Super7 Turbocharged June 27, 2003 Share June 27, 2003 (edited) I need a new air scoop to breath in more air for the intercooler underneath the bonnet. The stock air scoop is small and i think the intercooler will perform better with a new one which can bring in fresh air faster and more ... Any bro knows which workshop can made a good one??.... what material is best, fibreglass??.. metal sheet??..some composite materila?? .... or i can just add a custome made external attachment (maybe a fixed or adjustable) flap etc to direct more air in.... any suggestions/advices?? Thanks Edited June 27, 2003 by Super7 ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 27, 2003 Share June 27, 2003 DIY lah....tonight you see mine for some idea lah... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 27, 2003 Share June 27, 2003 Hi Uncle Foo Wah want to use a STI scoop or not Chances are they will need to cut your bonnet to have a bigger hole to fit a bigger scoop. Most will be fibreglass. I used to know a place that does such things but close down liao leh....so cannot help much. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 27, 2003 Share June 27, 2003 you spoil liao issit....ask DOM to DIY....wait long long Link to post Share on other sites More sharing options...
Super7 Turbocharged June 27, 2003 Author Share June 27, 2003 ... now you put air scoop liao ahh?!!! ... good, i can learn from you Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 27, 2003 Share June 27, 2003 He do CAI lah Link to post Share on other sites More sharing options...
Super7 Turbocharged June 27, 2003 Author Share June 27, 2003 i am thinking maybe leave the stock opening in the bonnet unchanged but add a new air scoop which has a bigger external intake opening:- ie more air rushes in thru bigger front end opening but same size tail opening linking the air passage to the intercooler, this way maybe i can create a 'wind-tunnel' effect (due to large front intake, narrow end discharge) and make the air flow much faster onto the intercooler fins.. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 27, 2003 Share June 27, 2003 aiyah......get a water reservoir to spray water liao lah.....or you can drive every km and spray manually Link to post Share on other sites More sharing options...
Super7 Turbocharged June 27, 2003 Author Share June 27, 2003 why not put the intercooler inside a water bath Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 27, 2003 Share June 27, 2003 then why not drive under water? Link to post Share on other sites More sharing options...
Luckcent 4th Gear June 27, 2003 Share June 27, 2003 ... now you put air scoop liao ahh?!!! ... good, i can learn from you Use air scoop for air intake will be nice. Link to post Share on other sites More sharing options...
Yongwd 1st Gear June 27, 2003 Share June 27, 2003 > aiyah......get a water reservoir to spray water liao lah. the best will be a 60L water tank, top up petrol + water at the same time maybe can consider NOS spray on IC Link to post Share on other sites More sharing options...
Super7 Turbocharged June 27, 2003 Author Share June 27, 2003 then might as well drive a boat...!!! Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 27, 2003 Share June 27, 2003 wah....not a bad idea.......then can have NOS as well....the ass will tear through the atmosphere man!!! Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 27, 2003 Share June 27, 2003 good.....then we can go your boat and BBQ Link to post Share on other sites More sharing options...
Super7 Turbocharged June 27, 2003 Author Share June 27, 2003 (edited) at changi point??!! btw, sat nite maybe i go changi village, you wanna come?? Edited June 27, 2003 by Super7 Link to post Share on other sites More sharing options...
Seansene 1st Gear June 27, 2003 Share June 27, 2003 Side-track a little - upgrade your brakes first... Link to post Share on other sites More sharing options...
Super7 Turbocharged June 27, 2003 Author Share June 27, 2003 (edited) actually, there are people only stay in small flat, but keep a nice boat, and spend more time on the boat than on land on weekends... weekdays bobian, gotta work on land... this way, they save money on house... unfortunately this is not for singapore, more for overseas... Edited June 27, 2003 by Super7 ↡ Advertisement Link to post Share on other sites More sharing options...
Carpark Barrier Knocked My Bonnet
Scratched bonnet
Scratched bonnet
CNA: No tall 'tail': Large lizard found under car bonnet
Bonnet & Boot Lift Supports (AKA Gas Springs)
CF Bonnet for A159..group order...
Workshop to install self-purchase bonnet
What does bonnet insulation fr ?
Be Caution Opening Bonnet During Smoking Engine
