edge of a flat during rain. Link to post Share on other sites More sharing options...
Ysc3 Twincharged December 2, 2019 Share December 2, 2019 2 minutes ago, Watwheels said: Try feedback to your TC. Sometimes it helps when they replace the control valve for your water mains. There was a journalist here will helped me put it in the newspaper but also no use. Link to post Share on other sites More sharing options...
Playtime Twincharged December 2, 2019 Share December 2, 2019 19 minutes ago, Ysc3 said: Yup... I paid $170 to find out... Was hoping the pump heater would help... But it was just like walking under the edge of a flat during rain. Like... expecting 20 yr old shoot amount... but... receiving 50 yr old performance 😂 Link to post Share on other sites More sharing options...
13177 Hypersonic December 2, 2019 Share December 2, 2019 12 minutes ago, Ysc3 said: Yup... I paid $170 to find out... Was hoping the pump heater would help... But it was just like walking under the edge of a flat during rain. You go to this place Tuscani Tapware, they are selling special shower head for house with low water pressure problem. It does help a lot with shower head meant for low water pressure. Link to post Share on other sites More sharing options...
13177 Hypersonic December 2, 2019 Share December 2, 2019 16 minutes ago, Ysc3 said: There was a journalist here will helped me put it in the newspaper but also no use. No use de even you complain to PUB, HDB and town council. They cannot solve the problem at all cause nothing much they can do about it. 1 Link to post Share on other sites More sharing options...
Ysc3 Twincharged December 2, 2019 Share December 2, 2019 (edited) 2 hours ago, 13177 said: You go to this place Tuscani Tapware, they are selling special shower head for house with low water pressure problem. It does help a lot with shower head meant for low water pressure. I am using something like this...but different brand And no beads. I went to HoKee to ask before and since they did not have pump heaters, the guy advised me to get this type of shower head. Does help a little only. The only other way I can think of is to change the water pipes in the house to thicker diameter type. Edited December 2, 2019 by Ysc3 2 Link to post Share on other sites More sharing options...
Jman888 Moderator December 2, 2019 Share December 2, 2019 3 minutes ago, Ysc3 said: I am using something like this...but different brand. recently change to one of this korean brand one (only one spray mode), pressure is strong but spray surface is not that wide. 1 Link to post Share on other sites More sharing options...
Ysc3 Twincharged December 2, 2019 Share December 2, 2019 2 hours ago, Playtime said: Like... expecting 20 yr old shoot amount... but... receiving 50 yr old performance 😂 The water flow through the pump heater and the laser cut shower head showed so much potential... But alas with the rain shower... Link to post Share on other sites More sharing options...
Ysc3 Twincharged December 2, 2019 Share December 2, 2019 (edited) 5 minutes ago, Jman888 said: recently change to one of this korean brand one (only one spray mode), pressure is strong but spray surface is not that wide. The metal plate is very thin... Think it's not possible to cut holes with angles.... So the water shoots out straight only. I also bought a 6" laser cut shower head... But it still can only shoot straight. Edited December 2, 2019 by Ysc3 Link to post Share on other sites More sharing options...
Victor68 Turbocharged December 2, 2019 Share December 2, 2019 2 hours ago, Lala81 said: I think the main issue is that even if u use a water pressure pump, but ultimately are using a flow restricted heating device (instant heater), it's like trying to step on the accelerator while holding down the brakes at the same time. Flow rate is highly dependent on pressure yes. If your incoming flow and pressure is just that, of course the pump can 9nly achieve what juices you have. With a tank, it does draws down till it is empty. Haha. Generally, under the plumbing guide, you would be required to install transfer tank when PUB pressure cannot maintain to your development. Link to post Share on other sites More sharing options...
13177 Hypersonic December 2, 2019 Share December 2, 2019 1 hour ago, Ysc3 said: I am using something like this...but different brand And no beads. I went to HoKee to ask before and since they did not have pump heaters, the guy advised me to get this type of shower head. Does help a little only. The only other way I can think of is to change the water pipes in the house to thicker diameter type. You should go to Tuscani Tapware, think they are the only one in sg who sell shower head for low water pressure. I bought one shower head from them, water flow improved quite a bit. But their low water pressure shower head not cheap. Link to post Share on other sites More sharing options...
Ysc3 Twincharged December 2, 2019 Share December 2, 2019 3 minutes ago, 13177 said: You should go to Tuscani Tapware, think they are the only one in sg who sell shower head for low water pressure. I bought one shower head from them, water flow improved quite a bit. But their low water pressure shower head not cheap. what the shower head you bought look like ? Link to post Share on other sites More sharing options...
Victor68 Turbocharged December 2, 2019 Share December 2, 2019 Tokyu Hands got such shower heads. However the spray is like mist 1 Link to post Share on other sites More sharing options...
13177 Hypersonic December 2, 2019 Share December 2, 2019 1 hour ago, Ysc3 said: what the shower head you bought look like ? Not rain shower head. It is normal type of shower head but is meant for low water pressure de. Actually there have a few model for low water pressure, see which pattern you like. Link to post Share on other sites More sharing options...
Kklim Supercharged December 2, 2019 Share December 2, 2019 (edited) Anyone got a plumber to recommend? Need to replace storage heater. Some asked for as much as the heater! Just need to mount on wall and reconnect/extend the pipes. Edited December 2, 2019 by Kklim ↡ Advertisement Link to post Share on other sites More sharing options...
Family of three electrocuted to death at Taman Jurong
Meguiar's Water Magnet MF drying towel
