Contax 1st Gear October 30, 2008 Share October 30, 2008 I want to install the above 2 gauges , any places to recommend. No need branded stuffs , as long as it work perfectly . ↡ Advertisement Link to post Share on other sites More sharing options...
Jazz 2nd Gear November 2, 2008 Share November 2, 2008 Try Mcwell Venture. Link to post Share on other sites More sharing options...
Starsaaa Neutral Newbie November 2, 2008 Share November 2, 2008 U can try poh lay asessories at this Pasir Panjang rd opp the Pasir Panjang Food Centre. My friend went to MY and compare pricing,the pricing at poh lay will be more attractive. Link to post Share on other sites More sharing options...
Contax 1st Gear November 3, 2008 Author Share November 3, 2008 thanks. Link to post Share on other sites More sharing options...
Contax 1st Gear November 3, 2008 Author Share November 3, 2008 thank you , will drop by and check it out ! Link to post Share on other sites More sharing options...
Slayer Clutched November 3, 2008 Share November 3, 2008 the vold meter is to measure the battery voltage ? or the alternator ? just asking coz i am not so sure how it works. or they are the same whether measuring battery or the other points ? Link to post Share on other sites More sharing options...
Kenzomaz Neutral Newbie November 3, 2008 Share November 3, 2008 How much? Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear November 3, 2008 Share November 3, 2008 I want to install the above 2 gauges , any places to recommend.No need branded stuffs , as long as it work perfectly . if you're reffering to water temperature and volt meter, just buy a ScanGauge2. it will show you these two readings from your OBD2 port in your car. will not cost more than $250. installing is just a matter of plugging the connector into the OBD port near your driver's foot well area. what car you driving? Link to post Share on other sites More sharing options...
Jazz 2nd Gear November 3, 2008 Share November 3, 2008 Not all cars suitable to use scangauge right ? Link to post Share on other sites More sharing options...
Starsaaa Neutral Newbie November 3, 2008 Share November 3, 2008 Not sure for the 2 gauges.. But for 3 gauges is abt $280 at last year (jan to june; not sure when as I forget when i installed it)pricing. Gauges are as follows Vaccum, Voltage and Water. Price include all in with installation plus the adaptor. For now the pricing went up a bit, as heard from my friend who had just installed. Link to post Share on other sites More sharing options...
Starsaaa Neutral Newbie November 3, 2008 Share November 3, 2008 The scangauge price will be more attractive as it has more functions. For the gauges will be more for cosmetic purposes. That will depend on the buyers' decision. Yes not all are suitable to use scangauge. Link to post Share on other sites More sharing options...
Starsaaa Neutral Newbie November 3, 2008 Share November 3, 2008 The volt meter will be used to measure the car batt. Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear November 3, 2008 Share November 3, 2008 most cars can use scan gauge, that's why i asked about TS's car model. to me, it's the best gauge money can buy... Link to post Share on other sites More sharing options...
Jazz 2nd Gear November 4, 2008 Share November 4, 2008 $280 only ? Good price you got there !! Link to post Share on other sites More sharing options...
Jazz 2nd Gear November 4, 2008 Share November 4, 2008 How or where to check, I driving a Latio, so not sure whether is it compatible ? Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear November 4, 2008 Share November 4, 2008 Latio can lah, no problem with compatibility. cars older than 1994, or certain JDM might have a problem... Link to post Share on other sites More sharing options...
Iygnaug 1st Gear November 5, 2008 Share November 5, 2008 Is there any single din gauge available in the market? I had looked at the Delfi single din before, but apparently we cannot customise the gauges that we want. So that's out. same thing, i want volt, vacuum, temp.. Link to post Share on other sites More sharing options...
Mok_ Neutral Newbie November 5, 2008 Share November 5, 2008 Latio is not OBD-II compliant and will not work with ScanGauge II. ↡ Advertisement Link to post Share on other sites More sharing options...
VOLTSwagen?
VOLTSwagen?
What to wear with max temp 20 degree and minimum 10 degree
Fuel gauge needle stop moving
How to reduce air temp inside car on hot days?
Lower temp or increase fan speed - which consume more FC?
"Half" Size Spare Tyre - where to buy / anyone want to sell?
Where to get tyre pressure gauge?
Gauge Monitoring Device
