Limbat 1st Gear July 31, 2008 Share July 31, 2008 They are different - now they even have in the market H11B & H12B only diff is a mounting adapter............ ↡ Advertisement Link to post Share on other sites More sharing options...
Limbat 1st Gear July 31, 2008 Share July 31, 2008 Quote Off the self HB4 cannot fit into the headlights. How ah? Not to mention it's not even white. I have got 2 sets of this model in Crystal White color - PM me if u need " White color" beam........... Link to post Share on other sites More sharing options...
Whitemondeo 1st Gear July 31, 2008 Share July 31, 2008 Fully agree with you about the o-ring. Unfortunately, no marking on the bulb and was told by the workshop to use the o-ring colour to assist. To be honest, this was my first time getting the HB4 for someone and got confused with the HB3 & HB4 bcos both look the same except the o-rings. Link to post Share on other sites More sharing options...
Limbat 1st Gear July 31, 2008 Share July 31, 2008 technical drawing of all Halogen Bulb type can be found on the net for comparision - www.limbat.com.sg Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie July 31, 2008 Author Share July 31, 2008 The HB4 fit nicely into the plug, and I tested, it can light up. Just that it cannot fit properly into the headlight. Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie July 31, 2008 Author Share July 31, 2008 HB4? Cannot fit leh... HB3 got? Link to post Share on other sites More sharing options...
Apollo 1st Gear July 31, 2008 Share July 31, 2008 friend.. goto this LianHoe at Rowell road, just buy 1 bulb. Lumax german brand, i think made in thailand/ indo. only $10+. test with 1 bulb. becos those filips/ osram will b 3 times more exp. no worries, this bulb will last u easily 2 yrs at least. u want can ask the unker there. they only see bulbs and fuses nothing else so they sud noe.. i using another brand called navya +50% brightness. Link to post Share on other sites More sharing options...
Limbat 1st Gear July 31, 2008 Share July 31, 2008 If I am not wrong your Headlamp casing is imported in from Japan - last year I tool a set for a starlet - it is slightly different something like a cross between HB4 & HB3 but both will not fit into your lamp casing. You will need to modify 1 of the mounting leg located at the base of the glass tube - then it will fit... cheers Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 2, 2008 Author Share August 2, 2008 OK... Thank you Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 2, 2008 Author Share August 2, 2008 wah.. so troublesome Link to post Share on other sites More sharing options...
Limbat 1st Gear August 2, 2008 Share August 2, 2008 yeap, veri veri troublesome btw where did u guys get the lamp casing from ?? Anyway u have to find a spare if not if your current 1 blown where are u going to get a replacement !! Link to post Share on other sites More sharing options...
So_nice 6th Gear August 2, 2008 Share August 2, 2008 the whole set of headlights are from starlet GT aka ep82. it can be modded..i believe our fave mech should be able to do it. haha he really do wonders wif them. kazuo, u should gif him a ring and ask for his advice. Link to post Share on other sites More sharing options...
Steam Neutral Newbie August 3, 2008 Share August 3, 2008 still haven't get it fixed? Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 3, 2008 Author Share August 3, 2008 no leh... tomorrow ba... Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie August 3, 2008 Author Share August 3, 2008 mod bulbs then ok la... more lamps? can mod to H4 ah? ↡ Advertisement Link to post Share on other sites More sharing options...
Eye surgery - cannot drive
Sales pitch for animals
Cannot anyhow stick SPF decal liao!
Free healthcare and higher taxes or die and cannot fall sick
Toyota Sienta cannot use 16" rims?
Why cannot transfer car in the first 3mths of ownership
Public Alcohol consumption bill-Cannot have a beer at a BBQ!
Now ADs cannot void your warranty!
