Passion 5th Gear March 9, 2008 Share March 9, 2008 Hi guys,got a very serious problem.My car suddenly has high fuel consumption,used to travel 40km before my needle reach 3/4 mark,now only 7.1km and it reached 3/4 marking.Btw,make and model is mazda 2 '04 model.Pls advice. ↡ Advertisement Link to post Share on other sites More sharing options...
Latioboy 1st Gear March 9, 2008 Share March 9, 2008 Have you gone for servicing? You been heavy right foot-ing? Also, check your engine oil. It could be very dirty Or just coincidentally, you could have been stuck in a jam, for that particular tank.... Link to post Share on other sites More sharing options...
Miles 4th Gear March 9, 2008 Share March 9, 2008 check fuel injector... if it is leaking fuel.... your whole tank of petrol will be finished in 200km. Link to post Share on other sites More sharing options...
Knightskid Clutched March 9, 2008 Share March 9, 2008 Did you smell petrol inside your cabin? If so, then pop up your bonnet and see whether your fuel line hose is crack and leaking. Link to post Share on other sites More sharing options...
Watwheels Supersonic March 9, 2008 Share March 9, 2008 Kind of difficult to pin point the fault according to your info. I guess it could be the fuel pump which is faulty. Link to post Share on other sites More sharing options...
Passion 5th Gear March 9, 2008 Author Share March 9, 2008 definitely no.I just pump last nite.And i release it when it click off.I didnt squeeze any more in or what.Normally by doing so,20 to 30km,depend on traffic flow,the needle will drop just below the full marking.now not even 30km,at 3/4 marking.Wow!!! Link to post Share on other sites More sharing options...
Passion 5th Gear March 9, 2008 Author Share March 9, 2008 how to check? Link to post Share on other sites More sharing options...
Passion 5th Gear March 9, 2008 Author Share March 9, 2008 no petrol smell leh..only fishy smell,i just came back from market.Definitely the fishy smell wun cover the petrol smell? Link to post Share on other sites More sharing options...
Maersk1 1st Gear March 9, 2008 Share March 9, 2008 bro...did you check your undercarriage ?? could the fuel tank leakage ?? Link to post Share on other sites More sharing options...
Knightskid Clutched March 9, 2008 Share March 9, 2008 Did you pop up your bonnet and trace the fuel line whether is there any crack? Link to post Share on other sites More sharing options...
Miles 4th Gear March 9, 2008 Share March 9, 2008 you have to bring in to servce centre and ask them to check. i know the previous B5.5 passat had this problem.... some VAG owners were complaining that they get only 6-7km/L only to realize their fuel injector was leaking. It does not ooze petrol when engine is off. Only when you drive the car, fuel pump pumps petrol to the injector that leaks and drips instead of spraying fuel to the combustion chamber... the current Passat also reportedly (in european car forum) have fuel pump failure problem. dont know if it affected the cars locally. Link to post Share on other sites More sharing options...
Passion 5th Gear March 9, 2008 Author Share March 9, 2008 checked.No fuel leaking.I trace the route from entrance of car park to lot.no sign of leakage. Link to post Share on other sites More sharing options...
Passion 5th Gear March 9, 2008 Author Share March 9, 2008 Pop up the bonnet,no sign of crack or oozes of petrol. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear March 9, 2008 Share March 9, 2008 Maybe you would like to bring your ride back to MM for a check up There are many causes to why there is a sudden increase in fuel consumption i.e dirty injectors, air filter, fuel pump kapo, leaking fuel lines .... etc Link to post Share on other sites More sharing options...
Passion 5th Gear March 9, 2008 Author Share March 9, 2008 How much to change the fuel pump and stuff?I ask a mechanic,he say pump full tank and monitor.Maybe the pump at station triggle off earlier.I was thinking,how could i travel 377km with only 26L of petrol?Tat's a awesome 14.2km/l for Mazda 2(pre-FL).I encounter this early trigger off at Esso Mobil pump station twice.But neva to this extend.Does catalyst convertor failure contribute to high FC? Link to post Share on other sites More sharing options...
Sir8 Neutral Newbie March 9, 2008 Share March 9, 2008 1/4 tank for 40km? so full tank only 160km? Have I read you wrongly? 7.1km for 1/4 tank!!!???? Link to post Share on other sites More sharing options...
Passion 5th Gear March 9, 2008 Author Share March 9, 2008 nope.1/4 tank from top lasted 7.1km.Maybe fuel needle spoil.it's analog,not digital type. Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear March 9, 2008 Share March 9, 2008 it could be possible for this case to happen.. but then, best to send it back to MM for checking.. or u got fool around with the needle to go m'sia?? ↡ Advertisement Link to post Share on other sites More sharing options...
Where to mod fuel needle?
Are You A Big Spender For A High End Bed Mattress?
Fuel Plus Meet Up
Fuel Plus Meet Up
