Sfrtuscani Neutral Newbie June 19, 2008 Share June 19, 2008 (edited) If the battery can last for 18 mths, then is ok lah. only $5.83 per mth depreciation. heehee....didnt hear tt from u tt ur battery dead... my free Amaron MF batt from komoco is already 2yrs old le... and i forgot to switch off my lights for 3 times... now still good as new!!! Edited June 19, 2008 by Sfrtuscani ↡ Advertisement Link to post Share on other sites More sharing options...
Wt_know Supersonic June 19, 2008 Author Share June 19, 2008 my last servicing did not ask me to change battery. didn't even check battery as my battery is maintenance free type Link to post Share on other sites More sharing options...
Calvin53 Neutral Newbie June 19, 2008 Share June 19, 2008 may i noe wat's the symptoms when batt gg to kaput? Link to post Share on other sites More sharing options...
Wt_know Supersonic June 19, 2008 Author Share June 19, 2008 insert car key. turn -> then hear tick tick tick sound. engine no sound and not even engine cranking sound. Link to post Share on other sites More sharing options...
Calvin53 Neutral Newbie June 19, 2008 Share June 19, 2008 yup.. but after jump start can it last long? Link to post Share on other sites More sharing options...
Wt_know Supersonic June 19, 2008 Author Share June 19, 2008 after jump start ... of course fast fast go get a new battery la Link to post Share on other sites More sharing options...
Cleanliver Neutral Newbie June 19, 2008 Share June 19, 2008 Symptoms gg to die i think is when u crank the thing seems sluggish, not spontaneous like b4..another gauge is first attempt to crank normally failed, then 2nd attempt u try cranking n holding it there longer then can start. after jump starting, provided you leave the engine running on for at least say 30mins, the batter may still remain charged at the next cranking but better to make battery changing the priority after this. Link to post Share on other sites More sharing options...
Keithpapa Neutral Newbie June 19, 2008 Share June 19, 2008 If Driving Nissan Go back to Tan ChongBattery Less than 2 Years 50% Discount foc for toyota within 2 years, just changed mine b4 two years. no qns asked ever the old battery is fine. Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie June 19, 2008 Share June 19, 2008 (edited) try not to jump start continental cars or those with lots of electronic, it can fry something, my mech learned it the hard way, and fried a BMW.. cost him a few hundred to rectify after starting, change batt immediately Edited June 19, 2008 by Cyberet Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged June 19, 2008 Share June 19, 2008 If the battery can last for 18 mths, then is ok lah. only $5.83 per mth depreciation. heehee....didnt hear tt from u tt ur battery dead... my free Amaron MF batt from komoco is already 2yrs old le... and i forgot to switch off my lights for 3 times... now still good as new!!! knn... if not y i call u yesterday morning??? try my luck to c whether r u in yishun but in the end, nvr answer call.. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear June 20, 2008 Share June 20, 2008 If Driving Nissan Go back to Tan Chong Battery Less than 2 Years 50% Discount ---------------------------------------- I changed mine at end of 22nd battery even tho battery still ok. Cost $52.50 before gst. This the first time I changed battery before it died. If go Battery Shop at least More than $100+ Link to post Share on other sites More sharing options...
Ccssgm 1st Gear June 20, 2008 Share June 20, 2008 1 full tank of petrol is more than $105, and can only last for 1 week, so what is $105 when it can last for 18 mths. Worth every cent lah. Yr Petrol So Heavy [laugh] Link to post Share on other sites More sharing options...
Ccssgm 1st Gear June 20, 2008 Share June 20, 2008 Borneo Motor So Good SERVICE Link to post Share on other sites More sharing options...
Ronnchee Clutched June 20, 2008 Share June 20, 2008 I read from some article, before you start the engine, look at the battery reading. If it drop below 12v, time to change liao. Or you can "listen" to the cranking sound. A sweet cranking shows the battery is still strong. Link to post Share on other sites More sharing options...
Ronnchee Clutched June 20, 2008 Share June 20, 2008 That is before the discount given lah... Average full tank about $100+/-. Where is cheaper to get car battery, JB or Sg ?? Link to post Share on other sites More sharing options...
Superduper Neutral Newbie June 20, 2008 Share June 20, 2008 To be on the safe side, change battery every 18 months. We do not want to be stranded especially when we are already running late. Link to post Share on other sites More sharing options...
Mivec69 Neutral Newbie June 20, 2008 Share June 20, 2008 car cannot start and stall in the mscp now. need to have onsite battery replacement ! Have you tried mycas? Some car models quite cheap. Link to post Share on other sites More sharing options...
Robo 2nd Gear June 20, 2008 Share June 20, 2008 charge liao faster go change... if not tmr or later cannot start again... ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Another doctor in trouble
Battery Voltage up & down
Amaron Battery
Amaron Battery
