Testa_ross4 Clutched June 5, 2008 Share June 5, 2008 Does Toyota Harrier 240G 16 valve VVTi engine using a timing chain or timing belt? Just checking for a friend as his Harrier has hit 140K kms and was advised to change timing belt. ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic June 5, 2008 Share June 5, 2008 There are both. Which one u talking about? Timing chain runs the overhead cams.(this one highly unlikely) The belt runs your air-con, pumps, power steering and alternator. Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie June 5, 2008 Share June 5, 2008 Timing chain. Can last at least 250'000km. Please check around with other bros here. Link to post Share on other sites More sharing options...
Testa_ross4 Clutched June 5, 2008 Author Share June 5, 2008 OK thanks, it should be timing chain that runs the overhead cam. Link to post Share on other sites More sharing options...
Flyguy63 Neutral Newbie June 5, 2008 Share June 5, 2008 Go to this site,local Harrier and RX300 group.Very informative and friendly people to assiat you......http://forums.delphiforums.com/harrier_rx300/ Link to post Share on other sites More sharing options...
Testa_ross4 Clutched June 5, 2008 Author Share June 5, 2008 TQ ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Land Cruiser Mini
Toyota Corolla Cross
Next Generation Toyota Crown
Toyota shows how GR Yaris is made, hints at more GR cars
Using blower to dry car
8th Gen Toyota Camry (XV70)
