How to control your car when it starts spinning under wet road condition
Lemonteh
Heard before that if your car are going to "spin", do this 2 things:
1. let go of acceleration
2. engage to lowest gear ASAP - use engine brake (but for auto car difficult as you need to step on foot brake to change to D1 or D2).
Was told not to engage foot brake, it'll worsen the spinning. Not sure if this is true wor??
bro... maybe to better help understand hydroplaning....
actually.. there are 3 types of hydro planing...
dynamic hydroplaning, viscous hydroplaning & reverted rubber hydroplaning (for aircraft landings so not in discussion)
dynamic hydroplaning occurs when the downward pressure (inflation pessure) of the tyre is insufficient to displace the water from the imprint area in the short time of contact.
prevention:
1. lower speed(duh)
2. tyres with deep tread depth
viscous hydroplanning occurs on a smooth pavement surface (e.g. multistorey CP wet surface). loss of friction can occur at relative low speed when viscosity alone is adequate to prevent water from escaping from under the tyre
er... sry with the boring definations but the key is tread depth...
not too sure abt the bigger tyre = easier to hydroplane part as bro silverZ mentioned... (or otherwise as u mentioned)
edit: after reading my sources again... i see a diagram showing tyre imprint area gettin smaller as speed increases = hydroplane....
so maybe bigger tyres = bigger area of contact... maybe = lesser hydroplane?
thou the key is still tread depth...
Edited by Zcold
prevention:
1. lower speed(duh)
Does it mean that wider tires means water have to travel longer in the threads before it gets pushed out? This would make sense if you see wider tires have wide threads while the smaller tires tend to have smaller treads.
  Quote
Does anyone knows what is the best way to gain control back in such situation when the car start spinning under wet road condition?
For me, I practice the technique from car simulation game. Usually the steps are, ease the brake and gas, and turn the wheel in the opposite direction.
correct lar!
I also got my knowledge in simulation games.. hence once when i skidded, can countersteer instinctively. PS3 games also not bad.. [nod]
As you said, the key is thread depth. So if you have a very wide tyre, and thread depth very deep... Then chances of hydroplaning occuring at lower speed is lesser. Then again, wide tyres with deep thread can only be found on tractors and off-roads.
er... so is wider tyres better or worse against hydroplaning?
my answer: i not sure
btw i tink the wide tyres/treads thinggy we are talkin abt here is at the scale of normal cars.. nt tractors/off roaders.... i'm sure tyre manufacturer would increase the proportion of tread depth to tyre width accordingly for street tyres...
To avoid hydroplaning, a tire has to push water out of the way without lifting off of the road surface. A narrow tire has less planing surface and a higher loading, so it is less likely to lift.
sounds logical, but narrow tyre while having a smaller planning surface have a smaller contact area as well...
so lets say 2 cars same weight, speed, road conditions etc, except one narrow and the other wide typres, with the same ratio of tread depth with tyre width...
in this case,
1.since contact area with the road is the key, which tyre has a bigger contact area?
2.hence is it correct to conclude that wide is better despite having a larger planning surface but still having a bigger contact area with the road than narrow?
sorry bro but its quite hard for me to imagine racing cars using narrow wet tyres [:/]
i don't think auto or manual makes a difference if u aquaplanned...
how do u control something that's floating on water?
the only wan u can control it is by sticking a stick down to the ground, which is 99.99% unlikely if such situtation arise.
is hydroplane = aquaplan?
I've aquaplanned 3 times since i started driving (twice car went to the workshop).
I don't think there's any way of controlling the car if in an event of aquaplan.
You can't steer the car, it doesn't move to the direction you want.
You can't jam the brakes, it doesn't work that way too, the car will still move forward.
Your brain wun allow you to step on the gas, unless you are willing to take the gamble of saving your life, or double-ing the damage or even death.
Tapping on the brake, I've not tried that yet, but seems like everyone says that it will work? I'm sure with today's technology of cars, ABS is there for such purpose right?
I'm sure everyone have their theory on how to counter the effects etc, but I bet only 10% actually will be able to manage it when such situtation arise. I used to laugh at my friend who crashed his evo due to aquaplanning, but when it happens, it happens. :)
The best way is to, PRAY TO GOD while ur car aquaplan, that's the best way to ensure the safety of your life. :)
Edited by Nazaki
Prevention is better than cure.
1. Don't try to save and buy cheap tyres.
2. Always check that your tyre pressure is correct.
If you want to go one step further,
1. Lower suspension
2. Adjust camber
Simplest solution.....DON'T SPEED!
  Quote
i used to drive a manual transmission rear wheel drive car in the US. the place i was in gets very heavy snowfalls and icy roads every winter so i got plenty of practice with the fishtails and wheelspins and stuff. Imagine "drifting" your car at 20mph on ice, sounds stupid right. When your car starts to "drift", do not hit the brakes, instead take the torque off the wheels by disengaging gear (or put transmission to neutral), and point your steering wheel towards the direction your rear is swinging into. this only works for wet or slippery roads.
for dry roads, if you're cornering and your rear is sliding out, put the pedal to the metal and accelerate out of the bend and you should be fine. In Singapore I find that many drivers cannot control their car when they go round a bend, always under or oversteering out of their lane. I soon realised why: I dunno where they learnt this from but the drivers here tend to brake thru a bend, and they tend to lose control of the car more easily when they do that. Do this: brake into a corner, when you reach the apex of the corner, downshift and accelerate out of it. You'll have a smoother and more controlled ride when you do that.
Wah ... now I know liao.
Been driving a manual car for the last 2 weeks ... quite fun .... can take alot of bents without even braking ... [nod][nod]
