Typhoonz 4th Gear August 11, 2008 Share August 11, 2008 Asking for my buddy. He was washing his car about an hour after he came home. As he was washing his front left rims, he rinse it down and there was steam coming out. He move his hand nearer and felt that heat was emitting from the brakes. He was puzzled that he didn't do any hard braking and it'a already an hour since he reached home. He also mentioned that for his car was vibrating a little like it's going over speed bumps for about a minute when he was on his way home. The vibrations disappeared after a while so he didn't think much about it. Anyone has similiar experiences? What's the possible cause? ↡ Advertisement Link to post Share on other sites More sharing options...
Linlauhia Neutral Newbie August 11, 2008 Share August 11, 2008 Drove with parking brake engaged Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 11, 2008 Share August 11, 2008 possible depend on wat car he driving some japan cars have very small brakes (eg fit/jazz) and the heat built up actually a lot the rotor surface migth be cool but inside the rotor bell/calliper area might still be hot best to invest in a IR temp gun to ensure cool temp b4 washing calliper/pad temp can go as high as 100+ deg for non slotted/stock pads Link to post Share on other sites More sharing options...
Blackbird749 Neutral Newbie August 11, 2008 Share August 11, 2008 Did he just changed his brake pads? Was the pads fitted properly?? It might be a case of brake pads not fitted properly and still in contact with the brake rotor when the car is on the move. Link to post Share on other sites More sharing options...
Route88 2nd Gear August 11, 2008 Share August 11, 2008 An hour should ease off heat. He uses high temp brake pad? Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 11, 2008 Author Share August 11, 2008 Front brakes leh... Parking brakes is the rear wheels right? Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 11, 2008 Author Share August 11, 2008 He's driving a ESi about 12 years old... Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 11, 2008 Author Share August 11, 2008 He hasn't changed his brake pads recently according to him... Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 11, 2008 Author Share August 11, 2008 He is using normal brake pads... Nothing performance in his car... Link to post Share on other sites More sharing options...
Jazz 2nd Gear August 11, 2008 Share August 11, 2008 Asking for my buddy. He was washing his car about an hour after he came home. As he was washing his front left rims, he rinse it down and there was steam coming out. He move his hand nearer and felt that heat was emitting from the brakes. He was puzzled that he didn't do any hard braking and it'a already an hour since he reached home. He also mentioned that for his car was vibrating a little like it's going over speed bumps for about a minute when he was on his way home. The vibrations disappeared after a while so he didn't think much about it. Anyone has similiar experiences? What's the possible cause? Suspect his brake pad heat trapped, when you pour water, it release the heat immediately which cause the brake and disk sudden cooling thus emit this smell. No good to the disk as this may tend to warp the disk. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 11, 2008 Author Share August 11, 2008 Anyway to remedy? He wants to find out more before going to the workshop. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 11, 2008 Share August 11, 2008 Brake piston jammed? Happened to me before. The brake disc on one side was scorching hot compared to the other side. Got a metal burning smell too. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 11, 2008 Author Share August 11, 2008 Might be... So how much was the damage to get it fixed? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 11, 2008 Share August 11, 2008 I can't remember. It was quite some time ago. Mine was a lorry though. Happened to high mileage vehicle. Perhaps u can ask your fren to jack up the front and see whether the tyres can rotate freely. If it's brake piston jammed, the tyres cannot even be rotated at all! Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 11, 2008 Author Share August 11, 2008 Oh then it shouldn't be... He still able to drive it... In fact he won't even have noticed anything amiss if he didin't wash his car... Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 11, 2008 Share August 11, 2008 My lorry still can be driven too. Just that when I parked the vehicle there was a very strong metal burning smell and when the mechanic jacked up the front, the wheel cannot be spin at all. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 11, 2008 Author Share August 11, 2008 I see... That bad ah? I'll tell my buddy to see if he can push the car when the engine is off... Link to post Share on other sites More sharing options...
Vincent_ltm Neutral Newbie August 19, 2008 Share August 19, 2008 since he is driving such an old car most likely he need to service his brakes caliper just change the caliper repair kits... if you need this service PM me ↡ Advertisement Link to post Share on other sites More sharing options...
Smell of Singapore's Rich
Favourite Japanese Songs from 1980-90s
FORCE Big Brake Kit promotional Price
Yusheng from Singapore, Malaysia or China
How to trace owner from vehicle registration number?
Black flakes from washing machine
No basis for employers to cut pay if flexi-work does not affect productivity: Gan Siow Huang
Yes, ‘old person smell’ is a thing – but what causes it and can you neutralise it?
