Condensation Neutral Newbie November 10, 2008 Share November 10, 2008 thanks for your replies and pm(s)! ↡ Advertisement Link to post Share on other sites More sharing options...
Pachelbel 1st Gear November 14, 2008 Share November 14, 2008 My ride is now 3 yrs old. Some rattling sounds from the cabin/engine compartment. Anyone know where the common source of rattling noise comes from? The suspension now sounds like a cheap, old car when going over rough surface (especially those pebbles surface they made when entering carpark). Any suggestions? Link to post Share on other sites More sharing options...
Route Clutched November 15, 2008 Share November 15, 2008 best to have it checked :) my last rattling sound turns out to be screws in the glove box that my dad left... Link to post Share on other sites More sharing options...
Rainbow 1st Gear November 21, 2008 Author Share November 21, 2008 anyone installed strut bar on your sirion? where to get? Link to post Share on other sites More sharing options...
macrosszero Turbocharged November 21, 2008 Share November 21, 2008 As Myvi and Sirion are rather similar, you can try Ultra Racing's to see if it fits? Link to post Share on other sites More sharing options...
Route Clutched November 21, 2008 Share November 21, 2008 i was told by speedworks jb that the bars wont work for the sirion due to a slightly difference in design of the engine bay? not very sure, did not try it myself as i feel handling is good enough after lowering Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 22, 2008 Share November 22, 2008 Get HotBits adjustable from Speedworks SG, about 80 bucks only, self-installation. Forget about UR. Though one-piece design which should be stiffer, it's blocking the fuse box. Thus making maintenance a pain. There are also some feedbacks on knocking sound due probably to poor design. Link to post Share on other sites More sharing options...
Rainbow 1st Gear November 23, 2008 Author Share November 23, 2008 thanks all for sharing the lobang. Link to post Share on other sites More sharing options...
Accordvtec 1st Gear November 23, 2008 Share November 23, 2008 Hi, I'm thinking to getting a OPC Sirion 1.3A. went down to their road show at Marine Parade today but was quite disappointed. There is only 1 salesperson there and he's busy reading newspapers and simply bo chap . The ... HU for 1.5 sports a quite different from what I saw in the pictures. Anyway, does anyone have a good SE to recommend ? Thanks ! I can help you with that. pm to discuss. Can give further discount/freebies so that you wont be short-changed. Link to post Share on other sites More sharing options...
Route Clutched November 23, 2008 Share November 23, 2008 dude, can show pic of how u install the strut bar? the top part seems to be blocking.... Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 23, 2008 Share November 23, 2008 (edited) Try this link: http://myvi.com.my/forum/index.php?topic=3093.0%3C/ Yes, it's blocked. That's why adjustable type is highly recommended. You don't want to dismantle so many things just to do simple maintenance like changing of fuse for example. Unlike those sedans (Sunny and Lancer, etc) with long nose, Sirion is very compact with very short snout. The suspension tower is just below the wipers' cover. Before you even begin, spray some WD40 on four tower nuts. Find a quiet, bright, even level spot, but under shelter, preferably on MSCP. Budget at least 1 to 1.5 hour for this simple job if you are not a pro (mechanic, technician or hardcore DIY person by profession). Steps: 1. Remove wipers. You need to remove nut covers first. Then, remove nuts to get the wiper arms out. 2. Peer under the wiper cover. You will see a number of plastic clips. Remove these clips using long nose plier. 3. Lift up wiper cover. 4. Unscrew 4 tower nuts using rachet/socket wrench. DO NOT use open end spanner. 5. Put in your strut bar. 6. Screw down 4 nuts. 7. Use alternate, criss-cross method to tighten 4 nuts, until they cannot move anymore. 8. Tighten bolts and nuts connecting to the brackets both ends using 2 same size close end spanners or wrench. (1 to hold and 1 to tighten). You must tighten until it (the other nut) cannot move further with just 1 wrench. 9. Reverse the procedure to assemble back the wiper cover & wipers. For removal of bar in future for general maintenance, just remove the bolt and nut connected to the brackets. There is no need to remove tower nuts anymore. After installation, you will feel noticeable difference in handling in your first corner. Have fun. For those who are more sensitive, you will hear more and louder thumping sounds when going over uneven surfaces. Proof that the chassis is strengthened. Edited November 23, 2008 by Kangadrool Link to post Share on other sites More sharing options...
Rainbow 1st Gear November 23, 2008 Author Share November 23, 2008 thanks for sharing the info, Kangadrool Link to post Share on other sites More sharing options...
Route Clutched November 24, 2008 Share November 24, 2008 thanks, i'm also from that forum but thought that the installation differs for our sirion, weird how speedworks jb told me the front strut wont fit. any sirion meetups? Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 24, 2008 Share November 24, 2008 I got my HotBits strut bar from Speedworks Singapore at Genting Lane. Fits perfectly. Where and when wanna meet? Link to post Share on other sites More sharing options...
Route Clutched November 24, 2008 Share November 24, 2008 cool! you got any other sirion contacts? if not we'll just meet up... wana see the mods on your ride Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 24, 2008 Share November 24, 2008 Mine is the standard Sirion, not even the Sports version. Only mods is front strut bar and rear lower arm bar. All mods to improve handling, not cosmetic. Just removed the 4-point front lower arm bar recently (due to poor design - knocking against exhaust pipe). Can still meet for kopi. Can show u how to install your upper strut bar too. PM me. Next planned mods - CAI and VS. Link to post Share on other sites More sharing options...
Rainbow 1st Gear November 24, 2008 Author Share November 24, 2008 can include me for the meetup. how abt kallang kfc/mac during one of the evenings? Link to post Share on other sites More sharing options...
Route Clutched November 24, 2008 Share November 24, 2008 hey np la, mine is not the sports model too...only have a few mods rainbow, np will let u know, maybe tues or wed at kallang mac? can you two pm me your number please? thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Land Cruiser Mini
Daihatsu admit tampering with safety tests for 30 years
Toyota Sienta 2016
Toyota Sienta 2016
Toyota shows how GR Yaris is made, hints at more GR cars
Toyota Corolla Cross
[Official] 2024 Lexus LBX
2022 Toyota bZ4X
2022 Toyota bZ4X
