Fkfs9 Neutral Newbie May 26, 2008 Share May 26, 2008 Gurus, I've gone thru the specs online for SLX265 and it only says Max 150 watts. Not too sure how to find the nominal power. Went to SLT and bought a soundstream amp PCA2.260 and the specs are as follow. Output @ 4 ohm: 80 x 2 Output @ 2 ohm: 130 x 2 Bridged @ 4 ohm: 260 x 1 So which should I choose? Choose output @ 2ohm or 4ohm? I have no intention of adding a sub just want this 2 channel amp to power up the front thats all. Rear is still stock. Should I mount the AMP at the bottom of my seat or fabricate a board and mount it in the boot instead? Thanks guys. ↡ Advertisement Link to post Share on other sites More sharing options...
Bearbear1494 Clutched May 26, 2008 Share May 26, 2008 Bro, for component speakers (& single coil subs for that matter), you don't get to "choose" which impedance you want when you're hooking them up to the amp unless you're using multiple units wired in such a way that you raise or lower the impedance. For the SLX, they're 4ohm speakers, so the amp output in this case will be 80W per channel. Since the amp's a 2-channel, naturally you'll be running the SLX in passive mode using the included crossovers. The mounting location of the amp is entirely up to you. If you have sufficient space under the seat, then by all means mount it there. Just make sure the power cables & the signal cables don't run alongside each other to prevent interference. Link to post Share on other sites More sharing options...
Apollo 1st Gear May 26, 2008 Share May 26, 2008 i think u got it wrong..for SLX 265 Delux Peak 150W Normal / RMS 100W Freq response 50-21000Hz Inpt sensitivity 90db 1W/1m Impedence 4 Ohm ur Soundstream may not b enuff to power it. do consider getting a 4 channel amp... as this allow upgradeability to control each channel Link to post Share on other sites More sharing options...
Fkfs9 Neutral Newbie May 27, 2008 Author Share May 27, 2008 Hi Bro, I get what you mean now. 4ohm so running 80W. Thanks. Link to post Share on other sites More sharing options...
Fkfs9 Neutral Newbie May 27, 2008 Author Share May 27, 2008 Hi Bro Apollo, I am using SLX265 not deluxe. So 4ohm @ 80w, confirm under power liao coz nomimal is 100W. Any suggestions within the price range of 300bucks? 4 channels but the 2 free channel power the rear, duno my rear can tahan or not. I also go no intention of a sub becoz it takes up too much space and i dislike the vibrating within the car. Maybe i can get a smaller sub. What do you suggest? Link to post Share on other sites More sharing options...
Apollo 1st Gear May 27, 2008 Share May 27, 2008 try searching under boss audio, 4 channel amp, bridge 2 channels. not sure how small is ur ride but u can get a 8" bass tube if it is ard Fit Jazz size. Link to post Share on other sites More sharing options...
Ks82 Neutral Newbie August 19, 2008 Share August 19, 2008 Don mind if i hitchhike this thread? I'm currently on csx265. Which amp should i get to match my speakers? my budget for the amp is below $500 inclusive of installation Link to post Share on other sites More sharing options...
Dunno Neutral Newbie August 19, 2008 Share August 19, 2008 80w/ch @ 4 ohms is enough to power it. Not a difficult pair of speakers to drive. You don't even need max gain to drive it. In fact, 80w rms is enough to drive most speakers in the market unless it's some high end power hungry speakers. Using a 100w/ch amp would probably make it sound a few dB louder, that's all. Link to post Share on other sites More sharing options...
Dygm Neutral Newbie September 8, 2008 Share September 8, 2008 am thinking of installing csx265 too. was quoted $380. Is it a reasonable price? What is your experience with it? I listen to classics and vocals. No intention to install sub woofer. Will go with a used 4-channel Kickers though. Your advice is greatly appreciated. Thanks. Link to post Share on other sites More sharing options...
Carnut Clutched September 11, 2008 Share September 11, 2008 The price is around there. Recommended Link to post Share on other sites More sharing options...
Rejoice Neutral Newbie September 11, 2008 Share September 11, 2008 bro can tell me where your got your quote. thanks. Was thinking of installing this speaker and is also looking for a 4 channel amp to pair it up. price range about 500-600 Link to post Share on other sites More sharing options...
Keromond 1st Gear September 12, 2008 Share September 12, 2008 (edited) Hi all, I also intend to have CSX265 n pair it with an amp...got a quote of 350( spkr only), Helix amp...but not sure wats the model..cos the shop was q busy...I just ask abit n went off. Any good 4 channel amp to go with this speaker...TIA Edited September 12, 2008 by Keromond ↡ Advertisement Link to post Share on other sites More sharing options...
Encounters with tyre shop
