Redlavita Neutral Newbie August 19, 2008 Share August 19, 2008 my friend went to service his ride and was told by the mechanic that it's alright to use ATF oil inplace of power steering fuild.. it's pass 3 months already and his ride is still doing fine.. Anyone tried before? ↡ Advertisement Link to post Share on other sites More sharing options...
So_nice 6th Gear August 19, 2008 Share August 19, 2008 i haf heard of this and seen pple doing it..i mean, no side effect meh? Link to post Share on other sites More sharing options...
Redlavita Neutral Newbie August 19, 2008 Author Share August 19, 2008 (edited) it may sound strange but his power steering still working leh... Edited August 19, 2008 by Redlavita Link to post Share on other sites More sharing options...
Kb27 Supersonic August 19, 2008 Share August 19, 2008 For older cars, they tend to interchangeably used ATF to replace PSF. But one property, that ATF does not have is anti-foaming which PSF has. It may not hurt to use ATF, but I'd rather use PSF which is formulated for that application. Link to post Share on other sites More sharing options...
Dwoon 1st Gear August 20, 2008 Share August 20, 2008 I think my manual says for ATF DEXRON III can be use for PS. Link to post Share on other sites More sharing options...
Tomcat Neutral Newbie August 20, 2008 Share August 20, 2008 but why use a different oil when a specific one is available? Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear August 20, 2008 Share August 20, 2008 normally how many lites do we need.. Link to post Share on other sites More sharing options...
Tomcat Neutral Newbie August 20, 2008 Share August 20, 2008 actually, i don't know, i just go and buy the oil myself...tell them my car model and the check the parts number (from my manual), pay and go...so can't answer your question...maybe someone in this thread can... Link to post Share on other sites More sharing options...
Watwheels Supersonic August 20, 2008 Share August 20, 2008 I dun think there will be side effect. Most PS is rack and pinion which is also a type of gear. Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 20, 2008 Share August 20, 2008 my friend went to service his ride and was told by the mechanic that it's alright to use ATF oil inplace of power steering fuild.. it's pass 3 months already and his ride is still doing fine.. Anyone tried before? I thought I read something about this from BITOG forum (but not sure if I remembered it correctly)... I think AFT oil is a better fluid than power steering oil, since the amount of stress that AFT fluid goes thru in a transmission is greater. So putting ATF oil in power steering (which is a basic hydraulic system) is no problem, but not the other way round. Now I also have a question: Can Toyota Type T-IV be used in Mitsubishi power steering, which calls for Dexron II or III? I thinking should be ok, but cannot find any document that say so... Anyone got any answer to this? Thanks. Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear August 20, 2008 Share August 20, 2008 i've tried it before, on both an altis and a camry... using Toyota Type T-IV just diy at home, quite satisfying actually... just use an empty shampoo container to pump out the PSF reservoir, then pour in to refill, do that every week for about 5-6 weeks, then the PSF would have been changed liao... the steering feel is creamier, slightly heavier, feels good! Link to post Share on other sites More sharing options...
Genie47 1st Gear August 20, 2008 Share August 20, 2008 I'm using T-IV as PSF when my specs ask for Dexron. Link to post Share on other sites More sharing options...
Octopus 3rd Gear August 20, 2008 Share August 20, 2008 [reply] I'm using T-IV as PSF when my specs ask for Dexron. Ok, I guess its safe for me to use it too. Link to post Share on other sites More sharing options...
Boyboy 1st Gear August 21, 2008 Share August 21, 2008 feels good after change yeah? i think dun need to change too often though. maybe every 40000km at most. or when u feel the steering a bit "rough" when parking Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear August 21, 2008 Share August 21, 2008 ya, PSF no need to change so often, 40k interval is just nice. Link to post Share on other sites More sharing options...
Kb27 Supersonic August 22, 2008 Share August 22, 2008 I just use a suck and fill method diy. But Hyundai spec for PSF3 is hard or impossible to find. I just used what I could find...not many selling PSF except the common STP. Link to post Share on other sites More sharing options...
Robin 4th Gear August 22, 2008 Share August 22, 2008 yes can but check yr car manual to confirm. My ATF and power steering fluid can interchange Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 22, 2008 Share August 22, 2008 Yes, you can alter your power steering characteristic too (hard or light) by altering the fluid used. Thin oil like Dexron VI(6.4cSt) will give you lighter feel while thicker fluid like High Temp(10.0cSt) will give the harder feel. ↡ Advertisement Link to post Share on other sites More sharing options...
Encounters with tyre shop
Steering leather wrapping
