Sienta Neutral Newbie August 28, 2008 Share August 28, 2008 Which of the above is a better choice? ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 28, 2008 Share August 28, 2008 find philips too high price having fitted both b4, find osram more value for $ Link to post Share on other sites More sharing options...
Thestig Clutched August 28, 2008 Share August 28, 2008 Without any specs such as Ks, lumens and the such, I would go for the Osrams and they tend to have better lifespan than Philips products. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged August 28, 2008 Share August 28, 2008 I agree that philips is too ex, tho in various test...it perform slightly better than Osram (even tho osram is +90% vs philips +80%). Osram is value for money. Link to post Share on other sites More sharing options...
Sienta Neutral Newbie August 28, 2008 Author Share August 28, 2008 Hi Furrynadz since you have fitted both, what are you findings? Link to post Share on other sites More sharing options...
Apollo 1st Gear August 28, 2008 Share August 28, 2008 both r too expensive. i got fr lian hoe another german brand, narya or smthg... <$40 for 1 pair. also +50% brightness but there r also other brands ard ... autobaccs bringing in polelarg or wat.. but not chirp. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 28, 2008 Share August 28, 2008 osarm cheaper and last longer 10% brightness, honestly cannot tell much want bright need hid Link to post Share on other sites More sharing options...
Boyboy 1st Gear August 28, 2008 Share August 28, 2008 at philips sale, i got it cheaper than osram at accessory shop unfortunately, that was my "spare" set. first set i bought from mcwell and was thorougly loberted Link to post Share on other sites More sharing options...
Ic3boi Neutral Newbie August 28, 2008 Share August 28, 2008 If compared to crystal vision, is crystal vision whiter? wats the K for the both a/m? Link to post Share on other sites More sharing options...
Dalenico 1st Gear August 28, 2008 Share August 28, 2008 Think it is 3800k anyway order online thru power bulbs..about 60 dollars for both.. my prevous OSRAM blue died after 10 mths...so i decided to try philips.. Link to post Share on other sites More sharing options...
Singer Neutral Newbie August 28, 2008 Share August 28, 2008 i thot CV is 4300k? to the other bro, anything above 6000k will be bluish --> purplish Link to post Share on other sites More sharing options...
Dynaway 1st Gear August 28, 2008 Share August 28, 2008 find philips too high price having fitted both b4, find osram more value for $ wats the price for the philips extreme power & osram nitebreaker??? Link to post Share on other sites More sharing options...
Mr_b20 6th Gear August 28, 2008 Share August 28, 2008 can anyone advise which is the most whitest ? thx ! Link to post Share on other sites More sharing options...
Dynaway 1st Gear August 28, 2008 Share August 28, 2008 use pentel liquid paper n color ur headlamp white lah. want so white for wat... white is white....wat is whiter than white... muahaha Link to post Share on other sites More sharing options...
Dalenico 1st Gear August 28, 2008 Share August 28, 2008 i was referring to NIghtbreaker Link to post Share on other sites More sharing options...
Rtth84 1st Gear August 28, 2008 Share August 28, 2008 White for what? Nice to see only thunderstorm you will be blind on the road and others can't spot your oncoming vehicle... Link to post Share on other sites More sharing options...
Mr_b20 6th Gear August 28, 2008 Share August 28, 2008 thx for yr concern i have fog lamps Link to post Share on other sites More sharing options...
Rtth84 1st Gear August 28, 2008 Share August 28, 2008 then what for have headlights that do not have enough Lumens to help you see? ↡ Advertisement Link to post Share on other sites More sharing options...
Shilin Night Market in Singapore
Home power back up
Home power back up
Alcades power optimizer
