Furrynadz 5th Gear September 4, 2008 Share September 4, 2008 try use second skin performs pretty well at fraction of dynamat price used b4 ↡ Advertisement Link to post Share on other sites More sharing options...
Oklor76 Neutral Newbie September 4, 2008 Author Share September 4, 2008 I will visit them tommorrow. See how will they handle this situation. Link to post Share on other sites More sharing options...
Nkps 1st Gear September 4, 2008 Share September 4, 2008 Quote so is ur car now not so SILENT? i have the same guessing as you Link to post Share on other sites More sharing options...
Nkps 1st Gear September 4, 2008 Share September 4, 2008 likely they will show you their AH BENG and AH SENG attitute, bring someone down with you Link to post Share on other sites More sharing options...
Ngck 3rd Gear September 4, 2008 Share September 4, 2008 Quote Hi, Recently I have black rubbery stain on my window. Thought was some bird sxxt. Later did I found out that the sound proofing material inside the door panel has fallen out thus the sticky bitumen faced the window panel. Question 1)I paid $250 for (2layer x2)from a reputable shop in Singapore in 20/12/06. And the material so call is the best in their range. Is it normal for it to drop out. 2)What is the option do I have. Take out everything and repaste again? Will it drop out again. Thanks for the advise. May go down to the shop to see what will they say since it has been 1 year plus going to 2 years. i diy using some brand from end 2005. (forgot which brand. too long liao) Until now still ok leh. even my car boot which i can access the soundproof mat directly, it is still very sticky leh.. Link to post Share on other sites More sharing options...
Ironstarz 1st Gear September 4, 2008 Share September 4, 2008 2 way for it to happen. 1 ) they did not prepare the surface well , i.e remove the grease and clean the interior door panel well. 2) They did not rub / press thru the sheet to the car properly Link to post Share on other sites More sharing options...
Harveynorman Neutral Newbie September 4, 2008 Share September 4, 2008 Rubbing and pressing is important to push out all the air still trapped. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged September 4, 2008 Share September 4, 2008 such problem shldnt exist... i use cheap bitument sheet use for construction (from bro maverick)and last me for 3 yrs w/o any problem. I even use it on my bonnet where its this is the parts exposed with most heat and it doesnt drop either... when i sell my ride.. i try to peel it and no way... no matter how i try, ... cant remove it at all.... its depends on whether the installer know the right way to do it. Link to post Share on other sites More sharing options...
Garlic 1st Gear September 5, 2008 Share September 5, 2008 Got my bitumen for DIY project from "maverick" as well, got both metal and plastic backed types. Its extremely sticky and stains whatever it comes in contact with, pretty much impossible to remove once it has been pressed onto the panel. Link to post Share on other sites More sharing options...
Garlic 1st Gear September 5, 2008 Share September 5, 2008 (edited) Just wondering, have you performed tuffkote or any anti corrosion treatment on your vehicle? If so, the oily stuff has to be completely removed prior to bitumen installation or else it will not adhere properly. Rolling is also necessary to remove air bubbles and activate pressure sensitive adhesive. Edited September 5, 2008 by Garlic Link to post Share on other sites More sharing options...
Shitcar Neutral Newbie September 5, 2008 Share September 5, 2008 hmmm what car you drive? haha when will you be going down? Link to post Share on other sites More sharing options...
Oklor76 Neutral Newbie September 5, 2008 Author Share September 5, 2008 Latest update. Went down to look for the installer. Told them about my problem. They restick the soundproof material again FOC. Link to post Share on other sites More sharing options...
Oklor76 Neutral Newbie September 5, 2008 Author Share September 5, 2008 Integra lor, went down liao ↡ Advertisement Link to post Share on other sites More sharing options...
Need soundproofing advices
Singapore dropping F1..... tips welcome formula E
Anybody noticed their home water pressure keep dropping?
Foam type sound proofing
Soundproofing for doors
Help!! Soundproofing Stuck to window
Where to buy bitumen sheets for soundproofing?
Wah! Honda 2012 sales dropping as SH!T
