Amp overheating?
Luv_presea
er.. i asked the installer.. if i put this basstube, need amp anot? he say need.. if not no sound.. den actually i wanted a 2ch amp just for the sub.. but then he suggested to take a 4ch de so can run the other component speakers.. so i got the 4ch de lo..
active is already got amp inside rite? and passive is need amp to power?
When the speakers got no sound, does the protection mode LED on the amp light up? You should be able to see it if the amp is under your seats. Don't know where to look for the LED? Check the manual, I also don't know where on the amp it is located. [laugh]
Edited by Dunno
Thats the problem you normally get when you buy things from all over the place. Not that it's wrong, but just that everyone takes the chance to push the blame to others.
Bridge or not bridge....is how you wire your speaker wires to your amp, which is what Eddy mentioned regarding 2ohms/4ohms thing. If you are keen and generally like technical things, you might want to do more reading online regarding this. I find it very interesting. I learnt everything from scratch.
Maybe I should change my question to "Who did the wiring from the subwoofer to your amp?". I think you need to go back to him. Maybe you can show us some pictures on your setup. If you a hands on person, maybe you can even check whats printed on the back of your speakers inside the basstube? If you're not a hands on person, I always think it's a good idea to get the installer fix it. Sometimes I feel I learn things by paying installer to do it while I watch. It's like a live demo.
ok.. checked the model no. le.. the basstube is EL804.. 4ohm de.. from what i found on the net.. and amp is Blaupunkt GTA480. 2ohm de.. anything not suitable with my current setup? i think its run on bridge mode.. all my speakers are powered by the amp.. not from the HU..
the sub was from my dad's friend.. he took it out of his car when he sold his car and gave it to my dad.. dad then gave to me lo.. went to shop and ask them what i need to power the sub..
the wiring from the amp they reuse.. so they just run a wire from the amp and then connect to the wire originally from the sub lo.. go see my reply to eddy regarding the model no. of the amp and sub.. i guess its bridged ba..
dare not to open it lei.. scared i spoil it.. tried opening up few other kind of things le and some spoilt.. so kinda hold myself back from opening up things now.. [laugh]
It depends on how big is your front speaker, but if you go bridged mode it should have enough power to drive your sub. However, if it is configured three channels then this may strain your amps and will go to protection mode often if you blast it.
Check the amp spec for 3 channel config mode, if it does not have enough power, then it is better to have 2 amps.
Edited by Kr_toy
ok so your basstube is a passive one and it will need an amplifier to drive it, yeah and 4ohms too, so we can now strike out the problem of amp driving wrong load.
speakers powered by your amp should be no problem at all and we can strike that out also.
so now we have to consider looking at the possibility of amplifier being driven into "clipping", i.e: your amp is pumping out more power than it can provide continuously. Kianbeng and Sarong1 did mention that as a possiblity.
Can you check the gain levels on your amp? Where is it pointing to? 10 o'clock, 1 o'clock, 4 o'clock? As your amp has 4 channels, you will find two sets of gain adjustment levers. Let us know both.
Edit: can you also let us know your HU brand and model number? Need to know the low-level signal voltage (ala voltage from the RCAs)
Edited by Eddy216
my front speakers are 6.5" de.. not sure about the wattage though..
now, even if i dun blast it, it'll still go into protection mode.. even when i turn off the HU or pause the song..
here's 2 pic i took.. kinda rushed to take the shots.. so could only take 2.. will take more if i have time.. as i see, the level for the rear de, is maxed out.. but i tried reducing it all the way below half mark, and the front de, i turn it to 10 o'clock position.. still experiencing the same thing lei..
Edited by Luv_presea
