kdash Supersonic January 31, 2018 Share January 31, 2018 Why does it matter whether you are sitting on the left or right? A skilled person can maneuver out as long as it's possible no matter left or right drive. i think what @victor68 means is the lanes switch sides, not the car being LHD or RHD... ↡ Advertisement Link to post Share on other sites More sharing options...
Victor68 Turbocharged January 31, 2018 Share January 31, 2018 Why does it matter whether you are sitting on the left or right? A skilled person can maneuver out as long as it's possible no matter left or right drive. i am skilked but others may not. wait they drive wrong lane how hahaha Link to post Share on other sites More sharing options...
Mcf777 Turbocharged January 31, 2018 Share January 31, 2018 I remembered lucky plaza car park, going up the slope, must keep right side. A bit confused if u first timer. Another confuse car park is Shaw centre (Scotts isetan). If u are exiting the car park (from upper level to lower level), u may be confuse where to turn, to go to lower level. 1 Link to post Share on other sites More sharing options...
Extremme 4th Gear January 31, 2018 Share January 31, 2018 I remembered lucky plaza car park, going up the slope, must keep right side. A bit confused if u first timer. Another confuse car park is Shaw centre (Scotts isetan). If u are exiting the car park (from upper level to lower level), u may be confuse where to turn, to go to lower level. Yup lucky plaza has the opposite direction up/down Link to post Share on other sites More sharing options...
Penknife 5th Gear January 31, 2018 Share January 31, 2018 I used to park at Woodlands drive 14 block 521A carpark. BMW 7 series, lorries, vans, all got no problem parking. So it’s a matter of skills and technique. I used to drive up like a racer on my civic esi. As long as I follow the guide lanes confirm won’t Buang the wall. Now driving Honda Jazz but my balls r missing. Still folllow the guide lanes but not as fast as before. One more thing why wdl dr 14 carpark is scary is because most MACP has a small kerb between the ramp and walls (for people to walk) but for some of these ramps the pavement isn’t there. So ur bumper will hit the wall first instead of your wheel striking the kerb. 1 Link to post Share on other sites More sharing options...
13177 Hypersonic February 1, 2018 Share February 1, 2018 The ramps leading floor to floor is so tight. You need to see it to experience it. Those kind where when you see it, you be Link to post Share on other sites More sharing options...
Extremme 4th Gear February 1, 2018 Share February 1, 2018 Wondering is this carpark ramp more tight than the one at bt merah central MSCP next to the interchange? The carpark at bt merah central quite tight also.Yes it is. I just parked at the bukit merah mscp you mentioned last week. No fight Link to post Share on other sites More sharing options...
Matoonia 6th Gear February 1, 2018 Share February 1, 2018 Entered a car park by mistake and man it was one of the most treacherous that I've been. Small and full of 90 deg turns. To make matters worse I did not know where the exit is so made coupe of 3 point turns. Go try out Katong Point, at your own expense Link to post Share on other sites More sharing options...
13177 Hypersonic February 1, 2018 Share February 1, 2018 Yes it is. I just parked at the bukit merah mscp you mentioned last week. No fight Which one more worse? Link to post Share on other sites More sharing options...
Extremme 4th Gear February 1, 2018 Share February 1, 2018 Woodlands one of course haha... Link to post Share on other sites More sharing options...
Mcf777 Turbocharged February 1, 2018 Share February 1, 2018 Anyone tried the hdb MSCP at Woodlands Drive 14. Link to post Share on other sites More sharing options...
Junky73 3rd Gear February 1, 2018 Share February 1, 2018 Post ur vid cam footage for those taking woodland mscp carpark Link to post Share on other sites More sharing options...
DACH Supersonic February 1, 2018 Share February 1, 2018 Woodlands one of course haha...Ya, no fight. Link to post Share on other sites More sharing options...
kdash Supersonic February 1, 2018 Share February 1, 2018 Wondering is this carpark ramp more tight than the one at bt merah central MSCP next to the interchange? The carpark at bt merah central quite tight also.this carpark is ok cause the driveway is wide enough for the driver to have a larger angle turn in to the ramp. i park there quite often. Link to post Share on other sites More sharing options...
13177 Hypersonic February 1, 2018 Share February 1, 2018 this carpark is ok cause the driveway is wide enough for the driver to have a larger angle turn in to the ramp. i park there quite often. True, driveway is wide enough for driver to have a large angle turn, but still scare the car will hit the wall. Lol. Such tight ramp also same as the one at marine parade central. Link to post Share on other sites More sharing options...
Locknload 5th Gear February 1, 2018 Share February 1, 2018 True, driveway is wide enough for driver to have a large angle turn, but still scare the car will hit the wall. Lol. Such tight ramp also same as the one at marine parade central. Longer vehicles have to go close to the left to make the right-angled turns for the BM mscp. The number of marks before and along the upslope bear testimony to this. Another peeve is the way some carparks are poorly designed, with the railings protruding when reversing causing rear-windows going "pop". Link to post Share on other sites More sharing options...
Agent008 2nd Gear February 1, 2018 Share February 1, 2018 Can try regent heights cp at bukit batok. Quite fun. Link to post Share on other sites More sharing options...
Kopites Supersonic May 15, 2024 Share May 15, 2024 (edited) Apparently not an isolated incident. Beware when heading to the funan carpark. https://mothership.sg/2024/05/cars-funan-car-park-slippery/ Multiple cars crash into Funan basement car park wall while going downslope during heavy rain Edited May 15, 2024 by Kopites ↡ Advertisement 3 1 2 Link to post Share on other sites More sharing options...
Your loot of the day
Barrier arms raised at carpark gantries in 500 HDB estates following ‘technical difficulties’
Online shopping fever
This Beast Worse Than Any Other Beast
MBS Carpark
MBS Carpark
Season Parking Around CBD - Inquiries / Buy / Sell
Carpark Gantry Cheats
