Sleepyman Clutched November 23, 2008 Share November 23, 2008 Theres a 'Gong-gong' sound when pressing my brakes. back and font... I noticed a few days ago only... Hmm my car is quite new 6 mths and 10k only?(all stock) wat do you think is wrong? ↡ Advertisement Link to post Share on other sites More sharing options...
Zcold 2nd Gear November 23, 2008 Share November 23, 2008 was it hard braking or normal braking? did u feel vibrations up yr brake pedal? Link to post Share on other sites More sharing options...
Sleepyman Clutched November 23, 2008 Author Share November 23, 2008 Hmm hard braking mostly. dun know for sure it vibrates to the pedal(will check it out later). Most noticeable when parking, everytime i brake i can hear the sound and vibrations ' like ur under rear bumper is scrapping the curb' feeling. Link to post Share on other sites More sharing options...
Sleepyman Clutched November 23, 2008 Author Share November 23, 2008 I started getting a loud clunk when I had to brake hard or when reversing then stepping on the brakes. It sounded like someone under the car was kicking the floor of my rear boot area . Does not vibrate to the pedal. Case of something wrong? Link to post Share on other sites More sharing options...
Beei 1st Gear November 23, 2008 Share November 23, 2008 (edited) Deleted Edited November 23, 2008 by Beei Link to post Share on other sites More sharing options...
Dipstick Neutral Newbie November 24, 2008 Share November 24, 2008 What's the make and model of our car? A few years ago I had a car that had the same problem. The AD couldn't fix it and the prob persisted till the day I sold it. Link to post Share on other sites More sharing options...
Hermit 1st Gear November 24, 2008 Share November 24, 2008 Possible ABS kicking in? Any gurus to comment? Link to post Share on other sites More sharing options...
Mavvy Clutched November 24, 2008 Share November 24, 2008 Hard braking kicks in ABS. Easily can find out information using search in MCF here. Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 24, 2008 Share November 24, 2008 check lower arm ball joints Link to post Share on other sites More sharing options...
Tanjkp Clutched November 24, 2008 Share November 24, 2008 Not trying to scare U. My experience on my old car found on this was the sub-frame mount screw loose that the mount moved resulting the noise during moving off / braking. Though ur car is still new, poor workmanship of screw forgotten to tighten can occur during production. One of the new car I got found with tail lamp cover chipped -- properly defect part mounted. Agent changed it after showed them. Link to post Share on other sites More sharing options...
Leecc73 Neutral Newbie November 24, 2008 Share November 24, 2008 Better check, its could be dangerous sometime. Last time i have this but its due to the brake pad all gone, and the oli leak till finished, the spring unable to retract back. Link to post Share on other sites More sharing options...
Edmund932 Neutral Newbie November 24, 2008 Share November 24, 2008 (edited) TS, hijack your thread cause I got a similar problem. I notice when I do soft braking, I hear some 'tock-tock' sound coming from the brakes. I can't make out if it is from the front or the back. Have been there for quite some time already. But strangly when i do hard braking, the sound disappears. My ride is also a stock ride. 2.5 years old. Btw, there isn't any vibrations. Just that the sound is there. Braking is normal. Any gurus know what is the likely source of this problem? Please advise.. Thanks. Edited November 24, 2008 by Edmund932 Link to post Share on other sites More sharing options...
Zcold 2nd Gear November 24, 2008 Share November 24, 2008 Hmm hard braking mostly. dun know for sure it vibrates to the pedal(will check it out later). Most noticeable when parking, everytime i brake i can hear the sound and vibrations ' like ur under rear bumper is scrapping the curb' feeling. hmmm... when ABS activate when u jam brake... the sound is "kung kung"... sounds the same... difference is i could feel vibrations thru the brake pedal (wearing thin sole slippers.. so could feel very well) not sure if its ABS activate in yr case... doesnt seems like thou... better bring to workshop for a check... esp since yr ride is new... sometimes when i park... then wanna re-adjust car... forgot that i have handbrake up... then will have this scraping 'eee' sound... shouldn't be this case in your car rite... maybe gurus here can help Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear November 24, 2008 Share November 24, 2008 Theres a 'Gong-gong' sound when pressing my brakes. back and font... I noticed a few days ago only... Hmm my car is quite new 6 mths and 10k only?(all stock) wat do you think is wrong? Brudder, look up your car manual. I encountered this when my car was less than 6mths old. A kind of "KRONG KRONG" sound when you step on the brake pedal right? It says in the manual that the car is "learning" something and doing adjustments. Link to post Share on other sites More sharing options...
Adrianli Hypersonic November 24, 2008 Share November 24, 2008 It might be the tire linkage is not bolted at all. Thus when u apply brake, the tire stop but the chassis is still in momentum. Tis was wat happen when I serviced my old COE car in a workshop. The mechanic forgot to replace the bolt after servicing the clutch, timing belt and water pump. After driving for 10km, felt the same jerking thing. Drove car back to workshop n told the boss to try the car. On round the industrial estate, he found the problem, jack up the car and replace the bolt. Braking went back to normal. Bring to a workshop to check. Link to post Share on other sites More sharing options...
Sleepyman Clutched November 24, 2008 Author Share November 24, 2008 My ride is an Impreza 1.6i. All stock. Tks all bro for the feedback. I will go to my workshop to check as still under warranty. Thing is I noticed it only a few days ago. My colleague whom i always pick up to work also asked me when i was parking and braked: " you scrapped ur bumper against the curb?" She also remembered there was no sound last time... Link to post Share on other sites More sharing options...
Hybridwalker Clutched November 14, 2017 Share November 14, 2017 Theres a 'Gong-gong' sound when pressing my brakes. back and font... I noticed a few days ago only... Hmm my car is quite new 6 mths and 10k only?(all stock) wat do you think is wrong? I have a new auto car bought last year. It also produce a gong sound when I release handbrake and then go from P to D. I think by releasing the handbrake first, the weight of the car rests on the gearbox so the gear is very 'tight' thus producing the sound. If I change P to D first, then release handbrake the sound is gone. 1 Link to post Share on other sites More sharing options...
DACH Supersonic November 14, 2017 Share November 14, 2017 You revived a 9 year old thread. ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
FORCE Big Brake Kit promotional Price
Sound Proofing the car
Whole car sound proof
Whining sound : Lift off accelerator
Right side speakers no sound
Metal grinding sound on civic
