Dennisk Clutched June 16, 2008 Share June 16, 2008 Hi guys, need some advise on this issue: Last week i went back to TTS for my 10K servicing. After few days of driving, i then realised that i can feel the whole steering vibrating (juttering) when i apply my foot on the brakes while slowing down and stopping. Is this abnormal? Before servicing i didn't have this issue. what could have they done to my car? ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic June 16, 2008 Share June 16, 2008 Did u call them & ask? I think u better bring your car down & explain your braking experience. Link to post Share on other sites More sharing options...
Ogima Neutral Newbie June 16, 2008 Share June 16, 2008 hello dennisk, steering vibration during braking.... normally above 100km/hr, might be due to rotors warping which is due to uneven wear / strinking which in turn due to hard braking / washing of rotor while hot after driving. as your mileage is only 10K....better bring back to last workshop to rectify. FYI, my japanese model warps only after 40K. Link to post Share on other sites More sharing options...
Dennisk Clutched June 16, 2008 Author Share June 16, 2008 (edited) so what can i do if rotor warps? yup, i felt it above 80~90 km/h Edited June 16, 2008 by Dennisk Link to post Share on other sites More sharing options...
Dennisk Clutched June 16, 2008 Author Share June 16, 2008 not yet. will do that later Link to post Share on other sites More sharing options...
Ogima Neutral Newbie June 16, 2008 Share June 16, 2008 hello dennisk, send the rotors for skimming....some workshops are able to do it at approx. price of SGD60....each ? (only the front is necessary). some workshop don't recommend skimming more than once as the thickness of rotors is reduced. with the reduction in material, your after-skimmed rotors will not last as long as the stock ones prior to skimming. alternatively, replace them with cross drilled and/or slotted after-market ones. the cross drilled holes can help to dissipate heat while the slotted ones enhance braking efficiency. however, since yours is only 10K mileage, better to go back last workshop. yeah...i forgot in my last post....Hollandia ! Link to post Share on other sites More sharing options...
Dennisk Clutched June 16, 2008 Author Share June 16, 2008 (edited) does warranty cover this? Edited June 16, 2008 by Dennisk Link to post Share on other sites More sharing options...
Ogima Neutral Newbie June 16, 2008 Share June 16, 2008 hello dennisk, well, i shouldn't speak on behalf of the seller....but guess it ought to. read on the sales agreement and a simple call/visit to them will answer all doubts. Link to post Share on other sites More sharing options...
Ju141586 Neutral Newbie December 14, 2013 Share December 14, 2013 This thread died for a few years. I'm experiencing the same problem as TS, initially thought changing engine mounting will solve the problem. It only helped a little as mounting is also spoilt. Anyone is advice the price for skimming or changing new rotors? Any workshop to recommend? Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 14, 2013 Share December 14, 2013 This thread died for a few years. I'm experiencing the same problem as TS, initially thought changing engine mounting will solve the problem. It only helped a little as mounting is also spoilt. Anyone is advice the price for skimming or changing new rotors? Any workshop to recommend? Sometimes the shuddering when u brake is due to discs/pads dirty/oily. After it sud go away. If it dun, then maybe hv the pads checked for wear first. Also worn steering n suspension joints can cause the shuddering when u brake. Link to post Share on other sites More sharing options...
Ju141586 Neutral Newbie December 15, 2013 Share December 15, 2013 Thanks for the advice! Link to post Share on other sites More sharing options...
MaxLim7028 December 16, 2013 Share December 16, 2013 yes, experience this b4 and changed the brake disc or other name as called here. because the disc has warped due to wear and tear, mine think >40k too or more but lost track liao. usually original parts should not fault at 10K, is it too low a mileage for passenger car. unless ever time you jam brake for any braking but not logically possible. u racer ?! ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Steering leather wrapping
Steering column
Steering column
Understanding Anti-lock Braking System (ABS)
the newest Mercedes model slk plaid
Reinventing the Wheel - Tesla Edition
