Sirbrian Neutral Newbie March 17, 2008 Share March 17, 2008 Just bought a laptop. The OEM gave 3Gb of DDR2 667MHz SODIMM RAM. I just read that to fully utilize the DDR2 effect I must have identical pair. So then, I just realise that kenna bluff by this OEM again. So yesterday open the ram cover, remove the 1Gb and slot in a new 2Gb RAM that I bought from Sim Lim. Then I realise that the brands are different though they are same 667MHz. Can I ask for advice if it is necessary to have both rams of from the same brand? ↡ Advertisement Link to post Share on other sites More sharing options...
Thug Clutched March 17, 2008 Share March 17, 2008 I dun think so it will make any diff...i used a kingston and another brand (I think its maxton?) in my pc b4..and it has no problem operating... Link to post Share on other sites More sharing options...
Typhoonz 4th Gear March 17, 2008 Share March 17, 2008 I think just as long as the same speed okie then it's regardless of brand... If you have 2 pieces of ram with different speeds i.e. 667MHz and 800MHz, then they'll be operating at the lower speed (667MHz)... Link to post Share on other sites More sharing options...
Gh05tss Neutral Newbie March 17, 2008 Share March 17, 2008 To be truly dual channel, same brand, same batch. You need to find out if your lappy support Dual Channel. Use http://www.cpuid.com/cpuz.php to find out more of your rams n lappy. Link to post Share on other sites More sharing options...
Slowmo Clutched March 17, 2008 Share March 17, 2008 (edited) wah who your oem. buylaptop, worst case scenerio i rather get dell... they do advise you of technical limitations like this. and btw,, certain chipsets already support asymmetrical DDR2 configurations. its only the older chipsets that you need 2 of the same ram capacity Edited March 17, 2008 by Slowmo Link to post Share on other sites More sharing options...
Sirbrian Neutral Newbie March 17, 2008 Author Share March 17, 2008 actually i'm refering to my new dell inspirion 1420 In fact the rams they install is also of different brands too. Link to post Share on other sites More sharing options...
Slowmo Clutched March 17, 2008 Share March 17, 2008 (edited) most newer dell chipsets already support asy DDR2 configurations. go check out what chipset model is ur intel, then refer to intel.com. or just open a support ticket with dell. the 'same ddr2 ram' thing is only applicable to older intel chipsets. thats as much as i know. i don't work for dell though i just have a vostro laptop. Edited March 17, 2008 by Slowmo Link to post Share on other sites More sharing options...
Sirbrian Neutral Newbie March 17, 2008 Author Share March 17, 2008 it is written in my laptop manual that I do need a pair of same ram size to utilize the DDR2 effect. Link to post Share on other sites More sharing options...
Kingkong 5th Gear March 17, 2008 Share March 17, 2008 (edited) Differing brands are ok, most of the time. But what Bro Gh05tss mentioned is valid, if you're refering to Dual-Channel ability, provided your notebook supports that. If the notebook doesn't support dual-channel, or there's no intention to utilise the dual-channel function, then it doesn't matter whether brand A mix with brand B, or 1GB mix with 2GB. Extracted from Dell site for 1420 ==> Up to 4GB2 shared3 Dual Channel 667MHz DDR2 SDRAM provides blazing performance. Edited March 17, 2008 by Kingkong Link to post Share on other sites More sharing options...
Sirbrian Neutral Newbie March 17, 2008 Author Share March 17, 2008 so mine does provide dual channel yah? thanks...sorry me pretty lousey on pc term and tech. ↡ Advertisement Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
Car accident advice
Car accident advice
Need Advice on Self Storage
Rearing Fish or Koi - advice needed
