Espire 1st Gear November 11, 2008 Share November 11, 2008 Hi All, What is the labour charges in changing oil sump gasket? any bro change before? tks ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 11, 2008 Share November 11, 2008 Is it leaking? If not, just leave it. Labour sud not b that much as its quite straight forward. Get your mech to do it the next time u change your engine oil. Maybe u prefer to buy the gasket/"O" ring from the shop & pass it to your mech. Link to post Share on other sites More sharing options...
Espire 1st Gear November 11, 2008 Author Share November 11, 2008 ya its leaking.. if not I cant be bothered also.. jus dun know how much is the labour, some quote me 100 bucks jus for labour. Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 11, 2008 Share November 11, 2008 You sure its the gasket leaking? Another possibility is the oil seal. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 11, 2008 Share November 11, 2008 If it was hit by something, u also need to check if the sump is cracked or warped. Labour just to change maybe $20-30. It is not that hard to do. Get it done with your oil change to make it easier & kill 2 birds with 1 stone. If u close to your mech, he sud not charge you $100 just to change the gasket lah. Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 12, 2012 Share March 12, 2012 Does anyone know where can i get this oil sump gasket / crushed washer / drain plug gasket? Called most stockist but they dont have it. It is not possible for me to remove it as I have just done an oil change recently. Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 12, 2012 Share March 12, 2012 Btw $100 just to change the gasket is ridiculous. Unless it is inclusive of engine oil and oil filter. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear March 12, 2012 Share March 12, 2012 Btw $100 just to change the gasket is ridiculous. Unless it is inclusive of engine oil and oil filter. Side track abit. Does the oil sump pan need to be taken out and clean? Link to post Share on other sites More sharing options...
Club21z 4th Gear March 12, 2012 Share March 12, 2012 If talking about drain plug gasket i think any workshop will do. Last time my EO leak so change the plug, $15. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear March 12, 2012 Share March 12, 2012 If talking about drain plug gasket i think any workshop will do. Last time my EO leak so change the plug, $15. the drain plug so expensive meh? $15? usualy its only very cheap. think the workshop chop u liao. Drain plug is a very cheap thing cost not even a dollar. Link to post Share on other sites More sharing options...
Club21z 4th Gear March 12, 2012 Share March 12, 2012 the drain plug so expensive meh? $15? usualy its only very cheap. think the workshop chop u liao. Drain plug is a very cheap thing cost not even a dollar. oops i think $8 including labour, not $15 Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 12, 2012 Share March 12, 2012 the washer is very cheap. Less den a dollar. Do they use back the same oil after replacing? Link to post Share on other sites More sharing options...
Seanboi 1st Gear March 12, 2012 Share March 12, 2012 Side track abit. Does the oil sump pan need to be taken out and clean? There is no need to. Link to post Share on other sites More sharing options...
Picanto 3rd Gear October 13, 2013 Share October 13, 2013 yes. they need to clean the sump before applying gasket QUOTE (Seanboi @ Mar 12 2012, 04:37 PM) <{POST_SNAPBACK}> Btw $100 just to change the gasket is ridiculous.Unless it is inclusive of engine oil and oil filter. Side track abit. Does the oil sump pan need to be taken out and clean? Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 15, 2013 Share October 15, 2013 QUOTE (Club21z @ Mar 12 2012, 05:37 PM) <{POST_SNAPBACK}> the drain plug so expensive meh? $15? usualy its only very cheap. think the workshop chop u liao. Drain plug is a very cheap thing cost not even a dollar. Drain plug $0.50. Transport charges to cycle to the parts shop 5 mins away to buy, $14.50. ↡ Advertisement Link to post Share on other sites More sharing options...
Changing halogen to LED
ATP AT-205 Re-Seal
ATP AT-205 Re-Seal
Changing of Spark Plugs
How close to wear indicators before changing tires?
Changing coins to notes
Scirocco - Changing to LED lights
Cost of changing headlamp bulb, foglight bulb
