Ghostami 2nd Gear December 27, 2009 Share December 27, 2009 I think maybe the motor version better.. Think about it, motorcycles normally rev more harder than cars, especially big bikes, so they have to formulate it to compensate this even though it might be the same W figures. I am not sure but this is how I figure it out. ↡ Advertisement Link to post Share on other sites More sharing options...
Redplanet Clutched December 27, 2009 Share December 27, 2009 Any bro know where to get Mobil 1 5W 30? Have been looking around but still can't find it. Autobacs @ ubi. Don't think it's best-priced there. Just fyi only. Link to post Share on other sites More sharing options...
Hwaa Neutral Newbie December 27, 2009 Share December 27, 2009 Went there once to do my servicing as well but not with the 300V. Went for the normal Motul instead. Still a fantastic oil! Can't imagine what the 300V will feel like, but am determined to try it out next time! How much is their 300V servicing package eh? Problem is my ride needs servicing every 5k, so am on cheapo mineral oil (still Motul though) If I get addicted to 300V...DIE lah!! their motul 300v package is $150 exlcuding wheel rotation, $160 inclusive wheel rotation. inclusive of all the standard checks, believe u shld know the way they do servicing liao.. Link to post Share on other sites More sharing options...
Octopus 3rd Gear December 28, 2009 Share December 28, 2009 motul for motorcycle and cars the oil are diff..what diff i dun noe , but if no diff they wont have come out with 2 diff packing one for car and one for bike.. Refer: https://www.mobiloil.com/USA-English/MotorO...rcycle_Oil.aspx Motorcycle oils and passenger car oils are very similar, with the exception of a couple of areas that are key to motorcycle operation. The first area concerns common sumps, or the use of motor oil, to lubricate and cool the transmission. As you know, in a passenger car the transmission is lubricated by an ATF fluid, which has frictional properties required for transmission operation. In a motorcycle, where the transmission may be lubricated by the engine oil, an engine oil that does not have the same level of friction modification (for fuel economy) of a typical passenger car engine oil will provide better transmission performance in terms of transmission lock-up and slippage. So motorcycle engine oil does not contain the friction modifiers of a passenger car engine oil. The second area of concern for motorcycle engine oils is that they tend to shear (breakdown viscosity) more quickly than a typical passenger car. Mobil 1 motorcycle oils are designed to provide exceptional protection against viscosity loss. I also hear due to much higher additive in motocycle engine oil, it may damage car's catalytic converter. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched December 31, 2009 Share December 31, 2009 http://www.ows-germany.com/engineoils.html#top I think another good alternative is the OWS Uber Racing oils. I am using the Turbo racing oil and its pretty good. Cost me $95 for 1 tin. Cheaper than many oils that cost well over $100 per 4L tin. Link to post Share on other sites More sharing options...
Trex101 3rd Gear December 31, 2009 Share December 31, 2009 (edited) Refer: https://www.mobiloil.com/USA-English/MotorO...rcycle_Oil.aspx Motorcycle oils and passenger car oils are very similar, with the exception of a couple of areas that are key to motorcycle operation. The first area concerns common sumps, or the use of motor oil, to lubricate and cool the transmission. As you know, in a passenger car the transmission is lubricated by an ATF fluid, which has frictional properties required for transmission operation. In a motorcycle, where the transmission may be lubricated by the engine oil, an engine oil that does not have the same level of friction modification (for fuel economy) of a typical passenger car engine oil will provide better transmission performance in terms of transmission lock-up and slippage. So motorcycle engine oil does not contain the friction modifiers of a passenger car engine oil. The second area of concern for motorcycle engine oils is that they tend to shear (breakdown viscosity) more quickly than a typical passenger car. Mobil 1 motorcycle oils are designed to provide exceptional protection against viscosity loss. I also hear due to much higher additive in motocycle engine oil, it may damage car's catalytic converter. Motorcycle engine oil are designed for much more extreme condition then normal car engine oil, that's why it's loaded with tons of anti-wear additives and is extremely shear stable. If your engine is not consuming any engine oil then you shouldn't worries abt your catalytic converter. We do have some customers that specially buy motorcycle oil for their car during track usage aka cheapo race oil, so there's still some use for MC oil. The type of application is the key. Edited December 31, 2009 by Trex101 Link to post Share on other sites More sharing options...
Picanto 3rd Gear December 31, 2009 Share December 31, 2009 any chance of you selling OWS oil? it seems quite popular Link to post Share on other sites More sharing options...
Trex101 3rd Gear December 31, 2009 Share December 31, 2009 any chance of you selling OWS oil? it seems quite popular Nah, not at the moment but we are talking to one Motul supplier on bringing in Motul, we see how's the price negotiation goes but hopefully it goes thru. Link to post Share on other sites More sharing options...
Kengohth Neutral Newbie January 2, 2010 Share January 2, 2010 hi, was using Shell Helix Ultra done at C&C. Am driving a Lancer EX 1.5L. For my 50k, used Motul 300V. It seemed ok in the first 5k. After that, the engine seemed be a bit "tired". Not too sure if it is my imagination or not. Changed oil at 55k, now using Mobile or BP. Cannot remeber. picked it from a list at riverview. seems to be doing ok leh. The car can ram hard, and react well. Not too sure if that time when i was using Motul, i was using Malaysia Esso 95 quite often. Now using Esso 97 (JB oil, obviously). Link to post Share on other sites More sharing options...
Octopus 3rd Gear January 18, 2010 Share January 18, 2010 Some UOA of various brand of engine oil, taken from: http://my350z.com/forum/engine-and-drivetr...nd-info-44.html Interesting to note that Motul 300V did not gave the best results. i thought for the price its selling, should have performed better. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 18, 2010 Share January 18, 2010 Some UOA of various brand of engine oil, taken from: http://my350z.com/forum/engine-and-drivetr...nd-info-44.html Interesting to note that Motul 300V did not gave the best results. i thought for the price its selling, should have performed better. The same goes for Redline. I would expect better protection for its reputation. Looks like Amsoil is still the best! Cheap and good. Castrol is a little too epxensive..... ↡ Advertisement Link to post Share on other sites More sharing options...
Motul 8100 X-cess 5W40
Motul Goes Retro With Classic Line Of Engine Oil For Older Cars
🚘 It's Official! Motul is in MyCarForum!!!🚘
OUTDRIVE THE RAT RACE WITH MOTUL
5W30 or 5W40 Engine Oil Is Better For Your Car?
What are lubricant standards?
How to protect your car during the COVID-19 Circuit Breaker
Motul Guide to . . . CNY CAR MAINTEANCE
