Spidey10 Supercharged April 4, 2018 Share April 4, 2018 On 4/4/2018 at 4:43 AM, Discoburg said: Haha bo bian, tyres worn out. Purchased 2 years ago and used like for 40K km. No, yes. tqvm.....ok, i am not alone in this then....scared tyre shop will laugh at me... ↡ Advertisement Link to post Share on other sites More sharing options...
Discoburg Supersonic April 4, 2018 Share April 4, 2018 To be frank, never had anyone asked me whether wanna do a alignment with rotation of tyre change. On 4/4/2018 at 5:18 AM, Spidey10 said: tqvm.....ok, i am not alone in this then....scared tyre shop will laugh at me... Link to post Share on other sites More sharing options...
Beregond Supersonic April 4, 2018 Share April 4, 2018 On 4/4/2018 at 5:18 AM, Spidey10 said: tqvm.....ok, i am not alone in this then....scared tyre shop will laugh at me... actually only a small % of tyres shop do alignment 2 Link to post Share on other sites More sharing options...
Albeniz Turbocharged December 18, 2020 Share December 18, 2020 (edited) Any good recommendation for tyre rotation and balancing near upper Bukit Timah, Bukit Batok or Tew Tee Industrial area? I am assuming they would help inflate the tyres too when I drive in. Also, my wheel alignment should be ok, but I just need to re-verify, How much would it cost for them to do a simple check/test? Just changed a pair of front absorbers recently, the ride improves, but not perfect yet (still can feel abit bouncy), so I am checking the tyres. Are Autoserv at Shell ridiculously expensive? They are conveniently located. Edited December 18, 2020 by Albeniz Link to post Share on other sites More sharing options...
Volvobrick Supersonic December 18, 2020 Share December 18, 2020 (edited) On 12/18/2020 at 4:48 AM, Albeniz said: Any good recommendation for tyre rotation and balancing near upper Bukit Timah, Bukit Batok or Tew Tee Industrial area? I am assuming they would help inflate the tyres too when I drive in. Also, my wheel alignment should be ok, but I just need to re-verify, How much would it cost for them to do a simple check/test? Just changed a pair of front absorbers recently, the ride improves, but not perfect yet (still can feel abit bouncy), so I am checking the tyres. Are Autoserv at Shells ridiculously expensive? They are conveniently located. Expand Alignment itself should be about 60 dollars. My WS recommended me Soon Huat at level 1 Enterprise Centre but quite popular better check first. I have been buying tyres from Yap Bros at Toh Guan. They should rotate/balance for you. At least they use torque wrench! And now also top up with nitrogen (which I couldn't care less). Edited December 18, 2020 by Volvobrick 1 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 18, 2020 Share December 18, 2020 On 12/18/2020 at 4:48 AM, Albeniz said: Any good recommendation for tyre rotation and balancing near upper Bukit Timah, Bukit Batok or Tew Tee Industrial area? I am assuming they would help inflate the tyres too when I drive in. Also, my wheel alignment should be ok, but I just need to re-verify, How much would it cost for them to do a simple check/test? Just changed a pair of front absorbers recently, the ride improves, but not perfect yet (still can feel abit bouncy), so I am checking the tyres. Are Autoserv at Shell ridiculously expensive? They are conveniently located. Expand Try to pump 2psi higher to see whether it is still bouncy. It could be sidewall flexing. 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 19, 2020 Share December 19, 2020 On 12/18/2020 at 4:48 AM, Albeniz said: Any good recommendation for tyre rotation and balancing near upper Bukit Timah, Bukit Batok or Tew Tee Industrial area? I am assuming they would help inflate the tyres too when I drive in. Also, my wheel alignment should be ok, but I just need to re-verify, How much would it cost for them to do a simple check/test? Just changed a pair of front absorbers recently, the ride improves, but not perfect yet (still can feel abit bouncy), so I am checking the tyres. Are Autoserv at Shell ridiculously expensive? They are conveniently located. Expand tire shop and workshop every where, to me is always good to go back to the shop where you purchased your tires, otherwise is not rocket science to do such job , is the matter how the work is carry out, examples (i suppose checking tire pressure is a MUST) Package 1 simply use power gun removed and swap cost may from FOC to $$$$ (10 mins job) Package 2 same as above but balance 2 front only from FOC to $$$$$ (20 mins JOb) Package 3 same as above and balanced all 4 (30 mins Job) Package 4 remove and Clean and wash your wheel outside in , remove the old weight and double sided glue (black black colour usually) tire shine your tires , even oil your nuts and Bolts ,center hub as well , securing the NUTS and BOLTS manually (no power gun used to prevent over tightening) and even Torque it (BEST) (min 45min to 60 mins work ) COST ? you decide what is justified and not sure anyone offering FOC. Package 5 balance and Rotate on Job Card and usually FOC lol Package 6 ? any input from your experient Link to post Share on other sites More sharing options...
Volvobrick Supersonic December 19, 2020 Share December 19, 2020 (edited) I always request the tyre shop to clean up the old sticky tapes. Sometimes even the brake dust too. No extra charges so I continue to patronise them. Edited December 19, 2020 by Volvobrick 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 19, 2020 Share December 19, 2020 so you are probably having PAckage 4 Cheers 1 Link to post Share on other sites More sharing options...
ayaz Neutral Newbie January 18, 2022 Share January 18, 2022 there are alot of shops are available in market. you need to choose only which shop who have proper skills. Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 25, 2022 Share January 25, 2022 On 1/18/2022 at 12:44 PM, ayaz said: there are alot of shops are available in market. you need to choose only which shop who have proper skills. Expand proper skills is ? it doe not need super skills to execute the Task but is about Bother to do it properly with Proper tools and Skill, i really do not like to way some WS using their Power air tools to fasten the bolts or nuts like playing it. (always over tightened and may cause cross thread untill when you need to remove it from your car) Link to post Share on other sites More sharing options...
Vratenza Supersonic June 2, 2022 Share June 2, 2022 I need an updated recommendation for tire high speed rebalancing and rotation. Prefer central/southern part of sg. Thanks in advance! Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 2, 2022 Share June 2, 2022 On 6/2/2022 at 3:00 PM, Vratenza said: I need an updated recommendation for tire high speed rebalancing and rotation. Prefer central/southern part of sg. Thanks in advance! Expand Can't go wrong with South East Tyre and Kim Hoe...may need to wait for a while with the latter even when you book a slot...I go to the kaki bukit outlets of both...you may try SET at marine terrace if it's nearer for you. ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
