Typoerror Neutral Newbie May 20, 2008 Share May 20, 2008 time to skim my rotors. any recommendations? ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 20, 2008 Share May 20, 2008 at e end of the jervious rd, there is garage in e esso station. look for ah jian who can do it for u. installation $35 n skimming is $35, i tink. Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 20, 2008 Share May 20, 2008 Blk 10 Sin ming. Leun Seng Engineering. they skim, as they are an engineering shop. you can see them boring ship engines or big truck engines. but them you need to DIY and remove the rotor yourself. Link to post Share on other sites More sharing options...
Typoerror Neutral Newbie May 21, 2008 Author Share May 21, 2008 thanks for the reply. will check it out Link to post Share on other sites More sharing options...
Whocaremi83 Neutral Newbie May 21, 2008 Share May 21, 2008 maybe can go jb cheaper Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 21, 2008 Share May 21, 2008 I don't think it's worth the $$ to skim the rotor, better to replace them. A OEM rotor from Brembo should be around $100+ Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie May 21, 2008 Share May 21, 2008 I also dont think it is good to skim the rotor as it may become too thin and warps even easier, replacement make more sense in the long run. Link to post Share on other sites More sharing options...
Typoerror Neutral Newbie May 21, 2008 Author Share May 21, 2008 hey, i bought spark plugs from you long long time ago. any idea where to buy and install oem brembo rotor? i am using the stock brembo set of evo9 actually. skimming is recommended by a reputable wksp, but they quoted me very high , hence i am exploring if can do outside. Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 21, 2008 Share May 21, 2008 yes, rotor is meant to wear down, so better to replace Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 21, 2008 Share May 21, 2008 For Brembo OEM, try Automart, boss is Boon Hua, 64815290, it's in AMK autopoint Link to post Share on other sites More sharing options...
Jemjem 1st Gear May 21, 2008 Share May 21, 2008 hi so we can solely change the rotor? it will fit into our stock brakes? jemjem Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 21, 2008 Share May 21, 2008 yes, you can, no not you can, you must as the Rotor is also a wear and tear item that needs to be replace, of course not as often as the brake pads. A rule of thumb, if the rotor is having a wear of about 4mm or more, best is to change it. You can use your finger, only when the brakes are cold, not when you have just stop driving to touch the edges for the wear. Most stock cars are having single or some dual pot calipers that are being push from inside, so if you are having a wear of about 4mm on the outside of the rotor, the inner part will have a much higher wear Original stock Rotor from AD will be much more ex than stockists of Original stock Rotor for whatever car make but Brembo (being a brake specialists) OEM Rotor will be of better quality than Original stock Rotor and will give a better grip prices could also be cheaper than stockists Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie May 21, 2008 Share May 21, 2008 I cannot imagine a wear of 4mm on one side of the rotor and people are still using it. The nissan primera service manual states front ventilated disc rotor should be changed when the rotor thickness drop by 2 mm (both sides add together) Thickness Inspection Using a micrometer, check thickness of the disc rotor. If the thickness is outside the standard, replace the disc rotor. Measurement point: At a point 10 mm (0.39 in) from the outer edge of the disc. Standard thickness : 28.0 mm (1.102 in) Wear limit : 26.0 mm (1.024 in) Maximum uneven wear (measured at 8 positions):0.02 mm (0.0008 in) or less So I estimate it should be changed if it is down by 1 mm from the outside. The specs for rear disc rotor is from 16 mm down to 14 mm, also two mm wear. Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 21, 2008 Share May 21, 2008 (edited) I think it depends on the model of rotors. My stock ones are damn thick. Its already worn down about 2mm and looks like there's hellavu lot more to go. But compared to my ex-colleague's (think his is brembos), he is down about 1mm and you can see that the slots are almost gone..... and the rotors are pretty thin to begin with. Edited May 21, 2008 by Dwoon Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie May 21, 2008 Share May 21, 2008 Any idea if Brembo has parts for Primera P12 ? Pads or disc rotors Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie May 21, 2008 Share May 21, 2008 I know the stock ones are very thick, 26 mm is very thick (includes the ventilation gap) but still below a certain thickness, it gets warped easily, You cannot used the disk rotors until the metal is paper thin. If when you step the brakes at high speeds and noticed your steering vibrates, it is time to change the rotors. Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 21, 2008 Share May 21, 2008 Bro, can recommend your "kang tao" for cheap rotors??? The price you've mentioned is very good and I'd like to get a set since I'm due for a change...... I don't think it's worth the $$ to skim the rotor, better to replace them. A OEM rotor from Brembo should be around $100+ Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 22, 2008 Share May 22, 2008 I normally change mine when it's about 3mm of wear ↡ Advertisement Link to post Share on other sites More sharing options...
Where to mod fuel needle?
Where to get those plastics that allow your to stick the road tax/decal on screen
Wheel Spacer, where to buy?
Change Disc Rotors
Change Disc Rotors
Where you cut your hair?
Going to Batam. Where to park overnight ?
NBA - Where Amazing Happens
