Booboon 1st Gear April 29, 2008 Share April 29, 2008 Hi detailing Gurus, As above question, does SRP contain any abrasives? Will frequent application (lets say once every 2 weeks application) thin down the car paint? Have been reading this forum and recieved contridicting report, some say it contains abrasive while others say no, it is strictly a chemical polish. Currently I m using DG101, but the curioisty part of me would like to try SRP one day. What is the function of the microscopic "resin" found in it. Anyone? ↡ Advertisement Link to post Share on other sites More sharing options...
Porker Turbocharged April 29, 2008 Share April 29, 2008 Don't know but all I can say is it works pretty well. I always add another layer of wax after applying the SRP Link to post Share on other sites More sharing options...
Maddriver 4th Gear April 29, 2008 Share April 29, 2008 Simple..try to squeeze some on to your finger..is kind of sandy feel.. contain mild abrasive in it.. possibilty of thining down the clear coat by hand is quite impossible... Link to post Share on other sites More sharing options...
Maddriver 4th Gear April 29, 2008 Share April 29, 2008 Bro.. your avartar... faint la Link to post Share on other sites More sharing options...
Civicfd Neutral Newbie April 29, 2008 Share April 29, 2008 Wa lau, the avartar damn poison. Watch out your lips, will get swollen and ended up 'ICU' . Link to post Share on other sites More sharing options...
Lv3338 Clutched April 30, 2008 Share April 30, 2008 I used it once in a while on stubborn stain which cannot be removed with hard rubbing with 101 or 501. Quite effective. Of course, use a slight bit to prevent wearing of the clear coat Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear April 30, 2008 Share April 30, 2008 its very nice, made the ride very shiny but then I lazy to use wax after polish haha until I find a good one.. the current ones I got is very hard to remove and always get stuck in between gaps. Link to post Share on other sites More sharing options...
Bearbear1494 Clutched May 8, 2008 Share May 8, 2008 SRP has very mild abrasive properties. Unless you're using a rotary or orbital buffer, it should not wear down the clear coat with frequent applications like once a month. For touch ups in between, recommend you use a quick detailer spray instead. Do note that SRP doesn't last very long by itself. It's a cleaner wax then still requires a wax or sealant topcoat in order to preserve the newly-cleaned surface. Link to post Share on other sites More sharing options...
Kangeroo78 Neutral Newbie May 23, 2008 Share May 23, 2008 Seen actual car with autoglym rsp, really shine. ↡ Advertisement Link to post Share on other sites More sharing options...
Amici Enterprise - Carbon Shield Exterior, Glass and Interior Coating starting from $348!
Autoglym Paint Renovator
Autoglym vs Duragloss vs Meguiars
SGCM has exactly 1,234 pages of news articles at this moment
What exactly is a sports car?
2 different cars spotted with exactly the same number plate
Autoglym Wind screen / Glass Polish
What exactly does Air Chargers like this one do?
