Intake Manifold - Clean, Hi-temp paint & Phenolic spacer
Vtim
no, not every 20k km lah, maybe about 60k~80k km depending on whether did you high rev your engine or not
may not have for Toyota wish but the wish 1.8L engine is 1ZZ-FE,
may be you can search under 99' onwards Toyota Celica SS1 (ZZT230) which also uses the same engine or Corolla 1.8L (Aug 00 to Apr 04), Corolla 1.8L RUNX (Sep 02 onwards), Corolla 1.8L Spacio (May 01 onwards), ISIS 1.8L (Sep 04 onwards), MR-S 1.8L (Oct 99 onwards), Premio 1.8L (Dec 01 onwards) & RAV4L/RAV4J 1.8L (May 00 to Nov 05)
of all the above, you may have better luck with the search on Celica SS1, Corolla 1.8L RUNX or MR-S wink.gifwink.gifwink.gif
Edited by Vtim
Which workshop? care to share w me? just done my 80K servicing and the guy at AS recommended me to use the 3M fuel tank addictives.
Edited by Kingcopa
Just go to your regular workshop and tell him to dismantle the IM and clean for you nod.gifnod.gifnod.gif
If you don't have one, PM me and I'll give you the contact and addy wink.gifwink.gifwink.gif
Do not bother, it is not necessary. The 1ZZFE manifold is molded plastic [;)] design was to insulate heat from the engine block + isolate vibration resonance (ie. quieter engine operation).
Since by default it already has heat blocking properties from factory, no companies bother to make an intake gasket (ie Cometic)
Btw, the intake manifold gasket is actually just a rubber ring seal, not flat plate style.
Hope I've help [wave]
In Reply To
I have already installed it inside the stock airbox, will post pics once result is out (after dyno)
the one that I used is TEC1-12706 (Single Stage TEC) and here are the specs : http://www.thermoelectricsupplier.com/single.php [/reply]
the TEC wasn't place at an idea location, see pics.
I will find a way to locate it along the airflow, may have to remove stock airbox and put in a aftermarket one like the Simota nod.gifnod.gifnod.gif
