Orac Clutched June 2, 2008 Share June 2, 2008 Hi All, I'm new to ICE. Just wondering if its possible to just add tweeters to my stock speakers(non-component speakers)? If its possible, is it just simply connecting the +ve and -ve wires of the tweeters to the stock speakers? Please advise. Cheers Orac ↡ Advertisement Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged June 2, 2008 Share June 2, 2008 I think you have to hook up a crossover to filter out the high freq to your tweeters, low and mids to your stock speakers since you don't have a woofer. If you just connect in parallel, the sound won't be nice. Fellow bros do correct me if i'm wrong here.. Link to post Share on other sites More sharing options...
Josephteo 1st Gear June 2, 2008 Share June 2, 2008 (edited) yea... if i not wrong.. you need to add a crossover for best effects... alternatively... the best way would be to change your stock speakers to component speakers which comes with tweeters, crossovers and new 6.5" speakers... Edited June 2, 2008 by Josephteo Link to post Share on other sites More sharing options...
Orac Clutched June 2, 2008 Author Share June 2, 2008 Hi, Ok, i understand now. Thanks both for your input. Cheers Orac Link to post Share on other sites More sharing options...
Bearbear1494 Clutched June 2, 2008 Share June 2, 2008 Your stock speakers are most probably co-axial speakers, with the tweeter built right on top of the mid woofer cone. If you're going to add crossovers to co-axial speakers in order to wire additional external tweeters, that will mean that the built-in tweeters will be disabled since the crossovers will now send only the lower frequencies to the mid-woofer. Of course it's better to just replace the entire set with component speakers, but your idea is still feasible so long as you don't expect really high sound quality levels. The above is just some extra info. Link to post Share on other sites More sharing options...
Orac Clutched June 2, 2008 Author Share June 2, 2008 Hi, Thanks for sharing. Finally, I learn something new today. Cheers Orac Link to post Share on other sites More sharing options...
Dunno Neutral Newbie June 3, 2008 Share June 3, 2008 Yup, safe the trouble and change the whole pair of stock speakers to component speakers. If you only add a pair of tweeters, you will need to also add a crosover box to filter the high frequencies to your tweeters and low frequencies to your coaxials in the door (this will effectively "mute" out the tweeters in the coaxial if the high frequencies are not channelled there). Without the crossover box, you will most likely end up blowing your new tweeters as they usually cannot handle frequencies below 2khz. Link to post Share on other sites More sharing options...
Apollo 1st Gear June 3, 2008 Share June 3, 2008 actually, if u hv the crossover tat comes with the tweeter, u still can do it, except that it does no more then raising the sound image. but due to the resistors inside the crossover, there will b a slight time lapse (very slight to the discerning ear),but overall, with the rear speakers playing, the overlaping lapse time delay will muff sound. in short, it is very primitive way to get sound imaging and wun b decent. try buying pre-owned component in region of 50W rms. if ur headunit is high power, it will b a large improvement fr where u r now with the stock speaker. Link to post Share on other sites More sharing options...
Dunno Neutral Newbie June 3, 2008 Share June 3, 2008 If driven direct from the HU, the component speakers should have a sensitivity of around 90dB and above. Then they will be easy to drive. ↡ Advertisement Link to post Share on other sites More sharing options...
The Perfect Storm of the Stock Market III
Professional casino gamblers-is it possible?
Component speakers, no amp?
Upgrading stock horn
Benefits of having bigger population in our day to day life.
The Best Cooling Measures: Ice Cream! 😂
