Astralee 2nd Gear June 24, 2003 Share June 24, 2003 any idea wat effect will unbalanced wheels have in the car other than vibrations at the steering. coz mw wheels unbalanced liao, hit one of the wheel on the kerb and no money to change leh. wonder if continued use will have any implications?? ↡ Advertisement Link to post Share on other sites More sharing options...
Zombie Neutral Newbie June 24, 2003 Share June 24, 2003 did you change your tyres recently? Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 24, 2003 Share June 24, 2003 if the damage is not bad, its not that bad....go for another proper balancing lor....i just did it for $12....safety come first Link to post Share on other sites More sharing options...
Jojo Neutral Newbie June 25, 2003 Share June 25, 2003 hitting curb depending on degree and type of tye you have. sometimes can cause tyre to be pregnant or bloated in side. heard very common in micilin (hearsay only, so pl dont sue me)sometime can bend the rim, which is more chia lat. or sometime siply knock out the balancing weight from the rim. if both no problem, sometime can twist the alignment and need to realign. since in your case, the steering vibrate, chances are a balancing may help. shud be cheap. about 10 bucks. in continue to vibrate and dont repair, becomes a nuisance because evertime shake shake shake, and in the long term could loosen other parts of the car, so more prob s later. Link to post Share on other sites More sharing options...
Astralee 2nd Gear June 25, 2003 Author Share June 25, 2003 went stamford and tried balancing. was told tat the rim spolilt liao. so sian, no $$ to change rims.... Link to post Share on other sites More sharing options...
Triston77 1st Gear October 14, 2003 Share October 14, 2003 hm..if steering vibrate, need to do balancing? my car vibrates at 100kmh and above..but..no vibration from steering wheel leh. how ah? Link to post Share on other sites More sharing options...
Smiley Neutral Newbie October 14, 2003 Share October 14, 2003 Quote any idea wat effect will unbalanced wheels have in the car other than vibrations at the steering. coz mw wheels unbalanced liao, hit one of the wheel on the kerb and no money to change leh. wonder if continued use will have any implications?? dangerous when braking, esp hard braking and on wet roads. ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Feedback
Feedback
Dealer re-sell problem car
Wheel Hubs
Wheel Hubs
