Yuan 6th Gear December 8, 2008 Share December 8, 2008 Quote I dont know your car model etc, so how to guess? You can be sure that the price difference between a lambo and chery is a lot. If anyhow guess, I think two shocks will set you back about $500 inclusive of labour if you use ORIGINAL parts. Should be cheaper if you use OEM parts or others. From what I know, shock absorbers are vital components in your car. Just as brakes and tires are. Correct me if I am wrong. Shock absorbers do play a part in the functioning of your ride, their braking and so on so forth. Like brakes and tyres, I believe cost for a good set of shock absorbers (as long as they attain the level of performance as your original parts or even better) should not be compromised and discounted. ↡ Advertisement Link to post Share on other sites More sharing options...
Twnll 1st Gear December 8, 2008 Share December 8, 2008 Does worn shocks increase the road noise? My 100k+ 3 yr+ Honda City seems a lot noisier than I remember... Link to post Share on other sites More sharing options...
Solar Turbocharged December 8, 2008 Share December 8, 2008 Quote So far leak not detected, looks pretty dry, or maybe the shocks are gas driven and not oil driven. since we are on this topic.. can anyone share what's the difference between gas and oil driven (of course.. one is oil..) such as, lifespan (if, subjected to the same usage/condition) cost comfort? btw, is the gas one call coilover? Link to post Share on other sites More sharing options...
Kianbeng Clutched December 8, 2008 Share December 8, 2008 You are probably using different tyres? Link to post Share on other sites More sharing options...
Kianbeng Clutched December 8, 2008 Share December 8, 2008 Gas shocks are more reliable, more expensive, better damping. Link to post Share on other sites More sharing options...
Kianbeng Clutched December 8, 2008 Share December 8, 2008 I changed mine around 100,000km. It wasn't quite satisfactory after 50k but it wasn't considered as spoilt. After that I changed to new ones which was a different brand and it became quite good. Normally you don't change the springs. Your springs determines the height of the car. Your shocks determines the rock & roll, bouncing effects of the car. Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear December 8, 2008 Share December 8, 2008 Just check the dampers as follow: a. Oil leaks b. Press down and see if the car body rebound and stabilise, and not oscillate many times. If any of the above, it's time to change the dampers. Spoilt dampers are dangerous to handling. Link to post Share on other sites More sharing options...
Newbie_driver Neutral Newbie December 9, 2008 Share December 9, 2008 (edited) i just change mine @ 50K mileage last week at autosaver, cost me abt $500 for all 4... the mechanic say oil leak so $$$ Edited December 9, 2008 by Newbie_driver Link to post Share on other sites More sharing options...
Pjlee25 Neutral Newbie December 13, 2008 Share December 13, 2008 Quote No way shock absorbers can last 10 years. The springs yes. For your reference: http://www.kyb.com.my/handy.html Yup...spring can last a lifetime...shock absorbers will depend on usage. Link to post Share on other sites More sharing options...
Nkps 1st Gear December 13, 2008 Share December 13, 2008 Quote Mine rear suspension is getting softer... Wat could be the problem? feed viagra Link to post Share on other sites More sharing options...
Geogeo Neutral Newbie December 13, 2008 Share December 13, 2008 May I know what car are you driving? Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie December 13, 2008 Author Share December 13, 2008 Quote I dont know your car model etc, so how to guess? You can be sure that the price difference between a lambo and chery is a lot. If anyhow guess, I think two shocks will set you back about $500 inclusive of labour if you use ORIGINAL parts. Should be cheaper if you use OEM parts or others. From what I know, shock absorbers are vital components in your car. Just as brakes and tires are. Correct me if I am wrong. Shock absorbers do play a part in the functioning of your ride, their braking and so on so forth. Like brakes and tyres, I believe cost for a good set of shock absorbers (as long as they attain the level of performance as your original parts or even better) should not be compromised and discounted. Ya, but the shocks are still damping well, it is just the occasional creaks that disturbs me. It passes the bounce test etc. Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie December 13, 2008 Author Share December 13, 2008 Quote Does worn shocks increase the road noise? My 100k+ 3 yr+ Honda City seems a lot noisier than I remember... No, symptons of worn shocks 1) Car may be more bouncy. 2) Nose dive during hard braking 3) Oil leaks if using hydraulics 4) etc etc Link to post Share on other sites More sharing options...
Shull Turbocharged December 13, 2008 Share December 13, 2008 Quote I dont know your car model etc, so how to guess? You can be sure that the price difference between a lambo and chery is a lot. If anyhow guess, I think two shocks will set you back about $500 inclusive of labour if you use ORIGINAL parts. Should be cheaper if you use OEM parts or others. oops.. i'm driving Civic ES.. Link to post Share on other sites More sharing options...
Shull Turbocharged December 30, 2008 Share December 30, 2008 bros, i've decided to change my absorbers within the next 2-3 weeks.. any specific brand to go for? and any reliable shops to recommend? my car currently in it's 6th year..going to use til 10th yr... Link to post Share on other sites More sharing options...
Passion 5th Gear December 30, 2008 Share December 30, 2008 On 12/30/2008 at 12:03 PM, Shull said: bros, i've decided to change my absorbers within the next 2-3 weeks.. any specific brand to go for? and any reliable shops to recommend? my car currently in it's 6th year..going to use til 10th yr... Bro,i recommend you search for Autosaver.I'm no relationship to this company,just that they give you a quotation of how much it cost and you can decide whether to change at their outlet or not. Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 31, 2008 Share December 31, 2008 On 12/30/2008 at 12:03 PM, Shull said: bros, i've decided to change my absorbers within the next 2-3 weeks.. any specific brand to go for? and any reliable shops to recommend? my car currently in it's 6th year..going to use til 10th yr... ================= Most Jap cars use KYB (Kayaba) as OEM. They have gas & oil. Chin Hon at Race Course Rd has them as well as other places. I got mine from Chin Hon as their prices were best at the time I was changing. Ask for the Made In Japan shocks otherwise u might end up with those made in some other lower quality country. I got the made in Japan gas shocks & they lasted >3 years till I sold the car. Very lasting & good damping too. Now got Monroe Active or something like that. Similar to their previous Sensatrac. I tried the Sensatrac b4 but I think KYB is more suitable for my Jap car. Firm & stable ride with the KYB. Link to post Share on other sites More sharing options...
Sky_vinz Clutched December 31, 2008 Share December 31, 2008 Hi guys, I've a 11mth old Lancer GLX. Recently the squeaking sound from the rear left is getting louder. Checked, no oil leak. So I supposed is due to the bushings? If yes, anyone has idea roughly how much to replace? ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Change Disc Rotors
Change Disc Rotors
Tool to change Spark Plug
X for twitter change request
