Fluffy Clutched July 28, 2008 Share July 28, 2008 bros, anybody know the what should be service at each service interval? Oil change at every 15,000km right? together with oil and air filter change. when to change ATF? when to change brake fluid? when to change timing belt + water pump? anything else need to change? anybody know where skoda has a detailed maintenance scheduled checklist? thx ↡ Advertisement Link to post Share on other sites More sharing options...
Simpleman 1st Gear July 28, 2008 Share July 28, 2008 What I can remember:- ATF and brake fluids change at 60K. Timing belt at 90K. Spark plugs at 60K. Think air filter need not be changed every 15K. Pollen filter probably change annually. Will try find the detailed schedule obtained in 2005. Link to post Share on other sites More sharing options...
Echelon 3rd Gear July 28, 2008 Share July 28, 2008 The wonderful thing about the Skoda Superb is that it is rather low maintenance and bullet proof engine - especially when you take good care of it. Oil change at every 15,000km right? together with oil and air filter change. You can if you want to but following the recommended change intervals is quite good already. when to change ATF? 60,000 km - I just did mine. Now it purrs again...silky smooth ride when gear changes. when to change brake fluid? 60,000 km - Just did mine. when to change timing belt + water pump? If not wrong 90-100k onwards, quite alot of work involved for this. anything else need to change? Battery, sparks (recommend every 30k, some say 15k - up to you) Air Filter - K&N is not bad but noisy, I reverted back to OEM filters. Link to post Share on other sites More sharing options...
Fluffy Clutched July 28, 2008 Author Share July 28, 2008 bro, u feel any diff with K&N and then change to OEM? i have a performance filter and it is much noisier....dun feel much diff in terms of power though Link to post Share on other sites More sharing options...
Koolaba 1st Gear July 28, 2008 Share July 28, 2008 Hi bro, Oil Change: Recommended interval is at every 15,000km. However if your driving pattern consists of a high percentage of start-stop driving, you can consider performing the change at ever 10,000km. ATF: 60,000km is a safe interval. I have known of a few Audi A4 and Passat owners who change at every 40,000km to 50,000km interval, to ensure that a gearbox change (due to premature failure) is not warranted. Brake fluid: every 3 years or 60,000km whichever comes earlier. If the brakes feel extremely spongy, it is a clear indication that the fluid must be changed. Link to post Share on other sites More sharing options...
Fluffy Clutched August 3, 2008 Author Share August 3, 2008 hey bro, u managed to find the detailed schedule that u got in 2005? Link to post Share on other sites More sharing options...
Simpleman 1st Gear August 4, 2008 Share August 4, 2008 Here you are: Service Type A 15,000km/45,000km Replace 1. Replace engine oil 2. Replace oil filter Check condition (visual) 3. Airbag units: for external damage 4. Battery: check level 5. Brake fluid level 6. Brake linings/pads: thickness 7. Brake system for leakage & damage 8. Cooling system: inspect and top-up 9. CV joint boots for leakage and damage 10. Door straps: lubricate 11. Electrical switches and controls 12. Engine: for leakage and damage 13. Exhaust system 14. Fault memory self-diagnosis 15. Gearbox: for leakage and damage 16. Indicators and other controls 17. Plenum chamber: inspect for dirt 18. Service interval display: reset 19. Steering boots: for leakage and damage 20. Track rod ends and boots 21. Tyres: for condition and inflation 22. Windshield wiper and washer Link to post Share on other sites More sharing options...
Othello Supersonic August 5, 2008 Share August 5, 2008 all this years, I've always wondered whether the wkshop does all these checks ... Link to post Share on other sites More sharing options...
Simpleman 1st Gear August 5, 2008 Share August 5, 2008 We all can continue wondering till the cows come home. Key point is: VISUAL CHECK! See only lah! See clearly or check thoroughly is another matter. Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie August 5, 2008 Share August 5, 2008 Link to post Share on other sites More sharing options...
Fluffy Clutched August 8, 2008 Author Share August 8, 2008 bro, what is the service type B and D? Link to post Share on other sites More sharing options...
Simpleman 1st Gear August 12, 2008 Share August 12, 2008 Service Type B 30,000km/90,000km Replace 1. Replace engine oil 2. Replace oil filter 3. Replace air filter 4. Replace air-con filter 5. Replace brake fluid Check condition (visual) 6. Airbag units: for external damage 7. Battery: check level 8. Brake fluid 9. Brake linings/pads: thickness 10. Brake system for leakage & damage 11. Cooling system: inspect and top-up 12. CV joint boots for leakage and damage 13. Door straps: lubricate 14. Electrical switches and controls 15. Engine: for leakage and damage 17. Exhaust system 18. Fault memory self-diagnosis 19. Gearbox: for leakage and damage 20. Indicators and other controls 21. Plenum chamber: inspect for dirt 22. Service interval display: reset 23. Steering boots: for leakage and damage 24. Track rod ends and boots 25. Tyres: for condition and inflation 26. Underbody protection & paintwork 27. Windshield wiper and washer Applies to Superb, Octavia and Fabia. ↡ Advertisement Link to post Share on other sites More sharing options...
Car repair and maintenance
Skoda Octavia RS launched in Singapore at $199,900!
[Spyshots] 2023 4th Generation Skoda Superb
Extending COE for Toyota Wish (2008)
Ho Hup Seng......Some good info for our Brudders
