Othello Supersonic April 3, 2008 Share April 3, 2008 (edited) its not so simple. once unscrewed, you can feel some tension when pulling. Read from briskoda that those guys just yanked it out. There seems to be catch or something like that. Edited April 3, 2008 by Othello ↡ Advertisement Link to post Share on other sites More sharing options...
Fortress Clutched April 3, 2008 Share April 3, 2008 Thanks for the info...will do that when someone is scraping his car... Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie April 4, 2008 Share April 4, 2008 unscrew already there is a second lock mechanism which need some force to pull it out....tat is wat i did to remove my antenna....now i got problem removing again Link to post Share on other sites More sharing options...
Fortress Clutched April 4, 2008 Share April 4, 2008 Thanks. Ok...understand, means my broke after 5 years, the next time to change is good enough to scrap.... ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
Toyota Axio 1.5L 2007 Engine Valve Cover Gasket & Plug Seal
Bridgestone Pink Valve Cap Donation Drive
Tire air pump difficulty
Fumoto Oil Drain Valve
$195 for valve cover gasket and plug seal?
Local gaming team forced to pull out of world tournament
