Zoomm Neutral Newbie June 16, 2003 Share June 16, 2003 Hi, Can anyone tell me what's wrong with my car? My car's clutch somethimes stucked and the gear was unable to engage and the car seem to be like a auto gear. This usu happened when in the carpar where I depressed the clutch for to long. Please help. Thank you. ↡ Advertisement Link to post Share on other sites More sharing options...
Jimmyl Neutral Newbie June 16, 2003 Share June 16, 2003 Could be some gearbox/gearplate problem, worsen by your riding on your clutch. GO check with a mechanic. Going to be expensive Link to post Share on other sites More sharing options...
Luckcent 4th Gear June 16, 2003 Share June 16, 2003 It may be the clutch master pump already failing. Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie June 18, 2003 Share June 18, 2003 is there any pedal feel ? Or would the clutch pedal kinda drop almost to the floor with little resistance ? Had that problem in one of my earlier cars.... clutch pump died, basically cannot engage/disengage gears. Suggest send in for servicing. Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie June 19, 2003 Share June 19, 2003 cable or hydraulic clutch? Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear May 12, 2006 Share May 12, 2006 sorry for hijacking old thread.. experiencing problems in engaging reverse lately.. the clutch can be depressed like usual..but however, the reverse gear is so hard to engage.. even though i have pushed it to the extreme right, when i try to pull the gear stick down.. there seems to be some restriction there.. tried a few times to release clutch and depress again.. sometimes can work, sometimes cannot.. if i try to be rough by just forcing it in.. there will be a sound like --> Grrrrrrraaak... please advise.. thanks Link to post Share on other sites More sharing options...
Sky8807 1st Gear May 12, 2006 Share May 12, 2006 Adjustment of the clutch free play could solve the problem. Too much play make the reverse difficult to engage. If adjustment is max already, then clutch worn to limit. Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear May 12, 2006 Share May 12, 2006 Biting point is not that deep.. clutch is still quite new.. less than 10K on it.. sometimes can't engage the gear when in Basement CP (shopping centre).. then people horn like as if.. "WTF with this driver?? don't know how to drive don't drive".. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear May 12, 2006 Share May 12, 2006 check your engine mounts. if they're worn its harder to engage gears esp at low RPMS. Are you having any issues with engaging first gear or is it harder to engage first gear over the other gears??? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear May 12, 2006 Share May 12, 2006 (edited) if its a hydralic clutch it sounds like either the master cylinder or slave cylinder is on its way out. If this happens too often, its just a matter of time before one of them goes and you're stuck without a working clutch. Usually the slave is first to go, but get them both checked out anyway. Edit: ahh i forgot. if it uses a clutch cable, get the cable checked for kinks or damage. Edited May 12, 2006 by Elfenstar Link to post Share on other sites More sharing options...
Yc86 Clutched May 12, 2006 Share May 12, 2006 worn out synchromesh? try reving the engine while in neutral before engaging the gear? maybe it'll help... nothing to do with clutch i suppose Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear May 12, 2006 Share May 12, 2006 engaging other gears all no problem.. only reverse.. everytime must force it in.. *Grrrrrak*.. that sound hear liao will scared the vehicle Kapuk leh.. Link to post Share on other sites More sharing options...
Sky8807 1st Gear May 12, 2006 Share May 12, 2006 clutch free play shd be about 1/2" before clutch pedal tension inside the car cabin. in your case it only adjustment at the engine compartment side. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear May 12, 2006 Share May 12, 2006 might be syncro then, but check the engine mounts first anyway... if thats it, its much cheaper than pulling ur box off. Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie May 12, 2006 Share May 12, 2006 Looking at your avarta, you are driving a BJ 323? If that's so, you are using the hydraulic clutch and high change, the clutch pump's weak. Did you change your clutch disc and pressure plate recently? Link to post Share on other sites More sharing options...
Teddi Neutral Newbie May 13, 2006 Share May 13, 2006 What's you cars mileage, model? If mileage is about 50K, change your clutch disk & gear oil. Link to post Share on other sites More sharing options...
RealmChua Neutral Newbie January 8, 2016 Share January 8, 2016 My suzuki swift sport also facing same problem... can go forward but cannot engage reverse gear... anyone know what is wrong? any how much is the repair cost anyone know? Link to post Share on other sites More sharing options...
MohdSalim72 Neutral Newbie December 23, 2016 Share December 23, 2016 Hi all need ur advise/suggestion..i have this problem with my gearbox(manual gear)..i can't shift to my 1st gear when moving off..have to use 2nd gear..anyway i driving Chevrolet Spark..left 1 more year to go..thnx all ↡ Advertisement Link to post Share on other sites More sharing options...
Clutch
Clutch
Clutch for Volvo V40 T4 2013 Price?
Urgent - battery or other problem?
A Snowstorm Trapped 50 People in a Remote Pub With an Oasis Tribute Band for 3 Days
Toyota Harrier Auto transmission problem
Unable to balance rims
