Porker Turbocharged August 29, 2008 Share August 29, 2008 I'm thinking of purchasing a plasma TV from USA knowing full well that it runs on 110V while we use 240V. The questions: 1) Is it safe (for the plasma TV) to use a step up transformer for this case? 2) What happens if the transformer breaks down? Will the plasma TV be damaged by the jump in voltage? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Mivec9 1st Gear August 29, 2008 Share August 29, 2008 u r in US now? why not get it from local as the pricing now quite competitive. if u get a step up transformer, i dun see problem for the plasma tv. but as your point 2 mention, there is a high risk of the power surge in the event of breaking down of transformer or other similar events. Link to post Share on other sites More sharing options...
Apollo 1st Gear August 29, 2008 Share August 29, 2008 1) Is it safe (for the plasma TV) to use a step up transformer for this case? of cos is safe... 2) What happens if the transformer breaks down? Will the plasma TV be damaged by the jump in voltage? if it breaks down... i dunno, my brain cell get fused. u hv to consult Prime Optimus abt this. Link to post Share on other sites More sharing options...
Apollo 1st Gear August 29, 2008 Share August 29, 2008 he too free mah.. can ask him tar pao blondie back also. Link to post Share on other sites More sharing options...
Porker Turbocharged August 29, 2008 Author Share August 29, 2008 Am not in US. Reason I'm getting from US is because its the 9th generation Pioneer Kuro. Its not available here YET but I reckon the price will be more than S$10,000 once its launched here. I can get it for about S$4000++ from US. Link to post Share on other sites More sharing options...
Porker Turbocharged August 29, 2008 Author Share August 29, 2008 Help me check on question 2 leh. You're supposed to be the expert mah Link to post Share on other sites More sharing options...
Mivec9 1st Gear August 29, 2008 Share August 29, 2008 if i'm u, i get it then. but buy some powersurge gagdet or mini backup generator....hee Link to post Share on other sites More sharing options...
Apollo 1st Gear August 29, 2008 Share August 29, 2008 KNN.. transformer leh. if it break down.. current how to pass? i fr decepticon one somemore. Link to post Share on other sites More sharing options...
Blue2 1st Gear August 29, 2008 Share August 29, 2008 Autobot mayb will no spoilt Link to post Share on other sites More sharing options...
Apollo 1st Gear August 29, 2008 Share August 29, 2008 nvm lah.. $4K niah niah.. he one nite inside kabuki also not even. Link to post Share on other sites More sharing options...
Blue2 1st Gear August 29, 2008 Share August 29, 2008 wah...so hiong ah.... Link to post Share on other sites More sharing options...
Chongster 6th Gear August 29, 2008 Share August 29, 2008 (edited) Quote I'm thinking of purchasing a plasma TV from USA knowing full well that it runs on 110V while we use 240V. The questions: 1) Is it safe (for the plasma TV) to use a step up transformer for this case? 2) What happens if the transformer breaks down? Will the plasma TV be damaged by the jump in voltage? Thanks. most computer has a switch that let you switch from 220 to 110. flick that switch and watever happen will answer your question (2).... Edited August 29, 2008 by Chongster Link to post Share on other sites More sharing options...
Apollo 1st Gear August 29, 2008 Share August 29, 2008 u can ask him intro mama san to work inside lor.. smelly smelly also make $15K a month Link to post Share on other sites More sharing options...
David Clutched August 29, 2008 Share August 29, 2008 Would you be buying with a international warranty? Link to post Share on other sites More sharing options...
Blue2 1st Gear August 29, 2008 Share August 29, 2008 oic...hmm...better no OT here... Porker asking Transformer question... Link to post Share on other sites More sharing options...
Kklee 6th Gear August 29, 2008 Share August 29, 2008 You'll need a step-down isolated (or double-wound) transformer whereby the primary & secondary separated. While US operates 115V, the appliance itself can be dual voltage via switch (115/230) or auto voltage(100-240). Link to post Share on other sites More sharing options...
Silhoutte Clutched August 29, 2008 Share August 29, 2008 Bro I think you also need to know the capacity of the step down transformers in terms of KVA too. I think when the transformer breaks down, the power is usually cut and all you need is a new transformer. Cheers. Link to post Share on other sites More sharing options...
Apollo 1st Gear August 29, 2008 Share August 29, 2008 told u liaoz.. Prime Optimus will leeply one.. decepticon work is to OTOT. ↡ Advertisement Link to post Share on other sites More sharing options...
Shopee Singapore
Shopee Singapore
Need Advice on Self Storage
