Gigacrusher Neutral Newbie November 2, 2008 Share November 2, 2008 Hi all, I have recently noticed that my starter seem to take longer to start up my engine after 3 years of use and while this is no surprise in itself, what scares me is at times, the starter just crank and stop dead even when the key still remains in turned position. Anything wrong here and would appreciate advice on what needs to be changed. Many thanks! GC ↡ Advertisement Link to post Share on other sites More sharing options...
Redlavita Neutral Newbie November 2, 2008 Share November 2, 2008 you might want to check your battery, i had the same experience recently, i suspected the starter motor too, cos the battery didn't went flat, i was able to crank, but couldn't start, waited half an hour, tried again, same result. turned out to be the battery died on me after 18 months of use. changed to new battery and problem solved.. Link to post Share on other sites More sharing options...
Maverickchua Neutral Newbie November 2, 2008 Share November 2, 2008 i have the same problem but it is always after I have drive for 40 mins. When I restart again, its kind of difficult. I crank up the starter key, it went dead. I rest for a while and start again, then its ok. At first i suspect that the battery might have problem, but when i do the every 10K servicing and I ask the technican to check, it was ok. I am still puzzle what is the root cause. Link to post Share on other sites More sharing options...
X_RAIDER Neutral Newbie October 16, 2009 Share October 16, 2009 Check your battery. When did you last change it? Link to post Share on other sites More sharing options...
York Clutched October 16, 2009 Share October 16, 2009 time to go for an engine tune up....on the timing ignition, mixtures ratio...etc etc...:) Link to post Share on other sites More sharing options...
SaNibOy Clutched October 17, 2009 Share October 17, 2009 Most prob its the starter. ↡ Advertisement Link to post Share on other sites More sharing options...
Damaged ignition coil. consequences?
Nissan Latio Ignition Coils Replacement
New VW still using key ignition
FireStorm Ignition Coil Booster
Gearbox issues; and problems at VW Service Centre
Common Problems with Optra 5
Headlight problems with modern cars?
Anybody experience problems engaging gear for Fiat Punto?
